Question about HP M2727NF Laserjet Printer
Laser M2727 making lines on copies. The glass is
Laser M2727 making lines on copies. The glass is clean. Have been making lots of copies on envelopes. Could this have damaged the print cartridge?
  • mdespain38 Apr 22, 2009
    When making copies there is a dark black line down each copy. It only appears when you put the originals through the feeder. If you lay the original on the glass to copy - no line.
  • raym01 May 22, 2009
    same problem only I have 2 vertical lines that appear down the center of the paper whenever I use the feeder
  • 3 Answers
Lift up the lid on top and clean the smaller glass on the lefthandside of the big glass.
Posted on Aug 05, 2012
Clean a feeder or replace one or more damaged light diods.
Posted on Aug 06, 2009
A vertical black line appear on each paper when the document feeder is used to make copies; such vertical line does not appear on papers when copying on the glass surface. How do I resolve this...?
when you open the copier platen cover, left of the copy glass, there is small narrow glass, which is used when you make copies from ADF. Over that glass is plastic protective sheet. Remove it and clean, also clean the glass. Use glass detergent and after cleaning dry it!
Even the smallest dirt can cause lines!
Hope that helps!
Apr 25, 2011 | Canon ImageCLASS MF4370dn Laser All-in-One...
B&w 6800 lots of horizontal black line areas. also, a vertical white strip about 3/4 inch wide about 3 inches from left side of paper
Hi!
the best thing is to make a copy using the glass and not the document feeder!If there is no lines on the copy simply lift up the cover and on the left side of the glass will be a thin strip of glass,Clean it with a dampened cloth and all line and marks should be gone1
Good Luck!
Apr 02, 2011 | Brother MFC 6800 All-In-One Laser Printer
When I send a fax the person receiving on the other end
TRY MAKING A "COPY" ON YOUR OWN MACHINE.
IF YOU GET DIRTY LINES ON YOUR COPIES AS WELL....OPEN THE adf AND CLEAN THE NARROW GLASS UNDERNEATH.
May 10, 2010 | Brother IntelliFAX 4100 Laser Fax
Vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Jun 01, 2009 | Brother MFC-7820N All-In-One Laser Printer
Line when we fax or make copies from the top feed
clean the narrow strip of glass to the left of the large glass.
razors
Apr 10, 2009 | Brother MFC-9420CN All-In-One Laser...
SOLID VERTICAL LINE ON AUTO FEEDER COPIES
Hi Sally,
Open the flatbed lid and look on the left side, I believe there is the flatbed glass and another piece of glass to the left, the small strip of glass is the one used for the automatic document feeder. this piece af glass needs to be clean or you will get a line from top to bottom from any type of speck on the glass. hope this helps... if so please mark as FIXYA!!
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Lines on making copies
clean the glass of the scanning area, a small dot of debris on the glass produces a vertical line from top to bottom in the feeding direction of the laser printer.
May 07, 2008 | HP LaserJet 3055 All-In-One Printer
Vertical lines
1st print a report, can you see the lines? Then either the drum is faulty or the laser scanner is. If the lines are not present when printing a report, make a copy and see then if the lines appear. If so, the scanner is faulty. Try cleaning the glass with glass cleaner. However, blank lines mean that bits are missing from the scanner itself and the scanner will need to be replaced.
Feb 27, 2008 | Brother IntelliFax-2820 Laser Fax
Canon Imageclass D780
Clean the platen glass and make sure the isn't any debris or ink on it, especially by the roller. If you make a copy thru the ADF while the ink is still wet it will deposit on the glass.
Jan 08, 2007 | Canon imageCLASS D780 All-In-One Laser...
HP M2727NF Laserjet Printer Logo
495 people viewed this question
Ben Johnson
