Question about Canon Office Equipment & Supplies
CANON IR 2016J is showing DOWNLOAD 7701
The board of my machine is showing the Code 7701 and since then it can't operate.
5 Suggested Answers
TMurdock
  • 93 Answers
SOURCE: download standby,CANON IR 2016jphotocopy machine
If you haven't done anything to the machine and it powered on with this message then the firmware has gotten corrupted. You will need to have a service tech come or take it to a Canon dealership to have the machine flashed so it will come back to ready.
Can only be done by Canon certified tech, files aren't avail to public, sorry
TankMurdock
Posted on Apr 23, 2009
SOURCE: my canon copier ir 2016j give an eror report code
- check the connector of the fixing film sensor.
- replace the fixing film sensor.
- check that the fixing film is not broken or out of place
Posted on Nov 25, 2009
  • 82 Answers
SOURCE: when i start canon photocopier ir-2016j , its
Your machine appears to think it's waiting for a file (like an update). Somehow it was put into download mode (only a canon tech would know how to). You need to have a canon technician to either reset the machine or if there is a legitimate problem put it into factory default.
It may be a hard drive error from my experience.
Posted on Nov 29, 2009
  • 78 Answers
SOURCE: no power in iR 2016J
order a new one
Posted on Nov 30, 2009
canontech
  • 1219 Answers
SOURCE: computer doesn't detect the CANON IR-2016J
the ir 2016 J cant be used as a printer without network function wich is optional. USB port is only for system software upload on these model.
Posted on Jul 29, 2010
I want canon ir 2016j photocopy machine drivers
Amanuel Getachew.
I want to add in Chris coughlin's suggestions. maybe check this parts
Laser motor, DC controller, ( Developer Fan or other Fan on IR series ), Bad fan, DCcontroller or image processor board
good luck!
Jul 30, 2012 | Canon iR 2016i Black and White Copier
In canon ir 2016 there is no scanner movement & also the laser lamp is not glowing & the machine is indicating check document
In canon IR 2016j, if you get error " check document", its a communication error. so you check the flat cables in control board ( is a board in the scanning section)
* Change cable from scanning lamp
* change 2 cables from ip board.
Jun 12, 2012 | Office Equipment & Supplies
My conan copier ir2116j hase error download standby
downlod stand by of canan photo copy machine ir 2016j
Mar 03, 2011 | Canon iR 2016i Black and White Copier
Canon ir2016 photocopy machine printer software
i want to get the Canon ir 2016j photocopy machine drivers
Oct 20, 2010 | Computers & Internet
When i start canon photocopier ir-2016j , its shows error download standby
Nov 25, 2009 | Canon iR 2016i Black and White Copier
Technical support
I gave an answer to a problem like this, i hope you can actually uderstand it cause the other guy seemed to not know what i meant,.
If your machine stops the starting sequence as regular but then it shows the download message the only solution you can try is to reinstall the operating system to the copier.
you will need the correct Copier's operating system, a laptop, a cross-over ethernet cable and ready to proceed.
the bad news is that the OS is only given to canon authorized service centers, so in other words you are gonna have to call them. sorry.
if that doesnt work out then you may have to buy new pcb boards.
Nov 22, 2008 | Office Equipment & Supplies
114 people viewed this question
old marine
old marine
Corne Viljoen
