Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge Profile Freezer not working
I have an 2002 S x S Artica Profile refrigerator. Fixed the dampner control fan assembly and now the freezer just stopped working overnight. The control have not let me adjust the temp for some time now. They just beep 3 times when pressed. The lights are on in the frig, the condenser fan is working. The compressor is not kicking on though.
  • mballing Feb 26, 2009
    Main pcb? I pulled the computer board, I believe that is what you are talking about, and on the back was burnt connection. It was on black box labeled (COMP). I assume that would control the compressor.
  • mballing Mar 05, 2009
    Looks like the main board caused all the problems, at different times. Must have just been going out over the years. GE parts guy said this is the third generation board, this one has a grounding strap also. Maybe they will get it right.
    Thx
  • 74 Answers
Main pcb failure but just check the wireing at the bottom of the freezer door as it can affect the control system
Posted on Feb 26, 2009
I have a freezer on top GE profile arctic fridge. It heated up for 24 hour then went back down and is now hovering at 7 freezer and 42 fridge. What is wrong?
This is a common problem with the GE Artica and Profile. The mother board=> WR55X10942 Main Control Board Compressor start components and condenser or evaporator fans must also be considered in the diagnostics. If you would like to do this yourself let me know and I will be glad to help you go throgh with the testing, Thanks Sea Breeze
7_10_2012_2_44_57_am.jpgWR55X10942 Main Control Board
Jul 09, 2012 | GE Profile Arctica Stainless Steel Top...
The freezer temp same as refrigirator, 38 degrees. reset freezer temp to 0 but does not go down.
The GE Profile PSW26PSSBSS is a little tricky to examine sometimes. It sounds to me that you either have a defrost problem, fan problem or motherboard is failing causing all of the symptoms. To begin check inside the freezer and look over the rear wall to see if ice is building up. If yes then that will be an easy fix by replacing the defrost heater=> WR51X10055 Defrost Heater and Bracket Assembly
and defrost thermostat=> WR50X10054 Defrost Thermostat If no frost build up I would like you to pull away from wall, unplug and remove the lower cover and feel the top of compressor to see if the compressor is warm, cool or too hot to hold hand there. If too hot then I want you to make sure both fans are working inside and out and that they do not stop after a few minutes. If the fans are OK then it is possible the motherboard has a defective relay and will need to replace=> WR49X10152 Control Board You may need to examine both sides of the board for heat marks or signs that solder has been melting away from a relay. If it comes to this I will guide you through the repair and replacement. Click Here for=> GE Artica Technical Information And Click Here for=> GE Artica Service Manual Click here for the=> PSW26PSSBSS Back Side and motherboard is the item listed in photo as 801. And the Freezer Components Click Here=> PSW26PSSBSS Freezer Components and in that photo part 240 is the Defrost Thermostat and 230 is Defrost Heater. I will be here to show you what to do if you care for my assistance, Thanks Sea Breeze
May 09, 2011 | GE Profile PSW26P Stainless Steel Side by...
My ge artica model number pss25ngma the refer part freezes evertyhing. I have adjusted the temp but it goes back to 32 waht can I do?
check the evaporator fan; listen to see if it is running check the baffles between the freezer and, the refrigerator box for air flow. Check the control knob to see if it is turning the cold control shaft. If these are not the problem: replace the cold control
Mar 17, 2010 | GE Profile Arctica Stainless Steel Top...
Making a clicking noise and not cooling
This could be a relay on the control board or the compressor is short cycling or both. You can use my assistance to help you resolve this or call a technician, this depends on you. I am very familiar with the Artica/Profile and know that if you can follow instructions and use a test meter we can get this fixed. I would like your complete model number so I can refer to the exact model you have. I will leave you contact information and a service manual and a web page to use with the diagnostics. This problem will not get better, Sea Breeze
Jan 26, 2010 | GE Profile Arctica Stainless Steel Top...
GE Profile Artica side by side - freezer not cold enough
replace control board on back of unit there is a six by 10 inch cover on back your panel is in there cost aprox 169.00 dollers also replace bo0th thermisters bottem left of freezer looks like a white bullet the other is in fridge behind shelf trim located beside and underneath where the cold air blows into the fridge.
Aug 10, 2009 | GE Profile PSI23NCR Side by Side...
Noisy Fans GE Artica Profile Side by Side
You will have to remove all shelves to access the problem areas. You will sometimes have to look carefully for the screws as they are camoflaged with paint, but i am sure they are there. Hope this helps
Jul 26, 2009 | GE Profile Arctica Stainless Steel Top...
My freezer (ge artica) temperature goes up to 40%, then cools dow
The main problem with the Artica/Profile is that they have a main control board and a thermostat board inside the fresh food compartment. I have a repair manual and will send you a copy if you want but we are going to have to look at the control boards for burn marks. Let me know if you need me. Thanks, Sea Breeze
Jul 15, 2009 | GE Profile Arctica Stainless Steel Top...
Frig gets too cold freezer works good
I had the same problem. I have the side by side Profile Artica. The problem was a broken damper. It allows the cold air in from the freezer side. With it broken, there was a steady flow of freezer air coming into the frig side. It was easy to fix. I ordered the part (damper/fan assemble) for around $100. While searching for a solution, it seems that this is a common problem. Unfortunately, I received a wide range of incorrect solutions to the problem which could have cost me a lot of money. I hope this helps!
Jun 19, 2009 | GE Profile PFS22 33" Artica French Door...
GE Profile Artica side by side stainless steel wont get cold
The Profile and Artica are good refrigerators. the problem may be the defrost element, defrost thermostat or the mother board. Let me know if you want help on this one. Thanks Sea Breeze
Jun 18, 2009 | GE Profile Arctica Stainless Steel Top...
GE PROFILE FREEZER PFS 22 SISBSS
hopefully you have a service warranty. I have had me fridge for two years and have replaced the temp control panel twice thus far. serviceman coming AGAIN on Tuesday because now everything in the fridge is freezing. cna't get the temperature in freezer and refrigerator regulated properly. GE knows they have a problem...something in the computer panel board sticks. I'd give anything to be able to put this on the curb and buy a new refrigerator.
Jul 19, 2008 | GE Profile PFS22 33" Artica French Door...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
219 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
