Question about Plumbing
Saniflow system motor pump sometimes not work
The motor only goes round if i give it a little push with pipe when the water is at fill level
  • 104 Answers
The pump is either bound up with lots of friction. ( Check with the motor off if the pump is easy to turn by hand, not with a lever. If you can turn it at all by hand it is not bound up.
The the problem is electrical. If this is a 220V pump, check to see that both circuit braeakers are ok. If so, call a service man familiar with the pump to further check the starter if equipped and the motor.
Good luck
Posted on Mar 19, 2009
Fisher and Paykel top loader washing machine, won't stop filling up with cold water
The pressure switch usually has air in the feed pipe which sometimes gets water into it which then fails to notify the system when to switch off water supply which then prevents the relay to the motor to start.check the feed pipe so it is empty of any water.this will allow the pressure switch to work properly.if the switch has failed you can get replacement part from eBay.
Dec 05, 2014 | Fisher and Paykel Washing Machines
Pump randomly runs
This problem maybe caused by a slight weep of water from the cistern the saniflow has a sensitive float system , once level is reached the unit will turn on until required level is acheaved again . So check toilet bowl to see if the is a trickle of water if so you need to take a look at the flush system in your cistern.
Here is a nice link for your saniflow maintenance.
Nov 17, 2012 | Saniflo & Saniplus& Macerator Pump
When the water is entering the tub it immediately goes out the outflow. The tub will not even fill up a little bit. What could be the problem? thanks
The drain hose outlet must be located higher that any expected water level in the tub. If too low, gravity drains the tub as it is filled. Extend the (a) drain pipe up to the proper level, even if you are using a floor drain to carry away the water. Hope this helps!
Jan 27, 2011 | GE WDSR2080D Top Load Washer
I have a saniflo toilet installed in my attic. The pipe runs accross under the roof and is connected to the sewerage pipe for the bathroom on the first floor. What toilet paper should I - use -2-ply or...
Any brand approved for septic should work well in the saniflow system, but the key is to use as little as reasonably possible and flush as you go. Big wads of any type will compromise the system.
Oct 03, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflow not pumping the water away only back through the pan and pipes are clear
under the backflow valve there is a rubber connection piece check for cracks mine did same there was a crack in it letting water blow right back in tank mine was lot louder than normal also i replaced and it went back to working fine
Aug 27, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Hi. I have a saniflow macerator,it's servicing just the toilet. I installed it about 9 months ago. I have had no problems untill this morning. It is making a clunking noise, the pump is working as normal,...
Hi Neil,
The pump is activated by a pressure switch inside the unit and would not normally make any noise, so probably can rule that one out!
From the manual on the saniflo it would suggest either a foreign object in the unit, a defective motor or control unit. It may be that you are unlucky and have a loose macerator blade that needs to be tightened (and loctite applied).
I would double check that the clunking is definitely coming from inside the unit and not a pipe or something else moving (the water pushing the 90 degree rubber discharge tends to move and can create movement around it). When you are sure, it will be the not so nice job of opening up the unit:
FIRST .. RUN THROUGH CLEAN WATER (will make sense later!)
- Empty the Cistern, bowl and disconnect the inlet pipes to the WC
- remove the WC and cistern
- being very careful, disconnect the outlet (some have non return valves, some don't, so you may get some sludge coming back down the pipe). Hopefully none if you pushed enough clean water through initially
get unit out and wear rubber gloves to protect your hands from getting germs in cuts etc. Normally need a star driver and flat blade screwdriver
If it is the macerator blade it should be clear that it is loose and could be tightened up. It could be play in the motor which unfortunately would mean a new unit - to test, gently pull up on macerator blade and feel for movement vertically.
also check for any foreign objects etc.
While it is out you may as well clean it out - I normally do this outside by putting warm bleached water into the unit for around 30mins, swishing it about and then emptying down a drain (cover up the mains cables in a plastic food bag first!). I also sometimes use a hose pipe to really get into all of the nooks.
Good luck with the fix, if this helps pls leave feedback, if not let me know and I'll try and help some more
Jan 26, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
How can you tell if the waste pipe is blocked on a saniflow toile
Yes the bowl will be slow to empty. Try squeezing the white discharge hose as the unit operates, if there is a blockage then this hose will be hard to squeeze. If hose is soft then blockage could be in the toilet pan U-bend in which case fill bowl with very hot water and leave to soften the toilet paper.
Jan 11, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Water leaking out of breather
I have a question, I have a saniplus no problems hooking it up filled the tank and then flushed it..On the discharge end I had a small about of water puddling up at the pressed in rubber fitting. Every clamp was tight not sure what the reason is any ideas. I thought about silcone around the rubbber seal between the lid.
Sep 08, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflow saniplus has stopped pumping water i think- the toilet and bath has filled up with waste water. i have taken the top off the saniflo and blades are working fine but they keep going because the...
We had that problem but the unit was built in and I could not get at it, the outlet pipe sounds like it is blocked, I cleared mine by connecting a pipe from the cold tap to the outlet pipe and flushing.
May 11, 2009 | Saniflo & Saniplus& Macerator Pump
Plumbing Logo
136 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
