Question about Toastmaster 817 Brunch Pan
Toastmaster 817 brunch pan non stick pan stopped working
I had bought the brunch pan on a rummage sale and it worked fine at first. Then sometimes it wouldn't come on when I plugged it in and if you wiggled the cord it would start to work. It kept getting worse until finally we couldn't get it to work at all. My husband tried replacing the cord, but it still wouldn't work. I realize that it may not be repairable, but I also haven't been able to find this item in any stores. So if you are unable to give advice on how to fix it, can you let me know where I can purchase another?
Cord doesnt work where do I get a new one
The cost is usually; too high with shipping to replace a cord. You may be able to get it from a rummage sale. Getting replacement parts for electrical componets usually involves a ship from area somewhere in China. Stay safe and purchase a new frying pan on sale at target or kohl's.
Mar 19, 2015 | Kitchen Appliances - Others
I bought this cooker from a rummage and need a replacement part. who do i contact?
To contact us, please write to or call:
Attn: Repair Center P.O. Box 6916
708 South Missouri Street Columbia, MO 65205-6916
Macon, MO 63552 1(800) 947-3744
hopefully thats right. good luck
Jun 21, 2011 | Toastmaster TRC-5 5-Cup Rice Cooker
Pan does not heat- the thermistor is shot. need to replace the thermistor.Its the one who regulated heat.If it doesn't work it might been busted and needs replacement..
Jun 16, 2011 | Toastmaster 817 Brunch Pan
My toastmaster bread machine 1142, the bread sticks to the pan and the kneading tool gets lodged in the bread after it is baked. What can I do to prevent this or do I need to buy a new bread pan and...
The next time you make your bread use the same recipe but use 2 table spoons less liquid. Having the paddle come off in the bread is not abnormal. If the bread sticks to the pan again let me know Sometimes my paddles stay in the loaves sometimes they do not.
Mar 24, 2011 | Toastmaster 1142 Bread Maker
When using a toastmaster waffled maker do you have to use an oil or butter pan spray?
Normally you mix oil in with the batter, but this doesn't keep the waffles from sticking. Even non-stick waffle makers stick some. Use a light spray of Pam (or similar) on the bottom tray, add your batter than spray the top pan and close. This gives you your best shot at a perfect waffle!
Jan 17, 2011 | Toastmaster 217 Cool Touch Belgian Waffle...
Where in phx AZ may I find a toastmaster 805-7" handi pan pan
They are selling on ebay right now for about 40.00 plus shipping:
The seller clearly has several of these in stock, and started the price @ 25.00 several months ago. I bought a couple at this price, but he has since increase the price (as the market will bear) to 40.00. ~Anita
Sep 04, 2010 | Toastmaster 817 Brunch Pan
Bread stick in pan
I have the same problem too, I just use a plastic or silicone spatula, the kind that you use to scrape the cake mixture off the sides of the bowl, just use the thinnest one you can, I also try to loosen the bread loaf by moving the part that moves the blades, just move it a little, back and forth and try to shake your loaf out. I hope this works.
Jul 02, 2009 | Toastmaster 1193 Bread Maker
I bought a pack and play at a rummage sale and
Believe it or not, the rails will not lock unless the bottom is slightly raised up. Then you can flatten the bottom. Unlocking works the same way, be sure that the bottom is lifted up partially. Hope that helps, I had the same problem.
Jun 12, 2009 | Baby Gear
Toastmaster deluxe oven broiler
I bought a Toastmaster Deluxe Oven Broiler #5268 is it possible to get a instruction manual online?
Aug 08, 2008 | Toastmaster 328 Toaster Oven with...
Toastmaster 817 Brunch Pan Logo
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
