Question about Abit KT7A Motherboard
Changing processor results in windows xp pro failing to install
I'm building up a computer for my friends kids with old hand me downs and i took a AMD duron 1000mhz cpu out of a Abit KT7 motherboard and put it into a Abit KT7A motherboard that had a AMD Athlon 750mhz cpu in it. problem is when i try installing windows xp pro sp3 it fails every time to install with various copy errors when windows performs first task of copying files, but it always fails on copying SHELL32. DLL but if i hit retry every failed copy works but later on in installation windows installation fails!!! ive resorted back to the 750mhz cpu (originally in motherboard) and installation of xp pro installs fine... Any help/tips would be greatful as its baffled me.
  • eddynoneck Mar 28, 2009
    i upgraded bios but no luck. i even installed windows xp pro using the 750 mhz processor then put in the 1000mhz processor but it kept on crasing the system at various points when in windows so i gave up and put the 750 mhz processor back. i was going to take the bois that was on the older kt7 board (doesnt have raid) and put it in the raid board but i had enough and settled on just running the 750 mhz instead. i sort of think it could be the bios as read somewhere that the duron runs at 2.2 v and ther atherlon at 5v so new bios is geared for atherlons 5v so maybe my 1000mhz duron was getting 5v supply as instucted by updated bios. will always be a mystery because at end of dat the system is so old it not worth all the hassel. lol
    ps sorry for late reply
    Scholar:
  • 116 Answers
Sounds like the 1000mhz processor either overheated at some point and was damaged, or its trying to run on a different bus speed.
Copy errors (random) normally point to bad ram. But being that it works fine with the other CPU, you can only have 2 possible problems :)
A bios upgrade may fix the bus issue, and a hammer will fix the damaged cpu issue. (Ok, so you'll feel better)
Posted on Feb 26, 2009
    President:
  • 2,653 Answers
I'd try upgrading the bios with the working cpu and then try again.
Let me know what happens. I like the weird ones like this.
Amd athlon 64 3800+ processor sound issues
Check mother board for failing capacitors. This is a common problem. There are replacements part kits to repair.
Computer operate erratic. Crashes. blue screen!
Hope This Helps?
Jun 26, 2017 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Will windows xp supported in amd sempron 145?
No it should not.
However your post does have one confusing detail - XP when installed does not reside on the motherboard but on a Hard Disk Drive. Parts of it will be loaded into memory when you boot up the PC.
If you mean that you are also installing a new Gigabyte MB under an existing installation of XP, you will probably still need the XP system disk for a reinstall of XP as it may not recognise the new MB.
If you are newly installing XP in an existing PC with the specs you mention, it should be ideal. It is best to have enough memory on board, at least 1 Gb.
Nov 20, 2011 | AMD Sempron 145, 2.8 GHz
I have this old laptop and its called a compaq (presario 2500) well yesterday i brought the sims3 game for it because the laptop dosent have internet. When i installed the game it says windows xp has to...
Thanks for using fixya.
My name is Carlo.
Your computer might not pass the system requirements that's why it has an error. Or, you can try installing it one more time and check if it will work. Computers do mess up sometimes.
Here's the system requirement of SIMS 3:
Desktop PC (Windows XP + SP2):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2000+ Processor
RAM: 1 GB of RAM
GPU: 128mb Video Card (GeForce FX 5900 or Radeon 9500)
Desktop PC (Windows Vista + SP1):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2400+ Processor
RAM: 1.5 GB of RAM
Laptop (Windows XP + SP2):
RAM: 1.5 GB of RAM
GPU: 128mb Video Card (GeForce Go 6200 or Radeon 9600)
Laptop (Windows Vista + SP1):
RAM: 2 GB of RAM
Read more: http://pc.ign.com/articles/939/939410p1.html#ixzz10TQHijZi
IF your computer does not pass the system requirement, then you cannot play sims3 in your computer.
I hope this helps. Thank you for using fixya
Please leave your comment and ratings. Thanks
CARLO
Sep 24, 2010 | Computers & Internet
Any. I got old one amd processor of 1,2 Ghz and I am looking around what I can do before I done this old pc to my kids. motherboard is 7vt600p-rz of gigabyte
Windows 2000 SP4 will run faster on it, if it is with XP. Win 98Se is just a sadistic idea. As for hardware, nothing cost-effective imho. SDRAM is really expensive, even if you have a free slot. This CPU will not utilize more than 512MB/1GB anyway. Even if faster CPU is supported, it is probably not worth again. Still, check on e-Bay if you enjoy the upgrade. Overclocking is not the strong side of AMD. But if you ask around your friends and get a RAM or CPU, or HDD at 7200 rpm for the OS (yours might be 5400 rpm), which they will never use for low or no price, things change. You can also do a fresh install.
Nov 08, 2009 | Gigabyte 7VT600-RZ (GA-7VT600-RZ)...
I get blue screen somtimes when I installed xp pro
it is the problem of foulty RAM, blue screen comes when the RAM was not working correctely it comes most time when you insalling xp
Sep 28, 2009 | AMD Athlon XP 1500+ , 1.33 GHz Processor
When strting up the computer stops at the screen where one chooses SAFE MODE etc.... It had a FREEZING problem. I did full windows xp pro REPAIR. Even when using a NEW drive and installing FULL NEW...
hello, remove your processor, blow the processor sit, wait a for some time and fix back the processor. this always happen when the processor is getting tired(old).or when the cpu is dusty
Aug 12, 2009 | Computers & Internet
Lite on DVD Combo disk read failure
You could take the drive out of the encloser and hook it up. There could be a flaw in the enclouser ive had that happen before to me. I just took it out and put it in standard if this dosent work then there is a flaw in the dvd burner
May 20, 2009 | AMD Duron 1.3 GHz (cpu-amd-1.3g-o)...
Amd 64 3000+
Hi Rhen, I did some research and found this on avid.com: "As far as problems you will encounter, Pro Tools used to have a problem where it wouldn't work at all on AMD systems without disabling DEP In Windows. Supposedly, the problem was related to the ILok drivers, and so with these drivers http://www.paceap.com/dldrvr.html you should be fine with Pro Tools and AMD." I hope this helps.
Aug 26, 2006 | AMD (SDA3000BOBOX) Sempron 3000+, 2 GHz...
Abit KT7A Motherboard Logo
157 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
