Home | Hobart | AM14-253 Free-standing Dishwasher | AM14 tank hea...
Hobart AM14-253 Free-standing Dishwasher
Problem for Hobart AM14-253 Free-standing Dishwasher
AM14 tank heaters--when are they energized?
By lshipman01 on Feb 26, 2009
The heaters for the tank in the AM14 I'm working on are energized only during the wash cycle (and maybe rinse cycle too--I didn't check). But when the unit is idle (meaning while waiting for another load of dishes), and with normal tank water level, the heaters are off, and come on again only during the wash cycle. Is this normal? If so, I would wonder how effective they would be in heating the water. With such a short wash cycle, the wash water's temperature drops. (PS: checked the heaters & they are all receiving normal power when the contactor is energized.)
Same Problem
Mar 02, 2009
-   Yup, it's an AM14. The incoming water temperature is low (about 120 deg) & that's why I'm wondering why the heater contactor is only energized during the (relatively short) wash cycle. Between wash sessions the tank is not drained, and I'm told (but have not personally observed) that the temperature stays around 97 degrees.
During the rinse cycle the display shows what appears to be the correct water temperature (about 135 degrees) so I don't think there's a problem with the display or the rinse thermistor. And the actual tank water temperature seems to be displayed correctly, so I'm ruling out any malfunction in the sensors or display.
I don't know the history of the previous owner. It's possible that he had a booster heater, so this wasn't a problem. Somehow I'm wondering if the tank heater temperature scheme can be adjusted? -   Guest
Solution #1
posted on Mar 02, 2009
Not Rated)
bigg t
Rank: Guru
Rating: 86%, 583 votes
How hot is the wash temp?It should be 150-165 degrees.The model is an am14 not an am15?I'm hobart tech and repair these units weekly.Let ne know.
Was this helpful?
Yes
No
Popular Solutions for Hobart AM14-253 Free-standing
Questions and Unsolved Problems for Hobart AM14-253 Free-standing
Do you recommend Hobart AM14-253 Free-standing Dishwasher?
Answer
Answer
Low Heat on booster unit Psi gauge not in green zone
Answer
No heat on booster unit low temp Operating temp only 70c
Answer
What soap is recommended for this washer, Hobart AM14? David Jackson
Answer
water comes out of the four corner when it washers
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hobart AM14-253 Free-standing...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
