Question about Sony Playstation 3 (PS3) Console
I turn my ps3 on then 10 seconds later it turns it self of whats up with it
    President:
  • 2,653 Answers
That's a bit hard to diagnose, can you give me some more details?
Does it feel hot, when did the problem start, what model, etc. etc.
In the meantime check out my guide here:
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Posted on Feb 26, 2009
Fault finding
HEATING AND AIR CONDITIONING
HONDA CIVIC 2001 - 2005
How to retrieve DTC:
The heater control panel has self-diagnosis function. To run the self-diagnosis function, do the following:
    1.Turn the blower fan OFF.
    2.Press and hold the recirculation control switch and the rear window defogger switch down.
    3.Turn the ignition switch ON (ll).
    4.Release both switches. The recirculation indicator and the rear window defogger indicators come on. The recirculation indicator goes off 3 seconds later and the A/C indicator comes on, then the self-diagnosis will begin. About 10 seconds later, the self-diagnosis will finish and the A/C indicator goes off.
    If any trouble is found, the recirculation indicator blinks the diagnostic trouble code (DTC) to indicate a faulty circuit or component.
    If the system is ok, the recirculation indicator stays off.
Aug 19, 2013 | Honda Civic Cars & Trucks
My TV 52 HDTV start and cople seconds later turns off
That can be caused by either the deflection board or the signal board. If you contact the guys over at www.tvrepairworld.com they can help you properly diagnose the issue and they have replacement parts as well.
Oct 19, 2012 | RCA Televison & Video
Mitsubishi ws55813 picture turning off
The model indicated has a self check feature.
If turned on and green power light comes on and a few seconds later goes out:
On front of set press and hold both the menu and input(device) buttons at the same time for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of 5 times.
Let me know what error code you find.
If you unplugged the set--you will have to plug it back and attempt to turn it on--unplugging set clears the error buffer.
May 16, 2012 | Televison & Video
I turn on my set and the power light comes on for 2-3 seconds then the set turns off. What causes this to happen?
F power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65411 65" Rear Projection...
The Light turns on and then 2-3 seconds later turns off. Any solutions to fix it?
DO SELF CHECK IT HAS: WHEN SHUTS OFF PRESS AND HOLD BOTH THE MENU AND INPUT BUTTONS ON THE FRONT OF THE SET FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
POWER LIGHT WILL BLINK TWO DIGIT ERROR CODE LIKE: 2 blinks, 2 blinks, a pause and repeat 4 more times.
let me know error code found and I will tell you what it means.
SD TECH
Aug 21, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I turn the camera off, it turns off, 15-20 seconds later it will turn on by it's self
backup your pictures if you have into the camera ,go to settings and change to factory settings and try
Aug 12, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
My 65 inch projection TV turns off within a few seconds when I turn it on. Why? No pictures or sound.
If power light does come on and a few seconds later it goes off---do the self check that the WS65909 MITSUBISHI should have:
On the front of the set press and hold both the MENU and INPUT(OR DEVICE) BOTH FOR 5 SECONDS AND THEN RELEASE BOTH BUTTONS.
Power light should blink a two digit code--error code---for example: 2 blinks, a pause and 2 blinks.
Let me know what code you get----it will repeat it several times---and I will tell you what it means.
SD TECH
Nov 03, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Tv is doing my head in...
Your TV is defective. Exchanging it at the store is your only option.
May 15, 2008 | Televison & Video
No Power in Mitsubishi VS-55705
Hi John This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Sep 11, 2007 | Televison & Video
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Sony Playstation 3 (PS3) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
