Question about HP Compaq Presario SR1630NX PC Desktop
Need to know mem spd...333...400 etc to add cards
Need more Ram already know to be DDR but what speed so I can purchase same sr1630nx desktop
  • 679 Answers
The 512 MB of installed RAM (PC3200), that is 400mhz, your machine will take up to 4 gigs of ram
Posted on Feb 26, 2009
    President:
  • 1,073 Answers
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
I have a Hp Pavilion 733b with chipset 845g, i have 1gb of ram but just recognise 256mb
Product: HP Pavilion 733b Desktop PC
http://h10025.www1.hp.com/ewfrf/wc/product?product=296502&lc=en&cc=us&dlc=en&lang=en&cc=us
Motherboard: FIC VG31
[ First International Computers ]
Motherboard specifications;
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07722&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=296502
Memory Type: DDR Sdram
Memory Speed: DDR Sdram at 266MegaHertz, or 200MHz
(PC2100, and PC1600, respectively)
Memory Sockets: Two. For Dual Inline Memory Module/s.
Maximum Memory: -> Maximum TOTAL Amount for motherboard.
2GB.
Maximum Amount for EACH ram memory slot: 1GB
So far looks good, BUT;
1) Is the Ram Memory Non-ECC?
http://en.wikipedia.org/wiki/ECC_memory
2) Un-Buffered? (Un-Registered)
http://en.wikipedia.org/wiki/Unbuffered_memory
3) Voltage: Does it use 2.5 Volts?
JEDEC standard for DDR Sdram ram memory voltage is 2.5 Volts (DC)
FIC is going to set the ram memory default voltage at 2.5 Volts.
Point? DDR Sdram at 2.6 Volts, or higher, may not work.
Betting the motherboard doesn't have SPD, and the ram memory may not either.
http://en.wikipedia.org/wiki/Serial_presence_detect
4) Ram Memory frequency rate:
What frequency rate of ram memory are you using?
(Excuse me,...'Speed')
The Intel 82845G Northbridge chip, will only support DDR Sdram at a -> Maximum <- frequency rate, of 266Megahertz. (266MHz),
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_chipsets
I have seen websites offering DDR Sdram at 400MHz for this board.
Maybe there is a BIOS update, I don't know. But going with the standard BIOS program that is installed, and info for the Intel 845G support, I would say this = No.
Processor Front Side Bus (FSB) support is either 400MHz, or 533MHz.
Ram memory typically operates at HALF of the Processor's FSB.
That would be 200MHz (PC1600), or 266MHz (PC2100), respectively.
[Half of 533 = 266.5
It's just rounded down to 266 ]
Can you read a manufacturer's label on the ram memory modules?
If so post what you see in a Comment.
Regards,
joecoolvette
[Sometimes when upgrading ram memory, it may take you to turn the computer completely off, and wait 1 minute. Then turn it on, and let it run for a couple of minutes, then turn it off. Wait 1 minute, turn it back on.
IF, the motherboard does have SPD, and IF, the Ram Memory has SPD, it may take a couple of 'Cold Boots', for BIOS to recognize the Ram Memory.
Some of the old mobo's were just like that.
{MOtherBOard ]
Jul 11, 2012 | Computers & Internet
What type of ram can I add to my Compaq EVO 510 CMT and what is the max amount?
DDR SDRAM type Ram i.e. DDR1 with 266mhz speed with DDR266/PC2100 compliance. You can simply ask for DDR SDRAM 266Mhz or you can find online with the similar compliance, DDR266/PC2100 Compliance.
I hope you still have the old one which was installed on the system, if so look at the white sticker, it should be labelled there...
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 15, 2010 | Compaq Evo D510 Minitower (Open Box)...
What type of RAM do I need?
This should be easy for you , just et this RAM specs for your computer this is a DDR with a Module Speed of PC3200, DDR400.
Jun 17, 2010 | MEDIONM 3 COMPOSER 5100 INTEL- (20023321)...
Need to add RAM
Located here is the actual specifications of your W3052.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W3052
The DDR means "double data rate", SDRAM is "synchronous dynamic random access memory" and DIMM is for "dual inline memory module". These are the way manufacturers describe the specific speed, type, and packaging of the memory. You need to get the correct combination for your computer in order for it to function properly. The PC2100 is NOT correct, at the very least it will slow your computer down, and possibly will not work at all. You should use PC2700.
If you wish to add another 512MB taking your computer to 1GB total, then you only need 1 module, a 512MB, like the one that came in the computer. Do not purchase a 1GB module expecting it to work properly with the one already there. It probably won't. If you want to max out your computer's memory taking it to 2GB, then you will need to purchase 2 each 1GB modules, and remove the existing 512MB module.
When you go to the computer store, you ask for either "one five-hundred-twelve megabyte, PC2700, DDR, SDRAM DIMM memory module" or "two one-gigabyte, PC2700, DDR, SDRAM DIMM memory modules".
The part numbers from, Kingston, one of the major add-on memory makers are shown here:
512MB = KVR333X64C25/512
1GB = KVR333X64C25/1G
Mar 28, 2009 | E-Machines eMachines Desktop PC
Upgrading my Ram
vista needs 40mb to install ...no matter how much mem you install vista is slow compared to xp or xp pro which configuered right can run at lightening speeds.
to upgrade mem ...
you either have 2 512mem cards or 1 1024 card ...if you have 1 1024 card add another if you have 2 512 replace with 2 1024.
you can buy mem cards in any pc shop.
Jan 30, 2009 | HP Compaq 6720s Notebook
Will a DDR Ram work with a DDR2 Video card?
The on board memory on the graphics card being DDR2 will NOT affect the system memory being DDR.
And the memory you want to add depends on the memory you have allready installed on your machine and what version of windows you are running.
Please post back with more info on this.
Dec 30, 2008 | Gateway 5200XL PC Desktop
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
E-machine not accepting new memory
try to check  whether the ram  frquency  matches the specifications....
any way  three beep  means a graphics card problem  so  if you have one remove it and try to reboot
but i think this has to do with the RAM frequency
pls do post back
Nov 26, 2008 | E-Machines eMachines W2686 PC Desktop
Upgrading RAM
Yes that should not be a problem as DDR is backward compatible with the slower speeds so the faster RAM, will just slow down to match. These are the only conditions listed so as long as the stick you have doesn't fall under this criteria you should be good.
he D845GLVA board provide the following memory features:
  • 2.5 V (only) 184-pin DDR SDRAM DIMMs with gold-plated contacts
  • Unbuffered single-sided or double-sided DIMMs
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • DDR266/200 MHz SDRAM DIMMs only
  • Serial Presence Detect (SPD)
CAUTION:
Do not use ECC DIMMs with this board. Using ECC DIMMs could damage the board.
Integrator's Notes:
  • Registered DIMMs are not supported.
  • Double-sided x16 DIMMs are not supported.
  • If a full-length PCI add-in card is installed in PCI bus connector 1 (the PCI bus connector closest to the processor), remove the add-in card before installing or upgrading memory to avoid interference with the memory retention mechanism.
  • This board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated (currently validated up to 1.0 GB) on this board.
Note:
To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
Enjoy the increase in RAM,
Lee
Jun 14, 2008 | Intel Desktop Board D845GLVA...
HP Compaq Presario SR1630NX  PC Desktop Logo
193 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
