We have a Brother InteliFAX 5750e Fax machine. From last couple of days it has start dispalying message " Wrong Operation" while trying to scan documnet to send as FAX. This message shows up when maching is dialing out a prevoiusly scanned document in the memory. The machine display shows 77% memory. If memory is full it should say Memory Full but instaed it is not allowing to scan next document. If I undersatnd right these machines are by default are dual access means we can send and recive faxes at the same time.
Any Idea?
SOURCE: Send Fax Issue
I have a brother intellifax 770 and I bought it used so their for I do not have the owners manual and I am having trouble setting it up and getting it to work. I can fax out but I just can't recieve faxes I can fax my daughter but when she faxes me she gets an error of 388 but she is able to fax and recieve faxes so we know her end is not the problem.
SOURCE: I cannot send or copy MEMORY IS FULL
Press Menu/Set, 2, 5, 1.
Press ▲ or ▼ to select Off.
Press Menu/Set.
Press Stop/Exit.
SOURCE: Error 77 on a intellifax 5750e
Unplug the power, press and hold the menu button, the power
(hold the menu button for 5 seconds after power is plugged in). Release
the menu button, now press 91, if the display still shows the error,
press 99
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Is tel line going into correct socket of fax? (Line not Ext.)
Is Fax set to auto answer or manual?
If you pick up line or press speaker button can you hear other fax sending if so press start and hang up you should receive fax, and you have just proven that machine is in manual receive mode!
I think you will find it will wake from sleep automaticly if setup correctly.
