Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
My fax says 10.1000 supply memory error
How do I correct this?
  • Anonymous May 06, 2009
    same problem
  • drgify May 10, 2009
    Hi ! I have the same problem, with the same HP M1522NF printer.
    Can anybody tell, what does it mean, and haw can i solve it ?
    ThanX lot !
Get the toner out. If there is an orange tab on the left side, remove it and put it back in. Now it should say that you have genuine HP toner--woo!
Posted on Jul 28, 2010
  • 3 Answers
I understand that "10.1000 supply memory error" means that the machine has detected that the toner being used is not a HP original. But what I bought and used was a 100% genuine HP toner - it came with a HP box and reward sticker and all. Well??? Any clues???
Posted on Nov 04, 2009
2 Suggested Answers
seeker5211
  • 1089 Answers
SOURCE: Printer is displaying the following
There is a chip on the toner cartridge that feeds info to the printer regarding the status of the cartridge. Either the chip is bad or the cartridge was replaced with the chip missing.. Try reseating the cartridge and then power cycle the printer. If the error persists, replace the cartridge
Posted on Sep 23, 2011
What is 10,1000 supply memory error with hp
10.1000 Supply Memory Error
A specific print cartridge has a missing elabel.
Reinstall the print cartridge.
Turn off and then turn on the product.
If the problem is not solved, replace the cartridge.
Jul 21, 2011 | HP LaserJet M1522nf Multifunction Printer...
Display fax gives a warning "received in memory" we also have a warning "prepare black toner" We can not print the fax! What can we do?
Generally the "received in memory" message is a result of the machines inability to print. I.E. It received a fax, attempted to print it, failed, and then stored it in memory to print once the issue has been corrected.
The Prepare Black Toner error is likely directly related. If the toner cartridge is empty, inserted incorrectly, or damaged it could be causing this error. Try reseating the cartridge by removing and reinserting. If that doesn't clear the error try replacing it with a new Canon branded cartridge.
As soon as you correct the printing issue the stored faxes will print.
May 03, 2011 | Canon MF8180C Color Laser MFC Printer
I am getting error: 10,1000 supply memory error reinstall
You are using re manufactured toner and it has a bad chip. Replace the toner.
Jul 06, 2010 | HP Laserjet CM2320nf All-In-One Color...
I'm getting an error mesage: ECM error on my Sharp AR-M207 fax machine. How can I fix it?
ECM (Error Correction Mode) is a feature common in most fax machines today. It helps to minimize errors while transmitting faxes over noisy phone lines.
1) Be sure you have the latest version of the drivers installed
2) Turn the fax off, then unplug for 10 minutes, turn on and try again. This should clear up anything in the printer/fax memory
3) Check if your phone line is unsually noisy when you tried to send the fax(es) that gave you the error message. If this is the case, a sucessful fax transmission will be almost impossible. You may have a faulty phone line or an improper installation. Either of these two should be fixed by your phone company. Also, most phoen companies can test your phone line (for fre) remotely to check for abnormally high noise levels.
Please, report back if you need further assistance.
My ID: alexocuello_
Mar 31, 2010 | Office Equipment & Supplies
HOW TO PRINT DOCS FROM PRINTER MEMORY
The printer doesn't save anything in memory except faxes that come in while paper or toner is empty. Once the error is corrected they will print. Otherwise you step thru the fax menu and see if there are faxes in memory.
Jan 07, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Minolta Fax 3600
Yeah, pretty much s(****). That message means the polygon mirror in the laser unit is not spinning up.
If you want to try to fix it, it's a square black box under the top covers. You can take it apart and oil the mirror shaft.
Sep 07, 2008 | Office Equipment & Supplies
Need fax out of memory
There is no direct means of recovering a lost fax, but unplugging the machine and reseating the power supply will restore normal operation. An error report will be printed and provide information about the lost fax, which may allow the user to contact the sender and request that the fax be sent again.
Aug 04, 2008 | Lexmark X5470 All-In-One InkJet Printer
Hi, Remote Fax Error being displayed
As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX mode.
Press Select.
Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
Change the setting from Yes to No using the + (right arrow) button.
Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
Press Select.
Press Options 10 times until MAX SEND SPEED appears on the LCD display.
Change it to 9600 BPS using the - (left arrow) button.
Press Select.
Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
Press Select.
Press Options 11 times until ERROR CORRECTION appears on the LCD display.
Change the setting from On to Off using the + (right arrow) button.
Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes. The X6100 Series only supports 1-D MH encoding with the error correction. Fax transmissions without ECM and other ECM types can result in bad quality on the received page.
Dec 19, 2007 | Lexmark X5470 All-In-One InkJet Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
4,981 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
