Question about Black & Decker HS800 Flavor Scenter 4-Cup Rice Cooker
How to cook rice in HS800 Flaver Scenter Rice Steamer
How to cook rice
3 Suggested Answers
SOURCE:
  • 4 Answers
SOURCE: how to use HS800 flavor scenter 4-cup rice cooker
http://www.useandcaremanuals.com/pdf/HS80035.pdf
is the manual for this product ---
Posted on Jan 17, 2010
  • 4 Answers
SOURCE: black and decker flaver scenter rice cooker manuel
is the pdf of the manual for this product
How much water to one half cup of jasmine rice
Hello, Steve -
If you are cooking the jasmine rice the traditional way on a stove, the ratio of rice to water is:
3/4 cups of water to 1/2 cup of rice (per most instructions on packages); for softer rice, add just a little bit more water, plus it is recommended to rinse the rice and drain it prior to cooking
See:
https://www.onceuponachef.com/recipes/perfect-jasmine-rice.html
If you are using an electric rice cooker, the rice to water ration is:
1/2 cup of rice to 1/2 cup of water; rinse and drain the rice prior to cooking
See:
https://www.wikihow.com/Make-Jasmine-Rice-in-a-Rice-Cooker
Best wishes.
May 01, 2018 | Cooking
Tip
Rice cooking
This morning I have encountered a great many questions on rice cookers, so I remembered the time when I had one and why I started cooking rice again.
The rice was beautifully cooked in the cooker, but it took up too much space on my kitchen bench. So I turned to pots and the micro.
Cooking rice in a microwave
  • take 1cup water
  • 2 cups rice
  • a pinch of salt
  • put the water, salt and rice together in a bowl with a lid
  • blend well
  • put the lid on the bowl
  • put the bowl into the micro
  • on the micro, keep full force and set the timer on five minutes
  • start the cooking
  • after five minutes open the micro, open the bowl and stir the rice with a fork.put the lid on again keep the micro going for another 10 minutes.
  • repeat the stirring prosess, until the rice is nice and fluffy andready to serve.
Cooking rice in a pot with a lid.
  • take 1cup water
  • 2cups of rice
  • pinch of salt
  • put the ingridience in a pot, and an oven safe pan
  • in the pot, now with a tight lid. Put on a cooker on highest temperature for five minutes.
  • open the pot, stir the rice with a fork.
  • lower heat and cook for another 15-20 minutes,, stirring occasionally.
  • the rice is cooked when fluffy.
Cooking rice in a pan in the oven
  • Put the temperature in the oven on 150 degrees Celsius
  • put the ingridience as in the recipe above in a pot and start boiling
  • remove from pot into a ovesafe bowl or pan
  • Cover bowl/pan and cook further for another. 20 minutes.
on Aug 12, 2015 | Miscellaneous
What is the rice to water ratio for cooking rice in the rice cooker?
Here's a simple one page guide for cooking rice in a rice cooker. It will tell you how much water to add depending on the type of rice you're cooking - How to cook rice in a rice cooker
Sep 17, 2011 | Hitachi RD5086P 8.3-Cup Rice Cooker
Info needed on rice cooker Bravett model MC665H, how rice can go into pot, what type of rice, and how long to cook
A cup of rice is equivalent to two person, depends how a person consumes the rice.
First wash the rice by rinsing it two times( using the pot itself ) with fresh water, add water till it cover the whole rice, amount of water should not exceed the level of your first line mid finger. After that put it in your rice cooker and switch it on. Rice cooker cooks it automatically.
White rice does not need extra time to cook.
Brown or any colored rice should be left or soaked for 10 to 15 minutes before cooking it ( because it is a bit hard ).
Hope that helps you out.
Thanks for using FixYa!
Jul 07, 2011 | Bravetti Kitchen Appliances - Others
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
Rice cooking
if that rice when cooked is too soft or too hard.. then , you might want to add more water to it. the correct ratio for cooking rice is always 1 cup rice and 1 cup water. it also depends on what type of rice your cooking though, some type of rice become too mushy when too much water is added... so always have some minimal water to the uncooked rice.
May 15, 2008 | Continental Manufacturing Company CE23201...
Rice
hi!
i love eating rice.
when you want to cook rice in a rice cooker, the ratio is 1:1.
1 cup of uncooked rice is to 1 cup water.
just be sure you use the same cup.
hope you will have a delicious rice meal!
Jan 16, 2008 | Town Food Service 57155 55-Cup Rice Cooker
How do I cook brown rice?
yup! there is a different ratio for brown rice.
1 cup brown rice = 2 cups water
hope this helps
Jan 01, 2008 | Continental Manufacturing Company CE23201...
Sticking of cooked rice inside pan
Buy a rice cooker with non-stick inner pot.
Dec 04, 2006 | Panasonic SR-3NA 1.5-Cup Rice Cooker
Black & Decker HS800 Flavor Scenter 4-Cup Rice Cooker Logo
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
nanisacan
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
