Question about Fisher and Paykel GWL11 Top Load Washer
I overloaded my washing machine!!
I have a top loading fisher and paykel washing machine that I obviously overloaded because the clothes bowl (drum) has collapsed down and nothing is holding the bowl in place. How can I fix this??
  • 145 Answers
Hi Tracy, welcome to Fix ya.
I believe know exactly what happened here- one or more of your tub support rods has broken and that caused the tub to drop down. Those are actually pretty easy to change yourself! Lift the lid, look for two plastic caps, one on each side, that cover the screws the secure the washer top to the cabinet. Pop the caps off, take out the screws. Now the whole top can be opened up (it's on a hinge of sorts) and now you can see the main basket/tub assembly. The rods fit in a recess on the tub at the bottom and on the top of the rods, the triangular plastic sits in each corner of the machine. There are no tools needed, these rods come off very easily.
You can get a set here: (They are sold in sets of 4 and should be replaced as a set)
I hope this info is useful to you.
Posted on Feb 28, 2009
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ... > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Washer dont spin out clothing
Is all the water pumped out of bowl.
If all water is pumped out, try blowing air down the clear pressure
tube to dislodge any blockages that would stop the bowl from spinning.
Jan 02, 2014 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel SmartDrive 5.5
Hi Craig
Was the drum was banging with no load in it.
It can be two things suspension rods or the bowl is faulty.
All the water has leaked out of the ballast rings on the bowl,
causing it to go out of balance.
Feb 01, 2013 | Fisher and Paykel Washing Machines
I have a 5.5kg Top Load Fisher & Paykel Washing Machine MW512. The clothes seem to come out with alot of dust particles on them. Is there somewhere in the washing machine where it is collecting this...
Hi - are these particles kinda ash grey black in colour? if they are then the bellows have sprung a leak.. unfortunartely the only way is to replace the inner stainless drum.
Inspect the top of the bowl for any signs of structural damage along the grey plastic housing as it contains very fine sand used to counter balance the inner bowl.. on rare ocassions these leaks and give you the particle effect similar to what you've described..
Aug 12, 2011 | Fisher and Paykel Fisher & Paykel Washer
The drum of my tThomson Washing Machine is stuck as the frame has
This is a faulty water valve assembly. replace asap if possible. the embedded water pressure sensor is damaged.
You will need to call Fisher Paykel so they may direct you to a local technician. the water valve assembly will need to be replaced at this point.
Aug 24, 2009 | Thomson Washing Machines
Fisher and Paykel top loading washer
This is not grease this is a build up of poweder in the machine on the outer bowl, this will also happen if you use too much fabric softner. :)
Sep 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel washer
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
Sep 07, 2008 | Fisher and Paykel GWL11 Top Load Washer
Bowl spiner
What is a bowl spinner, my washer is only 3 years old and seems to not aggitate any more. The light come on complaining of either the water is too hot or the bowl is unbalanced. puting my clothes on the cold cycle and balancing the load does not do any good. the wash and spin cycle will run its cource and I get dirty clothes from it!@!#@#$$@@!!!*^!
Nov 21, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
379 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
