Question about E-Machines eMachines Desktop PC
Short but rapid beep code when powering up emachine
I'm trying to resurrect an eMachine T2882 with a Trigem Imperial GV 20030812 mobo. It worked last night but now when I boot, I get a long string of Short but continuous beep code. Does anyone know what this code is or where I can get the list of beep codes for this board?
    Sergeant:
    Champion:
  • 357 Answers
The beep code most likely is either video card or memory.
If you have a video card or can borrow one that you know it works try it first, if that doesn't resolve your issue try the memory.
You can take the memory out and have it tested to see if it is defective.
Go to this site and get the Beep Codes, http://www.computerhope.com/beep.htm
I hope this helps.
Good Luck.
Posted on Feb 26, 2009
Emachines Imperial GV 20030812 Motherboard manual
THE MOST EASY WAY TO CLEAR CMOS JUST REMOVE CMOS-
BATTERY FOR 10-20 SECONDS.IT LOOK LIKE A WATCH-BATTERY.BE CAREFULE WITH THE HOOKS.
Dec 03, 2013 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Where to find manual for motherboard 143159 imperial Gv 20030812?
Good luck. Used to be you could get a mobo manual from e4allupgraders.
The Imperial board is made by TriGem
Started out as TriGem Sambo, is now TG Sambo
The Imperial models were Imperial G, Imperial GL, Imperial GV, and Imperial GLVE, if memory serves.
TriGem Imperial GV - 143159 -20030812
http://www.ebay.com/itm/gateway-emachine-mother-board-imperial-gv-20030812-/111025938736?pt=Motherboards&hash=item19d9a96130
Bad photo, but it does have the mouse Zoom In feature.
CMOS jumper and Clear BIOS Password jumper, down by the Front Panel header; is the same as used on the TriGem Imperial GLVE -129504,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07540&lc=en&cc=us&product=83481
Scroll down to Motherboard Layout (Illustration), and Photo; then down to jumper info.
(By the way.........the BIOS chipset is removable, therefore replaceable)
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
This is PANEL in the illustration. Bottom/Right corner. Uses the same Front Panel pinout, as your Imperial GV uses.
8 pins along in a row.
Starting on the LEFT side going towards the Right;
Pins 1, 2, 3, NO pin 4, 5, 6, 7, and 8.
A) Pin 1 is N/C. Not Connected
(May not even be there for all I know)
B) Pins 2 and 3 are for the Power On LED.
Pin 3 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
C) There is NO Pin 4. At least that is what I make, looking at the Front Panel header pinout. Indicate Pin 1 is N/C, and Pin 4 is N/C.
D) Pins 5 and 6 are for the HarDDrive activity LED light.
Pin 5 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
E) Pins 7 and 8 are for the Power On switch.
HOWEVER, since the motherboard photo on HP Support, and Ebay; is as clear as mud; suggest you do this,
Connect your Power On switch to Pins 7 and 8;
OR,
touch across them briefly with a small flat tip screwdriver.
(Power plugged in)
See if that is correct for the Power On switch. What will happen if it isn't? Nothing. Pressing the Power On button just won't turn the computer on; is all.
Turned the Power Supply (Computer) on?
Good. We can assume the rest of the pinout is correct also.
Want to make sure? Easy.
Take an LED bulb (Power On, or HDD), and touch it's two wires to the Power On LED pins, in the Front panel header.
Stays on? Yep. Power On LED pins.
Blinks? Whoops.
Those are the Harddrive activity LED pins.
Just that easy to check it. With using an LED, you won't harm anything even if the pinout is wrong.
Moving on.........
Using the HP Support page, for that TriGem Imperial GLVE motherboard, the Motherboard Layout is the same as the Imperial GV.
(So is photo, 'natch)
Referring to the layout, and photo;
A) Power cables:
Two
20-pin ATX main power cable, and 4-pin ATX +12 Volt power cable.
General example of a 20-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Note* Color of power cable connector does NOT matter.
Can be Whitish, Yellowish, Black, Sea Foam Blue, or Lactating Mammary Gland Pink. (Made the last two up)
Goes to the motherboard connector immediately above PCI slot 1.
Note the LOCK on the side of the power cable, and corresponding TAB on the motherboard connector.
General example of 4-pin ATX +12 Volt power cable, and connector on motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Power for the Processor
Looking at the motherboard illustration, look at the Northbridge chip; -> Intel 845GL in the middle.
ATX 12V to the left, is where the 4-pin ATX +12 Volt power cable plugs in.
See the aluminum finned Heatsink, sitting on the Northbridge chip?
The whitish/yellowish 4-socket hole square connector, to the Left.
Moving on............
See where it states Primary IDE to the bottom/right in the illustration? Blue IDE connector?
That is where the Harddrive plugs in.
This is a general example of the connector,
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
Note the Locating Lug on the top/middle. This particular style uses two ribs. Some are just a solid block.
The reason I brought it up, is if there is NO Locating Lug on the connector; let me know in a Comment.
I'll tell you how to use the faint Red stripe, on the side of the flat cable; in order to plug it in correctly.
The optical drive (CD/DVD drive) plugs into Secondary IDE.
You can see where a Floppy Drive plugs in.
Above the Processor (CPU) socket to the Right, is where a computer case fan plugs in. PS_FAN.
To the upper Left, is where the Processor fan plugs in.
CPU_FAN
To the left of the ATX Power Connector, (20-pin ATX main power cable; motherboard connector), is the connector for the small audio cable; coming from the optical drive. (CD/DVD drive)
Optical Drive In.
Right next to the round CMOS battery, is the Front Panel USB header.
-> TWO USB ports connect to this header.
(USB)
A 4-pin Peripheral power cable is used for the Harddrive, and Optical Drive.
Misnomered as 'Molex' power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note the rounded corners. When plugging the power cable in, these rounded corners always go UP.
[Molex was the first maker of the power cable connector.
The name stuck.
Kind of like calling an adjustable open-end wrench a 'Crescent wrench' ]
The motherboard chipset is an Intel 845GV.
This is what Processors (CPU), and Ram Memory are supported,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Single-Core processors.
Use a Socket 478 processor socket.
Intel Pentium 4, Celeron, or Celeron D.
(Celeron D is NOT a dual core processor)
400 to 533MegaHertz Front Side Bus processor support.
(400/533MHz FSB)
DDR Sdram ram memory that is either 266MegaHertz, or 333MHz.
(PC2100 and PC2700, respectively)
2GB's of it.
1GB for EACH ram memory slot.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 08, 2013 | eMachines Mb, 143159 Imperial_gv 20030812...
I need display driver plz help me imperial 20030812 display drivers downloads
Hi, you can download the driver here:
http://support.gateway.com/us/en/emac/product/default.aspx?tab=2&modelId=1434
If not the right driver search by model and number.
The driver maybe needs to be unziped before installation.
Hope this will help you.
Mar 30, 2011 | E-Machines EMA IMPERIAL GV (845GV) TG3...
I put W 7 32 bit on imperial GV 20030812 but the resolution of the video is not good, can you help please with of controller?
Hi Good day!!! Try to upgrade your direct X click here http://www.microsoft.com/games/en-US/aboutGFW/pages/directx.aspx if still bad maybe your graphic hardware is not compatible for windows 7, by the way what operating system you use before you install windows 7?
Please reply if you have further problems i will assist you more
Thank you for using FixYa
Please accept if my solution helps you
Nov 10, 2010 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Front power switch broken. Bezel won't come off easily. Thought we could just get a switch and install on the back but don't know which of the colored pairs of wires go to the original switch in the...
I would suggest this generic Power On switch,
1) http://www.directron.com/atxswitch.html,
and the Red, and Black twisted pair of wires go to the Power On switch.
Your statement of ,"....don't know which of the colored pairs of wires go.....", leads me to believe you may have all of the Front Panel wires disconnected.
How about information as to where ALL the Front Panel wires go?
(Provided I have correctly interpreted your statement)
Back in the time that the eMachines T2542 was made, TriGem was the motherboard manufacturer.
The Model Name of the motherboard is Imperial, and the Model Number of the motherboard, could have been one of four variations offered.
Model Name: Imperial
Model numbers could be G, GL, GV, or GLVE
(Imperial G, Imperial GL, Imperial GV, or Imperial GLVE)
ALL four variations used the same Front Panel header.
(The connector on the motherboard the Front Panel wires connect to, is named the Front Panel header)
I would like you to view this page,
http://www.e4allupgraders.info/dir1/ecase/support/front_panel_header_support.shtml
Scroll down to the heading -
Trigem Imperial Front Panel Header Pinout.
A) Pins 1, 2, and 3 are for the Power On LED light.
B) Pins 5 and 6 are for the HarDDrive activity LED light.
(Pin 4 is not used. NC. No Connection)
C) Pins 7 and 8 are for the Power On switch
D) I wouldn't connect any wires to Pins 9 and 10, nor Pins 11 and 12
E) Pins 14 and 15 are for the Reset switch. (The button you press to restart your computer.
If the T2542 doesn't have a Reset switch, don't worry about it. There are many other ways to restart your computer)
F) Pins 17 18, and 20 are for an internal speaker.
This speaker is used for BIOS Beep Codes.
In the chart to the right, you will see GRD used many times.
GRD stands for Ground.
ANY Black wire in the twisted pair of wires, is a Ground wire.
Most of the eMachines I have worked on, use a Red, and Black pair of twisted wires for the Power On switch.
I could be mistaken on the T2542.
Best method, is to follow the color code of the wires that come from Pins 7 and 8, and be sure.
Aug 17, 2010 | E-Machines T2542 PC Desktop
Looking for manual to hook up power, reset,and leds on imperial gv 20030812 motherboard
Hello Laws 1957,
Here is a more or less universal pinout diagram for your motherboard. I sincerely hope this is in or was from an eMachine PC.
http://www.e4allupgraders.info/dir2/images/switches/imperialfntpanelom4.jpg
If I find anymore information for you I will be sure to post it. Good luck with this.
Jul 13, 2009 | Computers & Internet
EMACHINE T2642 W/ IMPERIAL GV20030812
Can you provide at bit more info?
You say it wont power up, are you getting any power through at all? DO the LEDs light up? Can you hear the noise of the fans etc powering on?
Mar 23, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
628 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
