Question about SonicWALL PRO 100 Firewall
Cannot run RDP, Telnet over MPLS when sonic firewall is connected
When I disconnect sonicwall firewall I can telnet, RDP over att MPLS cloud but immediately it is connected, I can only ping back and forth but cannot telnet. PLEASE ahy idea is welcome.
  • sendmani May 11, 2010
    can you brief your network with ip address...
    Regards,
    Mani.S
    Problem Solver:
  • 9 Answers
You have to give rights to the particular systems. Means enable NAT policys in the sonicwall router.
for details go to the SonicWall Router Manual. Or else you can contact me, I will help you.
Thanks
Sriram.S
Chennai - 4
Posted on May 12, 2009
How do I telnet to a device behind a firewall
The normal way. Unless the firewall is configured to block telnet to or from your source or destination. In which case you need to create a rule on your firewall to permit your TCP port 23 traffic.
Jun 07, 2013 | Computers & Internet
How do I telnet to linksys E900
Windows XP included a 'telnet' client.
With Windows Vista/7/8, you have to explicitly choose to install the 'telnet' client.
Then, you can use the 'telnet' command.
Dec 14, 2012 | Linksys E900 Wireless Router - IEEE...
How do I telnet from one computer to another computer, where first computer is connected through wireless and second computer is connected through ethernet cable to "2 wire 2701hg-b gateaway"? Thank you...
Make sure that the computer that you want to telnet to is running the telnet service, and that the firewall on that PC (if using XP/Vista/Win7 and it is switched on, or you have a third party software firewall installed) allows connections to the telnet server.
From the other computer you should be able to just run telnet [destination IP address] and press enter (may need to install telnet client on Windows 7)
Hope that helps
Oct 15, 2010 | 2wire HomePortal 1800HG Router...
The system can not ping across the wireles bridge..what could be the problem?
Hi
check the firewall on the sytem and the firewall on the router and also make sure that u have used the correct way of pinging( 32 bit or 64 bit pinging). Also try to do telnet using the telnet command TELNET IP .....I hope this will sove your problem
Thank You
Please rate me as it will be just one CLICK
Don't find fault, find a remedy. - Henry Ford
Oct 23, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Can you tell me about telnet
Telnet is a way of connecting remotely to a device.You need a software like Putty which is available for free on the net.
After downloading it,Run it, type the ip address of the device you want to telnet to.
Jul 03, 2009 | Computers & Internet
I am trying to telnet through a Linksys RVS4000 from the wan side of the router to a fixed device on the lan side of the router. Both networks wan & lan are operational and I can ping the Wan side...
run netstat on the lan pc to see if telnet server is listening on port 23. look at logs on the router and pc to see if it is blocking any traffic. make sure lan pc has route back to wan
May 14, 2009 | Computers & Internet
Sonicwall site2site vpn issues
please select nebios option in hq site tz190 firewall.
Apr 07, 2009 | Sonicwall TZ 170 NFR (01-ssc-5564)...
Locked out of HTTP inside port on SG300 - telnet works
I was unable to supply a link to the manual for this product so I downloaded it to one of my sites to make it available to you. Here is the link:
http://www.dscmain.com/snaplink/sg_314_ug_revA.pdf
Please let me know if this helps...
Tim
Mar 23, 2009 | SG300 (SG0126US) Firewall
Not able to see HP C6180 on SonicWall TZ 180
Not sure if you've done this already or not, but I would suggest installing the printer manually as a local printer, and create a TCP/IP port that points at the IP of the Printer. Rudimentary way to go, but should help.
-Backu
Jan 16, 2008 | SonicWALL Total Secure 25 VPN Gateway, WL...
Port 25 Access
Are you running windows XP with the default windows firewall in operation? It is accessible from control panels -- could it be blocking/filtering port 25 -- this is not as much of a solution as a place for you to look on your machine -- I am running a 3rd party firewall that disables the windows firewall.
Dec 14, 2007 | Computers & Internet
SonicWALL PRO 100 Firewall Logo
788 people viewed this question
Top SonicWALL Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Raymond Ramirez
Raymond Ramirez
Alun Cox
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
