Question about Sharp AR-M205 Copier
The copier will not copy. The letter L and the number 6 flash al
The letter L and the number 6 flash alternatively
  • Anonymous Mar 15, 2014
    flashing number 6 and flashing the letter E
    Problem Solver:
Leaser moter problem replace poligoan moter
Posted on Feb 27, 2009
H and 4 appears alternately on SHARP AL-1226
Press the key simuteniously C ,Density Key& C Then press 14 and press start key, then machine auto restart. ok
Dec 17, 2013 | Sharp Office Equipment & Supplies
My Sharp AL 1000 is displaying alternatively the letter H and the number 4. What should I do?
Hello
The error that is on your disply is the following.
The fusing temperature does not reach 175 degrees celsius within 30 seconds of turning on the power, or the fusing temperature keeps at 140 degrees celsius.
In sequence press the following buttons [clear]-[density select]-[clear]-[desity select] the display will go blank.
With the copy quantity keys input 14 and press the start/print button, the machine will cycle.
If the error returns then the thermistor and themo fuse will have to be rplaced.
I hope this helps you
Regards
Apr 16, 2011 | Sharp AL-1000 Copier
A letter and number appear alternately
What Letter and What number?. These usually come up as L - 1 or H - 4...both of which are easily resolved. Just let us know what code is flashing.
Feb 03, 2011 | Sharp AL 1631 Copier
My sharp al-1530cs keeps flashing a L and will not copy
L what? These Sharp machines will flash a letter followed by a number such as L 1. The L1 is the most common so I will give you my link for that solution. If this is not correct just reply back with the code you have.
Good Luck and Thank You for using Fixya.
WheatlandServices
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
Nov 05, 2010 | Sharp AL-1530CS All-In-One Laser Printer
The copier displays an alternating L and 1. The
the display flashes L1 when turned on and will not make copies
Feb 12, 2010 | Sharp AL-1642CS Copier
Displaying L and 6 (flashing) on Sharp AL-1000 copier
The L-6 indicates there is a problem with the "polygon motor". This is the motor inside the laser unit. The laser is not servicable unless it is opened in a "clean room" (no dust particles). If turning the copier off and on does not resolve the issue then the laser needs to be replaced. You could try taking off the back cover of the copier and unplugging and re-connecting any wires you can see connected to any board. sometimes it may just be a wire has worked its way loose.
Jan 11, 2010 | Sharp AL-1540CS All-In-One Laser Printer
"l" appears when this copier is warmed up ,but it want copy
"L" and what number? 1?
The scan head is locked. Unlock it
Manual is here:
http://www.sharpusa.com/files/cop_man_AL1641CS_1631.pdf
Feb 11, 2009 | Sharp AL 1631 Copier
Flashing ''4'' then ''H'' on my Sharp AL-1551CS
Disconnect printer from computer.
Switch on printer.
Type quickly: C "Auto" C "Auto", than 14 (number of copies) than "start"
"Auto" is the second button from the left.
Nov 16, 2008 | Sharp AL-1551 Laser Printer
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
Sharp AR-M205 Copier Logo
74 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
