Question about Microsoft Xbox 360 Wireless Controller and Play & Charge Kit - Game pad - Micros
Windows cannot initialize the device driver for this hardware.
Xbox 360 pad wired i get the same problem and its a standard wired 360 pad i try to uninstall.update.rollback.even download othere drivers it still dont work theres no help i even got uniblue 2009 to scan my drivers and my registry after all drivers where updated it still dont work i try 2 othere pads and it dont work still i had it working on this pc with xp before it got a nasty virus so i reinstalled xp on my pc and nowdays it dont work just keeps saying.. Windows cannot initialize the device driver for this hardware. (Code 37)
  • Azrul Syahriman
    Azrul Syahriman May 18, 2009
    Windows cannot initialize the device driver for this hardware. (Code 37) for my Xbox 360 controller for windows.
    (Windows XP)
  • 28 Answers
SOURCE: i need drivers for the
This should be it.
http://download.microsoft.com/download/0/0/f/00f2a67b-e10b-43b1-8cca-3deb12218f75/Xbox360_32Eng.exe
if that doesn't work try this:
http://www.microsoft.com/hardware/download/download.aspx?category=Gaming
~gnomer
Posted on Jan 04, 2009
  • 4 Answers
SOURCE: Xbox 360 wired control pad won't work
Possible fix, make sure your contacts are clean, and your cable is not damaged. Obviously the 5v lines are connecting, but no data is getting through. I reccomend using a q-tip to get any grime off, but you may need rubbing alchohol (90% reccomended because it dries cleaner). Clean off the connections on the xbox and the controller. If it still doesnt work, list any extras you have plugged into your controller, and the estimated time you bought the controller.
If all else fails, I've just got a great deal on a MadCatz xbox 360 controller ($25) and its fully functional, minus the controller faceplates if thats your cup-o-tea.
Posted on Feb 07, 2009
SOURCE: Xbox 360 wired pad not working, worked for about 2
batteries?
Posted on Jun 01, 2009
SOURCE: wireless xbox 360 control pad
U JUST BUY ANOTHER ONE ;)
SIMPLE
Posted on Oct 10, 2009
  • 25 Answers
SOURCE: my xbox 360 wireless controller
Could be a couple of things.
Replace the batteries, making sure they are in the controller in the right direction.
Resync the controller to your xbox. This is done by pressing the small sync button on the front of the xbox, then pressing the small sync button on the top of the controller (near the charge port.)
If neither of these work, you might have a faulty controller.
Posted on Feb 28, 2011
Walmart controller not working on my pc
Set up a wired controller
Step 1: Install the Xbox 360 controller for Windows software
Use the installation CD that came with your Xbox 360 controller for Windows before you connect the controller for Windows to your computer:
  1. Insert the installation disc in the CD or DVD drive of your computer. If the Setup program does not automatically start, change to your CD or DVD drive and run the setup program.
  2. On the setup screen, click Install.
  3. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
If you don't have an installation disc for your Xbox 360 controller for Windows, you can download and install the software online:
  1. Go to the Software Downloads section of the Microsoft Hardware website.
  2. Select Gaming as the product type.
  3. Select Xbox 360 Controller for Windows as the product.
  4. Select the version of Microsoft Windows you are using on your computer, select your operating system language, and then click Download.
  5. Click Run.
  6. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
Step 2: Connect the controller to your computer
After you install the software, plug your Xbox 360 wired controller's USB connector into a USB 2.0 port on your computer.
Step 3: Test the controller
To test your Xbox 360 wired controller on your computer, follow these steps:
  1. On your computer, click Start, type Run, type joy.cpl, and then press ENTER.
  2. Select Xbox 360 Controller, and then click Properties.
  3. Test your Xbox 360 wired controller by pressing a button, pulling a trigger, or moving a stick on the controller. If the controller is functioning correctly, you will see the corresponding action light up in the application. If the application does not recognize your controller, see Troubleshoot your Xbox 360 controller for Windows.
Jan 06, 2014 | Microsoft Xbox 360 Controller
Try clearing the cache on your Xbox console:
http://support.xbox.com/en-US/xbox-360/settings-and-initial-setup/clear-system-cache
If the game is installed on the hard drive try uninstalling it and running it from the disc
If the issue persists contact Microsoft about hardware repair.
http://support.xbox.com/en-US/xbox-360/repair/repair-process
May 06, 2013 | Microsoft Xbox 360 Console
My XBOX 360 wired controller is barely a month old and it has stopped working already. Every time I try to connect the controller to my PC (Windows 7), it says device not recognized. I have tried...
I have to ask the question have you contacted Microsoft about this issue? Since the device is only one month old it is still under full factory warranty. Also you question is confusing in that you talk about an xbox360 conrtoller that has stopped working but do not define if it stopped working with your xbox 360 and you are now trying to have an xbox360 device work with a PC instead of xbox360. Please get back to me with more accurate information. But you best bet is to contact microsoft since it is still under warranty.
best,
DeepReserve (game tag on live)
Jun 18, 2011 | Microsoft Xbox 360 S9F-00001 Wired...
Wired 360 pad isn't working
I had same problem..if u have a dance pad with foam inserts....take out the insert and try to start up without them....the problem we had is one of the inserts was putting pressure on one of the buttons preventing xbox from reading pad...if u don't have inserts one of your buttons is sticking...give it a shake and try again....we fixed ours by simply rearranging the inserts...hope this was helpful
Jun 12, 2009 | Konami Dance Revolution DDR Original Dance...
Xbox 360 Controller and USB Headset Conflict
Go to control panel, sound and audio, hardware, USB devices, and disable it. The computer thinks the XBox controller is an audio device and is giving it priority.
Aug 26, 2017 | Logitech 250 Headset
Video Game Consoles & Games Logo
290 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
