Question about Frigidaire PLGF390DC Stainless Steel Gas Kitchen Range
Oven door does not lock
I was baking cassava cake and it didn't cook after 30 minutes. i realized that it was because the oven door did not lock. what could have caused this problem? thanks.
5 Suggested Answers
  • 126 Answers
SOURCE: Oven will not bake properly
as i have said before cook times are only a guide as all ranges in different locations cook differently! get to know your stove
Posted on Dec 10, 2007
  • 3422 Answers
SOURCE: Oven won't turn on and left rear burner dosen't work
HI,
It won't bake Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
It bakes poorly Here are two instances of when food "bakes poorly:"
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Posted on Aug 22, 2008
SOURCE: Broiling and Baking Element Stopped working
the thermostat is bad that's the one that turns bake and broiler elements,but before you replace anything check for power on wires connecting to the elements.
Posted on Dec 10, 2008
SOURCE: CAKE COOKING UNEVENLY
Most ovens normally turn on the top assembly that works as the broiler to bake in order to help bake it more evenly.
Posted on Feb 16, 2009
What is a cake
A cake is made with all purpose flour, Specifically, 2 and 1/2 cups flour 2 and 1/2 teaspoons baking powder, 1/2 teaspoon
salt, 2/3 cup butter or margarine, 1 and 3/4 cup sugar, 1 and 1/2 teaspoons vanilla, 2 eggs and 1 and 1/4 cups milk.
Grease and flour 8X1 and 1/2 inch round pan, Beat margarine with electric mixer on medium add eggs and vanilla then combine dry ingredients beat well blended.
Pour batter in prepared pan. bake at 375 degrees for 30
minutes. Cool for ten minutes.Turn pan over and remove cake. Recipe is found in Better Homes and Gardens New Cook Book
Nov 29, 2016 | Baking
I have FGES3065KFA gallery and I have baking problems. It bakes outside of the cake but inside of the cake stays raw. Me and my husband check the bake and broil element they work fine. We change the...
read the mixture instructions
try preheating the oven for the required temperature or when the thermostat turns the light off
insert the cake to be cooked and leave it there for the desired time
Too hot will burn the outside with out cooking all the way through
check the ingredients carefully as if the mixture is too wet ( butter, milk, water all make it wetter than required )
Place the cake in the center of the oven ( not on the bottom shelf or the top shelf)
All these may sound mundane but they all point to getting a good cake result
Sep 14, 2015 | Frigidaire FGES3065KF Gallery 30" Slide In...
How to make a cake in koryo microwave oven KMC2323
Pinched this off the internet . Method Baking a Whole Cake in the Microwave.
  1. 1 Mix your cake batter. In a large bowl, combine 3/4 cup softened butter or margarine with 3/4 cup sugar and 2/3 cup flour. Stir together with a spoon or rubber spatula.
    • You can use regular flour if you don't have self-rising, but you cake will end up more like a brownie in texture.
  2. 2 Add in the rest of your ingredients. Pour in 3 tablespoons of milk. Crack in 3 medium eggs, and add 1 teaspoon of baking powder and 1 teaspoon of vanilla extract.
    • You can use whole, fat free, 2%, or whatever type of milk you prefer.
  3. 12Edit step 3 Flavor your cake. For a chocolate cake, add 1/3 cup cocoa powder. For a vanilla cake, add another teaspoon of vanilla extract.
  4. 13Edit step 4 Mix together. Stir well with a fork or use an electric mixer to mix for about 4-5 minutes or until smooth. If you have a food processor, you can also add all of your ingredients to the food processor for about 60 seconds to mix instead.
  5. 5 Spoon your cake batter into a microwave safe dish. This is very important! Never use a metal baking pan for microwave baking.
    • A shallow dish will probably give you the best results.
  6. 6 Bake your cake. Cook your cake in the microwave for 3-4 minutes on full power. The cake will bubble and puff in the microwave just as it would in the oven, and just as it starts to set (it'll still be jiggly), it's done.[2]
    • Check to see if your cake is baked by sticking a toothpick straight down into the center. Your toothpick should come out clean. If there is gooey cake reside on the toothpick, put your cake back in the microwave and cook it in 1 minute increments until done.
    • Take care not to overcook. If you microwave your cake for too long, it will dry out.
Sep 04, 2015 | In Microwave Ovens
HOW TO COOK CAKES IN SUNBEAM SLOW COOKER
Ingredients
Original recipe makes 1 cake
  • 2 cups white sugar
  • 1 3/4 cups all-purpose flour
  • 3/4 cup unsweetened cocoa powder
  • 1 1/2 teaspoons baking soda
  • 1 1/2 teaspoons baking powder
  • 1 teaspoon salt
  • 2 eggs
  • 1 cup milk
  • 1/2 cup vegetable oil
  • 2 teaspoons vanilla extract
  • 1 cup boiling water
  • PREP20 mins
  • COOK3 hrs
  • READY IN3 hrs 50 mins
Directions
  1. Spray crock of a large slow cooker with cooking spray.
  2. In a medium bowl, whisk the sugar, flour, cocoa, baking soda, baking powder and salt. In a separate small bowl, whisk together the eggs, milk, oil and vanilla until well combined. Whisk in the boiling water. Pour the wet ingredients into the dry and mix well.
  3. Pour the cake batter into the prepared slow cooker.
  4. Set slow cooker to "Low". Cook until cake has no wet spots on top and has pulled away from the sides of the crock, about 3 hours. Turn off slow cooker and allow cake to rest for 30 minutes before serving.
Sep 08, 2014 | Crock Pots & Slow Cookers
I lost my instructions for the recipes and i don't know how to make the cake mixes
I have the recipe for yellow cake from the handbook:
preheat over for 15 minutes and spray pans with cooking spray
1. pour contents of yellow cake mix into bowl and stir to break up any lumps. 2. add 1.5 teaspoons of water and stir to form batter 3. pour batter into baking pan and spread evenly. 4. place pan in baking slot of oven and use pusher end of pan tool to push it into baking chamber. Do not use your hands. 5. bake cake for 12 minutes. 6. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 7. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. Transfer cooled cake to a plate, turning over so bottom faces up.
frosting 1. pour contents of frosting mix into bowl. 2. add 1/2 teaspoon of water and stir until smooth. For thinner frosting, stir in a few extra drops of water. 3. spread frosting over cooled cake.
Sugar Cookies
1. pour contents of sugar cookie mix into bowl and stir to break up any lumps. 2. add 3/4 taespoon of water and stir to form dough. 3. sprinkle your hands with flour and shape dough into 6 small balls. 4. flatten 3 cookie balls and place in baking pan. 5. place pan into oven and use pusher end of pan tool to push into oven. Make sure both metal doors are closed. 6. cook for 10 minutes. 7. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 8. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. 9 repeat steps 4-8 to make remaining 3 cookies.
those were the basic recipes in the handbook. Hope that helps
Jul 25, 2011 | Hasbro "easy Bake Oven and Snack Center"...
How to set the temperature on the KitchenAid Superba oven/convect
A separate oven thermometer is absolutely necessary in baking. Something similar to this would be cheap and easy. http://www.bedbathandbeyond.com/product.asp?order_num=-1&SKU=10161738
Or you could go for a digital one with a probe.
Apr 08, 2009 | KitchenAid Architect Series KEBC107KSS...
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Frigidaire PLGF390DC Stainless Steel Gas Kitchen Range Logo
21 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
