Question about Maytag 24 in. MDB9150A Built-in Dishwasher
Heat will not turn off Maytag MDB-9
I have had this dishwasher for about 19 month and just last week after completing a wash cycle. The heating element would not turn off. As instructed, I turned off the unit to reset the board. I then turned it back on and it worked fine. However after shutting the door the element turned back on with the unit off. I called a repair man and they want 89.99 to come out plus the hourly fees to install the parts, plus the price of the parts. The unit cost me $300.00 and Maytag could care less.
The lock light will not turn off. tried break no joy.
Posted on Sep 11, 2012
SOURCE: Dishwasher Heating element not working
my wife shut the water off to the dishwasher and forgot to turn it back on and then used the dishwasher.
the heating element went on but there was nop water.
when we turned the water back on,the drying cycle does not work.i would think that the element needs to be changed or is there a relay on the computer board?
this is a two year old Jennair unit.
any suggestions?
Posted on Apr 29, 2008
SOURCE: Maytag Dishwasher flashing lights
I have the same problem with the lights flashing on the control panel. It pops up every 4 or 5 months. The only solution I have found is to press the delay/resume button one time then press the drain/off button twice. You may have to hold the keys down for a couple of seconds. This seems to reset something in the panel. Make sure you haven't pressed the 3 second lock button or it won't work.
Posted on Oct 11, 2008
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
subarufamily
  • 6 Answers
SOURCE: MDB7600AWS No Rinsing
Sound like you are recycling the same filthy water over and over again. Your dishes will likely become progressively more and more filthy.
One likely problem is that debris has clogged the small drain ports.
Most Maytag D/Ws rely on a garburator to chop debris small enough to fit through these small ports. Unfortunately a chuck of glass or fruit pit often makes it through to clog the ports. This may cause very slow and incomplete drainage or no drainage whatsoever.
To examine these drain ports, you'll need to remove the lower rack and completely disassemble the central assembly from the top down. If you are mechanically inclined its not hard. If you are worried about proper re-assembly, then video tape the assembly as a memory aid and stack the parts and screws in careful succession.
Once you reach the steel garburator blade you only have one more plastic plate to remove. Examine both ports on the plate to ensure that there is no jam or debris. Throughout the disassembly, look for any broken glass or debris that could be jamming or clogging.
When you reassemble the unit, consider reassembling without the garburator blade. Instead, perform routine disassembly and cleaning every 3 - 6 months.
Posted on Jan 27, 2009
rickead1
  • 1998 Answers
SOURCE: Maytag MDBtt60awb
most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
Posted on Apr 30, 2010
Dishes have a whitish-gray film on them
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Nov 26, 2010 | Maytag MDB7100AWB Dishwasher
Maytag MDB7100AWB dishwasher. 'High Current' during wash cycle. What do I need to do? Thanks
What problem is the "high current' you mention causing?
Many dishwashers continue to heat the water to a higher temperature to wash and rinse the dishes with. They turn the heat strip on to do this, which causes the dishwasher to pull more current.
Dec 16, 2009 | Maytag MDB7100AWB Dishwasher
MAYTAG mdb4100aww-cycles but bottom sprayer doesnt wash off food. replaced impeller last year.
heat was off, filter was clogged,heat on and clean filter made the difference
Dec 06, 2009 | Maytag Dishwashers
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
Dishes have dried on food particles after cleaning
common problem with dishwashers, the filters become blocked/ break down, a cleaning cycle with an approved detergent usually fixes this. if not, the filters my need replacing.
Oct 24, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag Dishwsasher Model MDB-9
The Switches do not oprate when you press them. What can be the reason?
Sep 27, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag 24 in. MDB9150A Built-in Dishwasher Logo
167 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
