Question about Air Tools & Compressors
Crftsmn 17 gal vrtcl air compr some water entered garage where comp is. When I plugged it in would not turn on. could water have damaged it?
  • JODY BRIDGERS May 11, 2010
    HOW MUCH WATER. DID THE MOTOR OR PUMP GO UNDERWATER? MOST COMPRESSORS FLOAT-TYPICALLY UPSIDE DOWN - BUT THEY FLOAT. YES, WATER CAN DAMAGE BUT THEY SOMETIMES WORK FINE AFTER DRYING OUT.
  • 98 Answers
Yes that is a posability
Posted on Jul 21, 2009
Water leaking into oil on a 93 lincoln
It may be going in through the intake gasket.
Dec 06, 2014 | 2003 Lincoln Town Car
I did not drain the tank on my 80 gal comp now trying to drain I only get a trickle out of the drain line. Help
Take drain plug completely out of bottom of the tank and remove the outlet plug on the side of tank. pour 1 gallon of clean water into tank and stir up sediment. . Replace the side plug and start compressor , keep this up until drain water runs clear not orange. Then re install everything and check tank pressure and for leaks.
Apr 15, 2013 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
I have a 3 gal/ 1HP Craftsman air comp. When I plug it in and turn it on, I get the sound of current getting to the motor but it does not start. A failed Starting capacitor?
Could be, do you have a capacitor checker? It sounds like you have a compressor locked up. Do you have oil in the compressor? If the compressor is new I would take it back and see if it is still under warranty. before I did any thing to it.....
Dec 19, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Check air compressor in the garage. Took it inside and plug it in. Nothing. What would possibly cause it to work one second, then not the next?
you have to start at the beginning. your outlet, cord, motor breaker, the on off switch on the comp that trips the comp off at a set pressure. if you know how to use a volt ohm meter that would be good to check the cord and breaker. some time the pressure switch contacts will arc and burn a little and then don't make good contact.
Aug 31, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
No air pressure
If your motor is running and the pressure is not building it is either the valve plate or the compression ring. Check both for damage.
Sep 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I am missing the screw in drain plug for a Model 95386 air comp.
this is normal item at parts house, anyway why do have a plug. i put a small ball valve much better i got at home depot
Jul 02, 2009 | Air Tools & Compressors
CRAFTSMAN 25 GAL,1.6 HP COMPR. AFTER 1ST CYL WONT START BACK UP
the regulator on this model is know to go bad alot, probably needs replaceing. go to sears wbsite to order the part
Feb 27, 2009 | Craftsman Air Tools & Compressors
Valve plates installed wrong
Try this one and you can download an owner's manual from that page that has an expoded view of the compressor disassembled for parts identification Not sure if it's the right compressor,, closest I could find
http://www.sears.com/shc/s/p_10153_12605_00915312000P?mv=rr
Nov 19, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
19 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
