Question about PfaFF Quilt & Craft Pro 7530
Tension Problem while free motion quilting
Top thread shows on the bottom
    Problem Solver:
  • 9 Answers
Usually dirt in the tension plates. Pull a short piece of heavy thread through them holding the thread tight between both hands, work it back and forth to clear out lint.
Posted on Mar 04, 2009
How do I fix this tension problem so that i get smooth stitches when free-motion quilting?
Not sure I can help. Suggest perhaps loosening the upper tension a tad so the upper thread will be pulled more toward the underside of the fabric. Have you tried a different needle? Perhaps a microtex, top stitch, or embroidery needle will make a difference since the sharp point will better penetrate the quilt sandwich. Also, sometimes the thread will be the source.
Apr 05, 2016 | Sewing Machines
Brother Sq9185 sewing machine, the thread on bottom just pulls out, when free motion quilting? how do I fix this
Sounds like the upper tension needs to be tightened, or the bobbin thread needs to be loosened. At any rate, the tension is correct when the two threads meet in the middle of the fabric for general sewing.
For free motion quilting, the tension should be adjusted so that the bobbin thread does not show on the top of the fabric, however, it should not lay in a straight line like it sounds like it may appear currently. What you are currently producing is a gathering stitch where the bobbin thread can be easily pulled.
Nov 16, 2015 | Generic Brother 130-Stitch Sewing and...
Thread tension when free motion quilting
do you have this problem when doing regular sewing? if you do then the tension dial may be going bad & would have to be replaced
Mar 13, 2012 | Sewing Machines
I am learning free motion quilting. I either get the bobbin thread showing on top or when I lower the tension the top thread shows on the bottom. This problem seems to fluctuate also. What am I doing...
Try tightening your bobbin tension a little, and then readjust your top tension again for consistant tension. Also if your not running the machine fast enough while your moving the fabric, you might have you bobbin thread looking like a taught thread on the bottom. Make sure you use a small needle, like a #11 or a #10. The smaller the hole the needle makes, the less of the thread you will see on the opposite side. Especially if you are using contrasting colors.
May 11, 2011 | Bernina 1008
Pfaff Select 4.0 has looping on bottom of fabric, free motion qui
Make sure your are lowering the pressure foot first before you start sewing. With the free motion foot, you still have to lower the pressure foot, this allows tension to be put on the top thread and allows the foot to work properly (when the needle goes down so should the foot and when the needle comes up it should lift the foot up.)
Also make sure your tensions are in a middle setting and that you are threading the machine with the pressure foot up.
The way to insure you will not get your problem is with the foot up, you should be able to pull the thread easily right before the eye of the needle and when you put the foot down you should then feel a fair bit of tension on the top thread.
hope that helps :)
chris
Jun 06, 2010 | Sewing Machines
Just bought a brand new Pfaff Quilt Expression 4.0 and the top thread keeps getting shredded and breaking while doing free motion quilting. I've checked threading diagrams, changed to four different...
this is a known issue with the pfaff.....i have just bought the machine and it has thread uptake issues...thread tension issues and it comes unthreaded by itself often...leaving globs of thread on the bottom stuck in the feed dogs and under the throat plate.....then the stitches are not properly balanced because the tension gets too loose on the bobbin thread....very disappointed to find out it is a known issue with all the viking husqvarna made machines...which are pfaff, janome and viking.....sux.
Oct 21, 2009 | PfaFF Sewing Machines
Tension and missed stitches
It sounds like one of your clearances in the machine is off. When a machine skips stitches like yours is doing, it does so because the hook responsible for "catching" the thread from the needle is not close enough to the needle so it misses the loop of thread from the needle. If your machine was having a timing problem it wouldn't sew well on any fabric. A clearance problem shows up on certain fabrics at certain times. A few things you could do to try to compensate it would be to use a slightly larger needle and turn your top tension dial down to a lower setting. Move the machine a little slower on the frame or increase the speed of the machine. Either way a trip to your technician will be needed. Make sure you tell him to check the needle to hook clearance.
Sep 19, 2009 | Husqvarna Freesia 425
Viking Lily - free motion quilting - thread loops on underside.
I need more info.
>Where is your presser fooot pressure set(1-9) it should be around 4?
>How fast are you free motioning (faster is better? from 1-10 10 being full speed.
>Is your bobbin threaded correctly (I need to cover the basics.)?
>Never never use a needle smaller than a 90/14 for free motion (I know everyone's an expert...but trust me)
After all this, it's OK to tighten your tension up on top a little when free motioning and getting eyelashes/spider webs on bottom. around 6 should do it though.
Mar 09, 2009 | Husqvarna Viking 1
Kenmore 19233 computerized sewing machine
On my machine I find that my bottom and top free motion stitches are more uniform when I set my needle thread tension at 8 or 9. Also, you might want to use a top stitch needle.
Good luck,
SewReady
Nov 07, 2008 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
338 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
