Blinking yellow power button. T.V. Does not turn on.
SOURCE: vizio 32 does not turn on
The tv not not power 0n dead set,1 ic blown out stby sw,how I can fix the board.Thank you.
SOURCE: I have a Vizio hdtv 32
I would guess the power supply went bad. The Vizio parts store sells the replacement for $82. Cheap fix for a decent TV.
Replacing it only requires a moderate mechanical skill. Removing the screws from the case is the hardest part. Remember to unplug the TV before you attempt this repair, or contact a local repair shop. They may only charge a small fee to install it for you.
Testimonial: "Thanks I thought that might be the problem.... Do you have a web address for the vizio parts store?"
HI USUBen,
I do not know exactly what is wrong with your TV. I did study the manual and of course it wa no help. I did run across the last page where it said something akin to" Our professional Technicians can probably solve your probalem over the phone and save you a bundle on Shipping". So i say to you USUBen, Give calling Vizio a chance. Heres the number.
After much research, here is a
step-by-step for getting your Vizio Soundbar to work with the Comcast remote
using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144
(2 blinks)
Aux - Setup (2 blinks) - 994 -
Setup - 00169 - Vol Up - Should get 2 blinks
Setup - 00168 - Vol Down - Should get 2 blinks
Setup - 00037 - Mute - Should get 2 blinks
Setup - 00165 - Power - Should get 2 blinks
Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use
them:
Setup - 00036 - <button to use for TVOL> - Should get 2 blinks
Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on
the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
