Question about HP LaserJet 3030 All-In-One Printer
Copying only half of the page
Only copies half of the page while copying and incoming fax
    Scholar:
  • 85 Answers
Many times when this happens. 1)try reloading the printer drivers again. 2)also check the wires connected properly. 3)or check receiving fax from some long distance location.or very near location.
Posted on Feb 26, 2009
Incoming faxes have black line running through the centre
If it is just from incoming faxes and not from anything you print/copy then it is the sender's fax machine that is dirty. If everything you do has that line, try cleaning the scanner glass and corona wire.
Jun 09, 2010 | Brother IntelliFax-2920 Fax
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
PROBLEMS WITH CLARITY OF INCOMING FAXES /BLACK STREAKS DOWN ENTIRE PAGE/VERY HARD TO READ SOME OF THE INCOMING FAXES.RECENTLY REPLACED DRUM AND TONER/WHAT WOULD BE CAUSING THIS PROBLEM?
First, make a copy of something to determine if your machine is at fault.
Move the blue slider on the drum cartridge back and forth 10 times.
Oct 01, 2009 | Brother IntelliFAX 4100 Laser Fax
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Incoming fax shows one half of the page
The Thermal printhead is most likely burned out on one side and will need replaced. It could also be the printhead connector has worked loose and is only making partial contact. Remove the connector and reinstall. If that doesn't solve the problem then it would be cheaper to purchase another fax.
Jan 22, 2009 | Sharp UX 108 Roll paper Thermal Fax
HP 920 Fax Half Lines
Try making a copy of something.
If the copy comes out the same way as your faxes, then the ink cartridge is either dirty or clogged.
You can try removing the cartridge and checking the bottom of it.
You can even wipe the bottom of the cartridge with some denatured alcohol.
If this doesnt work, then purchase a new cartridge and your problem should be solved.
Good luck.
Hope this helps.
Mac =)
Apr 02, 2008 | HP 920 Plain Paper Fax
HP LaserJet 3030 All-In-One Printer Logo
95 people viewed this question
Ben Johnson
