Question about LG DLE5977 Electric Dryer
I bought new thermostats.I cleaned everything. I took the wires off the thermostat and put a jumper wire and conected them and it got hot
  • 686 Answers
Are you trying to burn your house down? :) the thermostats prevent over-heating. They cycle your heat on and off re-connect them the way they should be.
Posted on Mar 01, 2009
I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
Jan 07, 2017 | GE Ovens
Continues to blow the high temp stat. I clean the blower and replaced the venting. I also replaced the heating coil the dryer heats up for a load and then it stopss heating. I test the high temp stat
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Feb 17, 2015 | Dryers
Dryer heats briefly then heat cuts out
Sounds like a bad thermostat...There is one (some models two) disc type thermostats, about the size of a quarter that are wired into the heating element circuit. Take the back panel off and find the heating element. There should be a thermostat with two wires attached connected to the heating element. Unplug those wires and remove the thermostat and replace it. Be sure the unit is unplugged before you start.
Oct 12, 2014 | Tricity Bendix TM220W Electric Dryer
Fer211as heats but wont dry! heating element comes on but kicks off after gets to temp then element will not come back on unless stopped and restarted?
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 22, 2011 | Frigidaire FER211A Electric Dryer
Dryer runs but doesn't heat I have a Roper RES7646KQ2, l have replaced the following parts: 1-Thermostat 2-Thermal cut off kit which replaces (hi limit and Thermostat 3-Heating Element Still...
If I remember correctly, this model has a switch on the motor which activates both legs
of the 220 to allow the heating element to come on. There is a wiring diagram under the
lid of the dryer and should show this. Hope this helps.
Jun 21, 2011 | Dryers
The water gets too hot and trips the reset on the thermostat.
Two possibilities. 1 failed upper or lower Tstat 2 Shorted element
To test element: disconnect both wires to element terminals. use continuity tester to see if there is continuity through element (one probe on each element terminal) If no continuity element is bad. Then test for continuity between each element terminal and the water heater itself.( one probe on element terminal and one probe grounded on bare metal or inner tank.) If there is continuity from terminal to ground, element is bad and also can cause tank to continue heating even when thermostat shuts off. This is because the thermostat only shuts off one pole of the 220 and a shorted element can continue heating from the 2nd pole.
If both elements test OK and water heater heats the full tank( tank feels hot at bottom element access panel when no hot water for 2 hours) most likely the lower thermostat is bad.
Jan 25, 2010 | Reliance Water Heater #6-30-DORT 30GAL...
My GE oven heating element heats red hot no matter what temp I put the oven on
Something is probobly wrong with the thermostat, it gets hot to warm up, but should lessen as it reaches your desired temp. If the thermostat is bad it will just keep going.
Nov 20, 2009 | GE Profile JTP18 Electric Single Oven
Maytag Dryer working but not heating up.
possible air flow problem,, check exhaust hose and sure not clogged up needs air flow, if long dry times repl/ coils/ only on gas models /if electric./ repl/ hi limit thermostat,// and safety thermostat ,,u need 240 volts 120 to turn on dryer and another 120 to heat ......
Nov 30, 2008 | Maytag PYE2300AY Electric Dryer
Crosley Dryer Heats then stops
If im thinking right, this dryer has the element in the top left corner.  This unit has two thermostats, one mounted right above the element, and the other in the lower left front mounted on the fan housing.  The one in the front is called the high limit thermostat, which means when it gets to a preset high temp, it cuts off the system until cooling occurs.  The top thermostat, mounted above the element is the operating thermostat.  It probably is one of the two thermostats.  Its a very good idea to replace not only both of the thermostats, but the fuse as well.  The fuse kit (Maytag Part# LA-1053) comes with a thermostat and 2 fuses, be sure to follow he instructions on how to determine the fuse for electric and gas.  The high limit thermostat (Maytag Part# 53-0771) is an easy replacement.  Something is causing the unit to short cycle.  Sometimes you can hot-wire the operating thermostat (use caution, severe caution if doing this, not recommended if you arent sure whats going on).  By doing this (removing the two wires from the thermostat, taping them together), you can watch and see if the element stays on longer, at least until the high limit switch comes on.  This is really not recommended, if the high limit is out, it will not be good.  Just easier to replace them both.
Oct 24, 2007 | Crosley CDE6000 Electric Dryer
LG DLE5977 Electric Dryer Logo
88 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
