Question about Gateway MX3215 Notebook
I have a Gateway MX3215. The wireless connection won't read my Linxsys router but if I hard wire it to my computer it works. I originally had XP and upgraded it to Vista. The wireless connection was working for awhile but when I go into my device manager under network adapters both mass storage and PCI have a exclamation mark on them. I've tried resetting the winsock and still nothing happens.
  • 447 Answers
The Gateway site only lists the XP drivers for your machine so let's see if we can do some cross referencing:
Your wireless device should be a Broadcom. This link is for downloading the generic drivers for Vista.
The mass storage controller is a card reader. Try this download from Gateway (from a slightly different notebook model) to see if it's compatible.
The PCI device is kind of an odd one but it may be your audio card. Most likely the driver is an AC97 Realtek. Download the driver here.
Post your results back here to let us know if you need more assistance.
Posted on Feb 26, 2009
  • 46 Answers
You should check for updated drivers for the wireless NIC device. Gateway may have them available, but no guarantees. Did you do a compatibility check befiore installing Vista? It would have shown you what if any devices, and software were not compatible with vista before install. Try get as much info about the wireless device you can, and do a web search for known issues and solutions also. You may find others have had the same problem and a workaround.
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
I have a belkin g router. I am able to connect hard wire but not wirelessly. Not sure if i am missing a step. I tried rebooting the router and reinstalling it......no luck.
were you able to connect to that router before? If not then do the manual checking of wireless settings, get you default gateway ..how? http://www.ehow.com/how_2091470_computer-ip-address-windows.html instead of looking for Ip address .. look for default gateway it should be after subnetmask or if you havent change any settings on your router if the default gateway should be :192.168.2.1 -then open any of your browser like internet explorer or Firefox and type in the default gateway in the address bar (make sure during these steps your computer is currently connected to the router hardwired) -Do the wireless settings, here's how: http://en-us-support.belkin.com/app/answers/detail/a_id/3774/related/1/session/L2F2LzEvdGltZS8xMzA5ODU1NTc5L3NpZC84a1NuZ2N5aw%3D%3Da also what is your OS is it XP or windows 7, as well as check you wireless capability on your computer if it is ready for wireless connection...
Jul 04, 2011 | Belkin (F5D7633UK4A) Wireless Router
I had to format the hard drive and reinstall Windows XP. It not works but it will not find the wifi. The light comes on but no connection. I don't have a recovery disk. Can you help?
May be your driver for the Wireless device is not installed, you can download the Wireless driver for your model from here (Under the Network Category)
Regards, Waqar.
Oct 05, 2009 | Gateway MX3215 Notebook
So how is the other computer supposed to work on the internet, if this wireless router is hooked up with the current modem? If I need another part, then why did I spend $150, and not get all I needed??
Before you bought the wireless router, you probably had one computer directly hooked up to the modem (the box you got from your internet provider). The wireless router should have come with a cable similar to the one that had previously connected the modem to your computer.
When you use a router, the original cable from the modem is disconnected from the back of your computer and is instead plugged into the INPUT of your router. The cable that came with the router is then plugged in to the original computer.
So far, so good.
Now, when you want to add additional computers to the internet, you can do it in two ways: either wirelessly (which means the other computers need to have wireless capability already built in - which is the case with laptop and notebook computers, or they have to have a wireless card installed); or you have to purchase another cable (like the one that came with your router) to directly connect the other computer to the router.
The only time an additional cost would be involved is if you needed to purchase another cable (for a direct connection), or if your other computer doesn't have wireless capability.
Does that answer your question?
Jul 07, 2009 | Linksys WRTP54G-NA Wireless G Broadband...
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
I have a network and wireless issue needs to be fixed
First thing to do is make sure they are all in the same workgroup and that all three have identical user accounts and passwords.
Once you've done that, make sure all of them have sharing enabled for the areas you want to share of each drive.
This should do it. Let us know if you need further assistance.
Jun 18, 2009 | Gateway MX3215 Notebook
Slowed internet connection using wireless router...
Normal!
Wired connections are faster than equivalently wireless connections (from/to the same node) and so your
experienced is quite normal.
Additional nodes divide the original bandwidth and denigrate the performance, which is why one tries to
maximize the original bandwidth (speed in MHz) of the connection to the gateway.
You can maximize your experience by having critical systems wired to the router, and this also provides
greater security than any encryption (which is another brake on your speed) necessary for a wifi
connection.
Make sure you have the fastest possible wifi card in your portable devices to maximize your speed.
Apr 10, 2009 | Linksys Wireless-G WRT54G Router
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Plug in power cord and push power button, nothing comes on
Yup Yup I had the 28, same problem, the issue is within the adapter plug itself, I ended up taking my laptop apart and hard wiring the the connections directly into the wires that came off the plug, it was the only way to solve the issue without ordering the part from gateway,,,this is a image of the device that is causing you this misery.
t
http://cgi.ebay.com/DC-Power-Jack-For-Gateway-MX3212-MX3215-MX3225-MX3228_W0QQitemZ330288544158QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item330288544158&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Nov 21, 2008 | Gateway MX3215 Notebook
Linxsys wireless modem
Is it working if a computer is wired to the router?
Jun 09, 2008 | Linksys Wireless-G WRT54G Router
Gateway MX3215 Notebook Logo
399 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
