Question about Nikon Speedlight SB-600 TTL Flash
Too many flashes
Why doe the SB-600 flash fire three pre flashes before the photo gets taken? This only seems to happen on manual mode. Also the battery closing clip on the flash seems to be messing around, because the flash will just go off at times, only to come back on after pressure has been applies to the battery clip.
I am doing a school function in 2 days and I need help ASAP!?
  • 1 more comment
  • mego_g Mar 11, 2009
    I have the same problem as above. I have tried everything and I'm completely confused.
  • David Shaub May 11, 2010
    The 3 flashes is to eliminate red eye. The clip I can't help you with.
  • Richard Evans
    Richard Evans May 11, 2010
    I do not see a time stamp on this ...but if you need help send me an email at evansphoto@yahoo.com if you need help I will check it later tonite and see if I can help you thru this.
    Problem Solver:
  • 8 Answers
Its the red eye setting in your camera you need to read the manuel and find the menu setting to change it
Posted on Mar 20, 2009
D90-Sb600 help
The on-camera flash has to flash if you want it to be in commander mode. That's how it sends commands to slave flashes. Set to "--", that's all it does, the flash will not affect the picture.
If you want to operate remote flashes without any flash from the camera, you'll need to invest in a third-party wireless commander and triggers.
Apr 03, 2010 | Nikon Speedlight SB-600 TTL Flash
Underexposure with Nikon SB-600 flash
1 - Make sure you don't have your diffuser screen pulled down. This is easy to overlook and will produce that effect.
2 - Reset your flash - hold down the "Mode" and "On/off" button together for a few seconds. This gets you out of any funky mode you could have accidently put yourself in
3 - Put camera in fully auto mode. That clears any weird modes you could have gotten into there
4 - Clean the contacts on the flash and camera. I use a pencil eraser and wipe with alcohol and paper towel. Dirty contacts can cause flash misfire or cause full flash during the preflash mode, which gives you dim or dark photos or sporatic flash operation.
Mar 07, 2010 | Nikon Speedlight SB-600 TTL Flash
I have a new D3000 and a nikon SB-600 flash. I
From the Nikon site, do you have one of these flash units.
Support for the Nikon Creative Lighting System when using SB-900, SB-600, or SB-400 Speedlights, or the SU-800 Wireless Speedlight Commander
If so You set the flash mode to "comander" the pop up flash must be UP
This Video by Nikon shows how but you will have to read the manual to get a full description go to the flash section http://www.nikondigitutor.com/eng/d300s/index.html
Then look at them all :)
Jan 21, 2010 | Nikon D3000 Digital Camera
The flash is not in sync with my nikon d40 anymore. It fires first. Pictures come out dark. The camera itself takes great flash pictures
It sounds like you're trying to use the SB-600 off camera, as a slave flash. While the SB-600 does indeed have slave capability, the D40 does not have the ability to function as a commander. Thus, the SB-600 is being triggered by the D40's pre-flash.
As stated above, the D40 does not function in commander mode. You can mount an SB-800 or SB-900 flash unit, which will function as a commander as well as a flash. Or you can mount an SU-800 commander unit.
Alternatively, you can switch the D40 to manual flash mode so as to eliminiate the preflash. However, you will then have to calculate the proper exposure yourself.
Dec 31, 2009 | Nikon Speedlight SB-600 TTL Flash
Using SB 800 flash Master with 2 SB 600 as slave
Hi Frank, I use the same combination of the exact three flashguns you have. Works beautifully. I mount the sb-800 on my camera and set it to Master Mode (press and hold the center button till the menu comes up, select the master). Set the other two sb600s as slave. Please make sure the channel is set the same in all three flashes... when positioning the slave flashes, make sure that sensors on the remote will recieve the light from the main flash. For maximum coverage I use the sb-800 with a diffuser in bounce mode. You will be amazed at the quality of interior phots you can get with a 3 flash combo.
Apr 18, 2009 | Nikon Speedlight SB-800 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Too many flashes and than nothing
    just turn off red eye reduction (it fires 3 preflashes) and it will only fire once
    Feb 26, 2009 | Nikon Speedlight SB-600 TTL Flash
    SB 600 Flash pre fire
    The only thing I could think of is that when you use the red-eye on the camera or flash it will flash several times before taking a shot.
    Apr 01, 2008 | Nikon Speedlight SB-600 TTL Flash
    Sb 600 under exposure.
    You probably haven't changed the camera and/or flash back to TTL mode from wireless mode.  Make sure they are both set to TTL, not commander mode and you should be fine.  Note that the LCD on the flash will indicate which mode it is with a little graphic.  On the D70 you had to switch between TTL and Commander mode to set it up to work using the built in flash as the commander, so you just have to switch back.
    Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
    Nikon Speedlight SB-600 TTL Flash Logo
    206 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Ric Donato
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
