Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony 46inch tv will not come off standby from the remote
Changed batts from both remotes sony/ sky, tv comes on,but thens goes straight on to standby
    Scholar:
  • 85 Answers
Its the main board poroblem.its due to the components on the main board getting over heated due to got loose internally or short in between. have to be checked with a meter and replaced.
Posted on Feb 26, 2009
Sky remote code for model UE40J5100AK
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Press "TV" again then enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press TV then the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at:Skyplease remember to use your back button and come back to us.
www.electro-medical.blogspot.com
Samsung brand code 0060
3 digit code for Samsung
065, 584, 037, 245, 476, 398, 516, 292, 318,037
Oct 13, 2015 | Samsung Televison & Video
Code for sony tv
Make sure your TV is on.
press "TV" on your sky remote
hold down both "SELECT" and then "RED" button until the little LED blinks twice on your sky remote. (should be for about 2 seconds)
press "TV" again
enter the code "0000" on your sky remote
the little LED should blink twice again. (if it didnt, restart the process)
if it had blink twice, then press the "STANDBY" button on the sky remote - your TV should turn off. (if it didnt, restart process again)
if it did - press "SELECT" the little LED should blink twice again, and hey presto - you is programmed wink.gif
Apr 25, 2013 | Radio Shack (15-2147) Remote Control
I need the code number of tv to enable me to use sky remote control
Please try 0863 for Hyundai Televisions To program your Sky remote control using the 4 digit code
  1. Switch on the TV set
  2. Press the TV button on the Sky Remote
  3. Hold down the Select and Red buttons for 2-3 seconds until the LED blinks twice
  4. Press the TV button on the Sky Remote again
  5. Enter 0863
  6. The LED should blink twice, if not recheck the 4 digit code used and go back to 1
  7. Press the standby button on the Sky Remote (The TV should go to standby)
  8. Press the Select button to store
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Please keep me posted.
Thanks.
Lor04
Apr 06, 2011 | Hyundai Televison & Video
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Mar 15, 2011 | Hannspree XV32 32 in. LCD Television
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
I need a code for my sky remote for my sanyo tv in order to get the volume working It is a sanyo 32" Model CE32LD33-B-01
with the tv on and sky off, press red button & select together, remote blinks twice.press tv then standby repeat this action until the tv turns off. when it goes off press select. press standby again and tv should start. your sky remote should then work perfect. as a tip with tv on and sky off press tv then back up this should then go to the freeview setup and you can watch those as well for free
Sep 09, 2010 | Sanyo Televison & Video
Code for TV / Sky+remote
Problem: Need Sony manufactures code for the Sky remote.
Solution: Your TV Code for Sony is 0000
1. Turn on your TV.
2. Ensure that the front of your Sky Navigator is closed.
3. Press "tv”.
4. Hold down "select" and the red button together for about two seconds, until the red LED on the Sky Navigatore flashes twice.
5. Press "tv" again.
6. Key in the four digit code for your brand of TV. The LED on the Sky Navigator will flash twice. If the LED illuminates only once, re-check the code for your brand of TV and start again at step 5.
7. Press the standby button on your Sky Navigator. If your TV switches off, press "select". The LED on the Sky Navigator will flash twice. If your TV does not switch off, press "tv", then press the standby button.
Repeat this (press "tv", then standby button) until your TV turns off,
then press "select".
If you are still experiencing problems, please telephone for technical
assistance. you will find the "Technical Help" telephone number by
pressing "services" and selecting "Telephone Numbers".
The help given is based on information taken.... Hoped this has helpd you
Jan 13, 2009 | Televison & Video
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Oct 17, 2008 | Philips HDD065 MP3 Player
Sky remote
hi turn your tv on then if you get your remote point it at the tv then press tv on the remote then press the red button aswell as the select button together waite till the led on the remote blinks twice then press tv again on the remote then press the off button on the remote keep pressing tv then off pausing a second or 2 till the tv goe's into standby, once the tv goe's into standby press the select button till the led on the remote blinks twice then your remote should be programed into your tv. hope this helps.
Sep 20, 2008 | Audio Players & Recorders
Hitachi CLE984
The code you need is 0145
Jul 01, 2008 | Hitachi CLU-5713TSI Remote Control
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
165 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
