Question about RCA Televison & Video
TV SCREEN!!! On my television my screen is shaped like an hour glass.I have tried to go into the main/screen settings to fix the problem, but it is not working.I have also looked at my USERS GUIDE and no luck.Can you help or do you recommend I take it to a repair shop? Model # 32V432T
MikeNJ1964
  • 398 Answers
SOURCE: 51' projection tv(Hitachi 51G500A)
The Hitachi part number for the screen assembly for the 51G500a is KR02844. You can call a Hitachi parts distributor and see for yourself how much those things cost, but I warn you they are not cheap!
Posted on Jun 26, 2007
MikeNJ1964
  • 398 Answers
SOURCE: Tv picture shaped like hour glass
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
Posted on Jul 05, 2007
MikeNJ1964
  • 398 Answers
SOURCE: Replacement screen for 52"GE Television
I always have good luck ordering RCA parts from Union at 1-800-648-6657 or Panson at 1-800-938-4376.
Posted on Jul 31, 2007
techman
  • 3130 Answers
SOURCE: Panasonic PT53wx53g Rear Projection TV screen cracked
You can try it, but through my experience, it just does not look good. You may not have a problem with it. Give it a shot. Good Luck.
Posted on Oct 16, 2007
SOURCE: convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Posted on Feb 02, 2008
I was given a rca p61940 rear projection tv. The
It sounds like a convegence problem due to dust on the lenses. Clean the lenses with qtips and alcohol and then use auto convergence in the menu screen.
Mar 08, 2010 | RCA P61940 61" Rear Projection Television
Toshiba 50hdx82 the top and bottom of screen hour glass shaped
This is a convergence problem. If you wish to attempt the repair and are comfortable working inside the set, please update this and I will supply additional details and instructions.
Thanks,
Dan
Oct 21, 2009 | Toshiba 50HDX82 50" Rear Projection...
Screen Problem
the pincushion circuit is defective.bang the tv and see if the pix is normal,if so there is bad soldering on the main pc board. rca is known for that
Jul 23, 2009 | RCA TruFlat 27F520T 27" TV
Screen on JVC TV distorted
There is an Aspect button on the Remote for the TV. This button will fix this problem.
Aspect function strectches the picture horizontally or vertically to get rid of black bars in some movies. Sometimes this is good....sometimes bad
May 19, 2009 | JVC Televison & Video
Hourglass Shape
If there is a hour glass shape to the image but convergence is normal, there are 2 possibilities. You either have a pincushion correction problem or if the hour glass seems to be moving, it will be an open filter capacitor in the power supply.
Unless you are electronically inclined troubleshooting this issue will require a factory trained service technician. You can expect to spend $300-$400 to fix this.
Feb 17, 2009 | Philips 60PP9202 60" Rear Projection...
Stretched screen
Try the menu under setup, find convergence, it realigns the colors,, you are suposed 2 do that periodicly,, or when u move the tv,, should help you ,, ive got that same tv,,
Oct 05, 2008 | RCA P61940 61" Rear Projection Television
Mitsubishi WS-55807 hour glass shaped picture
If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual and try by yourself see link
Mar 04, 2008 | Mitsubishi WS-55807 TV
Tv screen has slight hourglass shape
A common fault are some of the electrolytic capacitors failing in the pin cushoning amp section, and probably in part of the scan amplifiers.
To service this will require the proper training and set-up to troubleshoot the set.
Take the set to a service center for an estimate. The cost can be at least an hour or two for the labour, and then the cost of the parts on top.
Jerry G.
Nov 06, 2007 | Sony KV-32S26 32" TV
Green Solid Hour Glass
possible convergence amp ic's failed should be under $300.
Sep 05, 2007 | Toshiba 46H84 46" Rear Projection...
Hour glass screen
Your problem is a bad main B+ capacitor. The right way to find this would be with a good ESR type capacitor meter. If you do not have an ESR cap. checker or do not know how to use a cap. checker. a local repair shop should be able to assist you in this repair at a decent price. Let us know what you did to get this set fixed?
Oct 05, 2006 | RCA F32665 32" TV
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
