Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Do i have it hooked up correctly
I have a frigideaire side by side and the water is hooked up but no water or ice are coming out. what tubes go were. i can here the motor working but nothing.
  • 520 Answers
If you have the line connected to the rear of frig. and the valve is on with no leaks you do have it hooked up properly. The water has to go through a series of solenoids and about forty or fifty feet of tubing before it reaches the door. This process takes a bit.Hold a glass under the water fill spout and press it in. If you can hear the sound then all you need to do now is wait. continue to hold the button until water comes out. dispose of the first few glasses of water and the first few drops of ice. this will allow the system to be flushed of all contaminants. Note that when an ice maker is new or not used much it will not make very fast. it usually takes about 24 hours to make the first drop. Hope this helps and good luck.
Posted on May 07, 2009
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Sep 14, 2011 | Kenmore Side by Side Refrigerator
Ice maker is not working
If I understand the problem correctly, it sounds like there is ice frozen in the tube that the water flows through just before it comes into the ice maker. If this is the case, I have the solution.
This problem is caused from a bad water valve. The water line that connects to your refrigerator hooks up directly into your water valve. The way it works is this. The water valve keeps the water pressure to OFF. Whenever your ice maker needs water it simply asks the valve to open and it does. The problem is this. The valve has malfunctioned and isn't totally shutting off anymore. This lets a tiny bit of water through. This water slowly makes its way up the water line into the freezer where it freezes in your tube :) You just need a water valve! With a model number I can give you an average price. Chances are it will run anywhere from $50 - $100. Just depends on where you get it. This is also a very easy thing to change!
Jun 02, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
GE PSS25MGMA Crushed ice only, nothing else will select on panel.
Yes , replace the main board . Part number WR55X10656 . There is only partial communication between the main board and the dispensor board . This main board , is behind the 8 " X 10 " panel , on the back of the refrig . Do not replace the dispensor board . I have never come across a bad dispensor board yet . Always a first time though .
Sep 27, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Maytag Icemaker freezing up
Possibly a bad valve but more likely not enough water coming to the unit,follow the water line from the back of the unit to where it hooks to the pipes there is usually a little saddle valve there,try closing it all the way and then open it back up check the water through the door and see if the pressure doesn't improve.
 You can also remove the Ice maker clear out the fill tube and sit a cup under the end of it for a day or two if you get water in the cup and Ice in the tube you probably have a solenoid valve that isn't closing completely.
Aug 31, 2009 | Maytag Freezers
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Hooked up waterline to side by side frigiedaire,
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 12, 2009 | Frigidaire GLRS264ZA Side by Side...
The ice maker doesnt work, and in the day several times appears water in the floor, in the side of the door of the ice maker
Uplug refrigerator and remove the ice maker so we can look at the tube that comes into the back of the ice maker. It maybe the ice maker is calling for water but ice or a crack in the tube that delivers the water is being deverted to inside the freezer area. Also look behind the fresh food compartment door and see if you can send me the model number so I will be able to go over the correct model. Let me know, Thanks, Sea Breeze
May 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I just bought a side by side and i hooked up the universal copper tubing for the water and ice and it is leaking. Also there is rolled up plastic tubing in the back of the fridge part and do i have to hook...
the roll of tubing is a storage place to keep cold water before itcomes out the door you just need to hook up the tubing in the rear then bleed the lines thru the door using the water in glass option and get the leak fixed
Jan 08, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire SBS
reach into the ice maker hook the ejector blades with a finger and pull them up a little you will hear a ratchet sound then watch them go around and listen for the fill valve before they stop let me know what happens
Jan 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
