Question about RTO Torque Horse Pro - Grade Pneumatic Nail/Staple Gun
The spring on my torq electric stapler has come loose
What
The spring that loads the staples for stapling broke in half where can I buy a new or used one
  1. Panasonic AS-300NN-A Panasonic Commercial Electric ...
    electricandbatteryofficestaplers.julietshop.tk/panasonic-as-300nn-a-panas...Mar 19, 2015 - Commercial-grade electric stapler with 25-sheet capacity features jam-free operation, auto-reverse, adjustable stapling position and LED status ...
Jul 11, 2015 | Panasonic As 300NN A Commercial Grade...
How do I reload staplers?
There are two basic designs of staplers. The most common type is the Swingline or Stanley Bowstitch types. At the business end of the stapler there is a small catch that you need to pull rearward and the front staple head will drop down. Inside, you will see a metal bar and a spring. Pull the spring back towards the rear of the stapler and insert a full clip of staples appropriate for your stapler. Release the spring slowly so the metal tab pushes against the staples... should be pointed tips down. Put the stapler on a firm surface and press it as you would when stapling something. The two parts of the stapler head will join back together again.
Apr 02, 2015 | Office Equipment & Supplies
How to put the spring back in the handle of Arrow T50 Stapler?
Ref. recocking the spring handle in your Arrow T 50 Stapler
1. secure the stapler in a vise. You need three hands to recock the handle spring.
2. Using a notched tack lifter hand tool, with one hand holding the handle so as to expose the spring, place the notched tool against the spring arm and force it to the rear. it will now be under tension.
3. Wiggle the handle into position so that you can quickly insert the clevis pin. Once secured, let go your handle that is now under tension. Replace clevis ring.
4. Dry fire to test.
Sep 18, 2014 | Arrow Staple T50 3/8"" Monel stainless...
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
Spring to stapler fell out
Hello, Go to this website for support phone numbers and too download manuals for this product. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Mar 03, 2014 | Stanley Black & Decker Bostitch 20SUITE...
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
My Swingline Stapler Model 51110 electric stapler no longer staples. The staples will not move forward and it just does "blank" stapling. Also, it goes off on it's own all the time running stapples...
I have the same issue; however, there is some resinous material that came out of it as a result of my trying to figure out why it wasn't stapling anymore. Anyone know where I can take it for repair?
Aug 05, 2010 | Office Equipment & Supplies
Instruction book for Arrow ETF50P staple gun . lost the instructions and can't figure out how to insert the staples in the gun
Look at the rear of the stapler. Push in then down on the stapler tensioner to release it from the rear of the gun. Slide the tensioner out. Next slide the new staples over the rail and into the gun with points down. Slide the spring tensioner back in and connect it to the stapler by maneuvering its clip down and then up.
Apr 19, 2010 | Arrow No.ETF50PBN Extra Heavy Duty...
Got a black and decker electric stapler given to me but no manual so can't find way to load it. It is a cat. no. 9700 stapler
Look at the back of the staple gun just under the electric cord and you will see a 1/2 loop of spring steel sticking up from the chrome base. Push it down lightly and toward the front of the stapler - when it is all the way forward lift the loop it while in the forward position and while up - draw it back and the will come out of the staple gun.
Sep 29, 2009 | Black & Decker Tools & Hardware - Others
Panosonic Electric Stapler does not staple paper!
It could be either jammed up with staples or the spring mechanism is shoddy.
Apr 14, 2009 | Office Equipment & Supplies
RTO Torque Horse Pro - Grade Pneumatic Nail/Staple Gun Logo
215 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
