Question about Linksys Wireless-G Broadband Router
I tried to secure my Linksys Wireless-G Broadband Router last night and set it up to require a password by going to 192.168.1.1. I also did something(I can't remember what) on the linksys website that made the status of my router 'secured' but then I lost connectivity. It kept asking me for a network key and I don't know what that is!! Can anyone help me? Is there any way to actually work on it without an internet connection?
  • kimberlyrutl Feb 26, 2009
    Okay, you just jogged my memory. I actually changed the settings from the default to a WPA. I was not connected to the network cable when I made these changes. Can I fix them now?
  • kimberlyrutl Feb 27, 2009
    Thanks!! I'll try that!!
  • 643 Answers
When configure security, is better to connect to network cable. Because once u setup the wireless key such as WEP or WPA, u will be log out from the wireless connection and u need the correct key to login.
Posted on Feb 26, 2009
  • didi2005 Feb 27, 2009
    Well, if u already setup WPA key to secure your wireless, u can access the wireless network by inserting the correct WPA key.
    But, if u forget the WPA key, then u can connect the router using network cable and reset the wireless security...
    Other than that, u can also reset your router, there is a small hole for reset to factory default... Just put a pin inside...
How to get wirless security
Connect computer to the router no 1 slot on the back.
Go to computer open Internet Explorer.
Login to the Linksys Router page(usual address 192.168.1.1 after reset).
This will prompt for the user name password for you.
Leave username blank type password =ADMIN or admin
Login to router and go to wireless tab.
Below click on security tab.
On the wireless security tab and select this as WPA personal.
Click on save settings and reboot the router.
Your wireless network is now secured.
Mar 15, 2013 | Linksys Wireless-G Broadband Router
I need to set up secure access for 3 computers, HOW?
if your connecting all your computers wirelessly then you can setup encryption for your wireless network.
login to your router from a browser. go to 192.168.1.1
click on wireless
click on wireless security
set security mode to wpa2/wpa mix mode.
set the passphase. this will be the password you required to authenticate to your wireless network.
click save settings.
all wireless devices will need to be reconfigured to the new passphase/password in order to use your secured wireless network.
Feb 14, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Set password on linksys router
Connect the computer to the router and open the setup page. Go to Wireless tab and click on Wireless security sub tab. Change the security mode. See Linksys router How to
Nov 16, 2011 | Linksys Wireless-G Broadband Router
I need to figure out how to re-set my Linksys WRT54GX2 Wireless0G Broadband Router With SRX200
This article will guide you how to change the router's password and reset it to factory default.
NOTE: Accessing the router's web-based setup page requires a password. The default password of a Linksys router is "admin". For security purposes, it is recommended to change default password.
Changing the Router's Password
Resetting the Linksys Router to Factory Default
Resetting the Router Using the Web-Based Setup Page.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
How to change linksys wireless-G broadband router password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless then wireless security then WEP security change the password and save settings.Then restart router then you can connect wifi with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 21, 2010 | Linksys Wireless-G Broadband Router
I have a Linksys wireless 2.4 Ghz Broadband router. I have a secure wireless network set up, but it has a red x through it, and defaults to an unsecured wireless network. How do I fix this?
Access the router setup page from the working computer you can do this by typing 192.168.1.1 on the address bar of your internet explorer and that will ask you for a username and password leave the username blank and password is admin if admin did not work type your commonly use password, Once you're on the setup page you can go to Wireless tab and then Wireless security and there enable the security that you want to use......
Nov 11, 2009 | Linksys Wireless-G Broadband Router
Router password security
When you set your router up to connect to your broadband you had to access the router through your web browser.
Do the same again and then check the Wireless section and follow the instructions on screen.
Oct 14, 2009 | Linksys Wireless-G WRT54G Router
Adding a password
The normal method of accessing the LinkSys router is by going to your computer browser (IE or FireFox) and where the web address goes put http://192.168.1.1 Hitting the link in this post should actually bring it up.
The default setting for the LinkSys is blank for the user name and "admin" without the quotes for the password. That should bring up your router configuration application in your browser.
Click on the "Wireless" tab first, and then the "Wireless Security" sub-tab second.
There you should find your security key and the type of security setup on the router. This would be what you need to duplicate for your Netgear wireless phone.
If your settings aren't as they come by default, you can defualt the entire unit and reset it up, but hopefully that won't be necessary (only would be required if you just flat can't get to the admin panel of the router).
Hope that helps!
Dec 28, 2008 | Linksys Wireless-G Broadband Router
My router is locked
Go to the computer that the router is connected to and access the settings. (192.168.1.1) Go to a link where you can restoer the factory settings. Do it and shut down everything. Power everything on in this order. (Wait 1 minute between them)
1. modem
2. router
3.computer
4. other network devices
Then try to connect all of the devices to the network. Then set the router to your personal settings.
Apr 29, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
99 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
