Question about Aspire (ATX-AS500-BK) (atxas500bk) 500-Watt Power Supply
The power supply works and powers the board, but not the fans
The power supply works and power the board but the fans and the lioghts don't work. I need to be pointed in the right direction to fix them!
I ws hvin the same problem with the same config and atx 500wtts after replacing smps for nearly 4 times even new i used to face same problem later they tell me that i should should replace my faulty motherboard which was causin me the problem
Posted on Dec 28, 2009
My enermax power pack sparked out of the fan in the back and now my computer wont turn on. Not sure if it's the power pack or the board is fried... Any help would be appreciated thanks =)
if it sparked then something inside the power supply malfunctioned and that is the reason it wont work. You will need to replace it. Unlikely that it fried your board in the process. You can test this by swapping the power supply with one that you know works.
May 20, 2010 | Enermax EG301P-VB (eg301vb) Power Supply
Computer not working
Try to reseat the connectors on the mother board.
Feb 21, 2010 | NEC (190300) 235-Watt Power Supply
I have a T3626 emachine that I replaced the drive.
check all your ground screws on the motherboard. If that doesn't work try booting it up with out the hard drive. if that doesn't work, pop out the BIOS battery and unplug your computer, let it sit for about a min. and put the battery back in and restart.
Sep 18, 2009 | E-Machines Emachine T5026 power supply **...
I need to get my powwer supply to turn on without my motherboard.
well if u want see your fans working without connecting the power supply you can short the green wire (pin) with any ground (black) to see your fan work.....
use a pin or a piece of mettal to short green and black pins
Apr 07, 2009 | Computers & Internet
ATX Bestec 1956F Power Supply Failure
sounds like your power supplie has not been switched on by *********** board.the fan will not turn on until power supplie is turned on by mb.as far as what is wrong there are several things i can think of.i would try resetting bios. It sounds like your power supplie is working and your motherboard could have a short.but i have no way to be sure without testing. I can however tell you how to perform a test on your power supplie.unplug the 20 or 24 pin connector from your mb. look for a green wire,and then locate the grey one.short these two together(you can use a paper clip or something).if it dosnt power up. your power supplie is bad.also do not short any other wires,and only touch the grey and green for a few seconds as this is not how it was intended to be powered on.
Mar 03, 2009 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
Psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
Jan 27, 2009 | Antec Solution SL400 Power Supply
Power supply
angeldram3
as i think ur processor over heated. or processor can dos not work fine or heat sink not installed properly. remove heat sink, and use heat sink component (a whithe colour gel. u can buy it any computer accessories shop) use it top of ur processor then attached heat sink. and connect processor fan. before installing heat sink check processor fan. then cleare CMOS by removeing battery (because this problem also can happen wrong frequency setting in CMOS setting).
Jun 29, 2008 | Gateway Bestec ATX-300-12EB3 305w Power...
Aspire (ATX-AS500-BK) (atxas500bk) 500-Watt Power Supply Logo
112 people viewed this question
Top Aspire Computers & Internet Experts
meteshadow
Jax Planet
Jax Planet
Brian Sullivan
Brian Sullivan
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
