Question about Technics SL-PG480A CD Player
CD's come out distorted on the TECHNICS SL PG 580A
CD's which I burn come out distorted on the  technics SL PG 580A player.
This has happened since I got it serviced.
Commercial CD's play ok.
Can you recommend a brand of disc which will work?
    Genius:
  • 1,148 Answers
TRY NEW RCA JACKS AND TRY BLOWING IT OUT,,GET YOU A LASER LENS CLEANER
Posted on May 15, 2009
I have a technics SL-CH505 compact disc but it will not play burnt CD;s any suggestions my other technics SL PG 400A plays them noproblem
The Optical Pickup(laser) may be weak. It takes much more power to record than play, which I guess it works.
Oct 13, 2014 | Technics Audio Players & Recorders
I have a Technics CD changer SL-PD867 it will not play re writable disc's any other disc ok
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
May 11, 2014 | Technics SL-DZ1200 CD Player
I burned a CD on my PC to keep in my car and it plays OK in the car and on my PC, but does not play on my Technics SL-PD687 5 disc cd player. It's recorded in *.cda format and it's on a CD-RW. Any...
The problem with old CD Players are that they sometimes are a little fidgety when it comes to reading CDRs.
You could try burning a new CD on the lowest possible setting, say 2x or 4x.
Also try changing the CDR brand as some cheap CDRs are prone to not reading in old CD Drives.
Try using a regular CD-R (CD recordable - record only once) instead of a CD-RW (CD rewritable - rewrite multiple times). CD-RW use a different "ink" to write the data to the disc and can be re-recorded/erased a couple of times before it loses its ability to write effectively to it.
Mar 05, 2011 | Technics SL-PD687 5-Disc CD Changer
I need manual for Technics SL-PD687 CD Changer
i need a manual for the technics SL-PD687 cd player
Oct 09, 2010 | Technics SL-PD687 5-Disc CD Changer
Technics SL-PD888: Output signal is distorted/overdriven.
I can't find a manual. If it has both analog and digital outputs, compare both for sound quality and report the results. Also try them on different INputs of your electronics to eliminate that as a problem.
Let's examine THAT side, too. What are the components involved and how are they connected?
Feb 21, 2010 | Technics SL-PD888 5-Disc CD Changer
Does the Technics SL-MC6 play home made CD's? CD-R? CD-RW?
i've not come across a technics cd player yet that doesn't play cd-rs but they definatly don't play cd-rws.
Aug 02, 2009 | Technics SL-MC6 CD Player
When Making A CD To Play On My technics SL-PD8 It
If thhis happens quite often , and does not depend on the media, then it is usually a dirty lens problem. The lens is dirty or scratched and sometimes cannot read CD TOC (table of content).
If this happens only on reocrded CDs , try changing the media used. For example if you used +R, try with -R.
If this happens on all media, then try cleaning the lens with a lens cleaner CD or blowing some canned air on the lens.
See: CD and DVD Lens Cleaner...
May 02, 2009 | Technics SL-PD8 5-Disc CD Changer
Technics SL-PG480A CD Player Logo
283 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
