Question about RCA MM61110 61" Rear Projection Television
Schematic or service manual for a RCA MM61110 or MM52110?
I have a RCA model MM61110, 61" rear projection TV that will not power up. I suspect the HV powersupply section. Does anyone have the schematic and assembly print or a service manual for this TV that you could email me? I have the service manual for a Mitsubishi VS-45603, 50603, 50604 and VS-60603 that I would be happy to trade you if you are looking for them. The chassis number for the RCA set is MMC102G. My email address is bmcquitt2@yahoo.com.
Thanks for your time and any help....Bryan
5 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: RCA Projection TV MM52110 Won't Power Up
Being able to read a schematic and understanding how a TV works are two different things. These chassis that RCA used in these sets can be somewhat complex to troubleshoot. I would geuess that unless the power light comes on at all then you have a dead power supply in the TV.
Posted on Apr 15, 2007
Shuttle83
  • 1139 Answers
SOURCE: RCA Scenium HD52W140 smoked
Hello Here is a link to get the schematic for this set: http://www.servicemanuals.net/results.aspx?type=SM&brand=424&model=%20D52W20 Thank you
Posted on Sep 24, 2007
  • 1153 Answers
SOURCE: HD52W140YX!
Check first R14705 to see if burnt! If so then HV Trans is bad. Also if you need schematic try www.servicemanuals.net
Posted on Oct 08, 2007
  • 1030 Answers
SOURCE: OWNERS MANUAL FOR RCA
owners manuals or user guides are availble online at rca.com
Posted on Jan 18, 2008
SOURCE: rca rear projection p52960 no pic.....
where is the vertical ic in the chassis
Posted on Oct 01, 2008
Power supply sparks when tv is turned on
That can either be the Flyback or the HV splitter. The flyback is located on the lower left hand side when looking in the rear and has a large red cable coming out of its top. The HV splitter is located in the front in the center of the set. These are both very easy and inexspensive to replace. I can post a link where you can get replacements with instructions.If you would like.
May 08, 2009 | RCA D61W20 61" Rear Projection Television
RCA MM6110 The TV is on but I am not getting a picture.
Have you tried resetting the cable box by unplugging it for 5 sec. and plugging it back in? (power cable)
Aug 27, 2008 | RCA MM61110 61" Rear Projection Television
RCA MM61110 Problems
I took the back panel off and noticed that one of the cooling fans was not working..... apparently the computer tells the tv that it will not be able to cool. I cleaned things using air and basically followed the wires for the cooling fan and wiggled them... lol.. works fine now
Jun 09, 2008 | RCA MM61110 61" Rear Projection Television
RCA MM52110 FUSE REPLACEMENT
Check on the power supply box. Lower LH corner in back where the plug goes in. There is normally a small breaker switch on it.
Nov 30, 2007 | RCA MM52110 52" Rear Projection HDTV-Ready...
Clicking
thats the power supply trying to fire up but there is a fault.
Nov 15, 2007 | RCA MM61110 61" Rear Projection Television
RCA 61" Model P61960 stopped working
You have a flyback transformer and horz output transistor bad
Nov 04, 2007 | RCA P61960 61" Rear Projection Television
RCA MM61110 Television
I had the same problem sometimes when my Gold Plus would reset itself and include all the channels but only those Over-The-Air channels. The only way I could change the programming was to completely shut down the power. Not just turning the tv off but completely unplugging it from the wall outlet. When you turn your tv back on you'll be able to choose from Antenna/Cable option. As for Guide,if you don't want to use it, don't set it up, it won't effect anything else on the television.
Aug 08, 2007 | RCA MM61110 61" Rear Projection Television
Apr 14, 2007 | RCA MM52110 52" Rear Projection HDTV-Ready...
P61940 RCA TV does not turn on.
Get a schematic and trouble shoot the main power supply if you have solid state experience. If you dont , PLEASE call a trained TV tech to assist you in this repair.
Sep 04, 2006 | RCA P61940 61" Rear Projection Television
Rca 61 inch tv
that "pop" was the flyback transfor, a resistor, or a capacitor bloweing up. if your not a technician this is considered a circuit repair and ther are no serviceable parts inside this set for you to replace without the proper tools , service manuals, and schematic diagram. Sorry man your gonna need a serfvice pro to help ya with this repair. Good Luck
May 24, 2006 | RCA P61927 61" Rear Projection Television
RCA MM61110 61" Rear Projection Television Logo
153 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
