Question about Foxconn NF4UK8AA-8EKRS Motherboard
ATX-SW motherboard manual
I have a Multivision AMD 2100+ XP PC, and need the manual for the ATX-SW motherboard. I have unplugged the start, reset, speaker, HHD led an power led wires from a 14 pin connector and need the manual OR instructions to find out where they all go. Prior to this the PC would not switch on even though it had previously worked perfectly.
  • Charles Fields
    Charles Fields May 11, 2010
    That is the incorrect model number for the board.
    Try again, maybe take a pic of the board.
map9966
  • 2351 Answers
SOURCE: Foxcon Motherboard pinout
Hi bwalker24,
This is a pic of how to connect you're LED & switches.
f0649db.jpg Enjoy!
Mike
Posted on Jul 27, 2008
ardmax
  • 155 Answers
SOURCE: foxconn motherboard pinout
Please follow this link and download the manual.
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0002117
Don't be surprise that the manual name is 662M03, it is still the right manual becuase is made for both type of motherboards.
Posted on Oct 01, 2008
the_fire
  • 432 Answers
SOURCE: Wiring front panel
if you go to this website
http://www.foxconnchannel.com/support/downloads.aspx
You can select motherboards --> socket 754 --> your make of motherboard and then download the manual which will tell you what the pins are for and where abouts they are on the motherboard.
Posted on Apr 13, 2009
DickCanFixIt
  • 948 Answers
SOURCE: I'd like to know the sequence to connect the
If your board is the one in this manual, the pins are located very close to the CMOS battery. Page 21 in that manual shows the diagram. Power LED is the top two left pins. Hard disc LED is the bottom two left pins. Power switch is the top two right pins. Reset switch is pins 3-4 on the bottom row. Pin 5 on the bottom is not used.
Posted on Apr 27, 2009
  • 127 Answers
SOURCE: i clean my computer! i
You better read the user's manual, where you have all the instructions.
Download it from:
http://www.foxconnsupport.com/download.aspx?models=en-us0000341&category=C000000001&series=en-us0000002&keywords=&sort=Motherboard%20Manual
Posted on Jun 29, 2011
HOW TO CONNECT POWER LED HDD LED RESET SW POWER SW IN BIOSTAR AMD N68S+ MOTHERBOARD
You can find the manual here: http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=498#dl The board is usually marked, also, although it is very tough to read the small print.
Oct 31, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
Ok! I have an ak32 shuttle mother board I'm wanting to upgrade. Over the years I've added newer graffics, audio, extra usb ports,and earthnet card. I built the pc in 2002. I had a cooling fan recently go...
the case isnt amd athlon 2100 xp, thats the processor, the case is either a atx or micro atx case, so refer back to the case and find out if it is a atx case or a micro atx case, then find a micro atx or atx motherboard so you dont have to replace all of your components
Jan 05, 2010 | Computers & Internet
ATX-SW Motherboard?
The manufacturer website should have what you need.
You also might need to know what chipset is on the board as well.
If it is the AMD board, go to www.amd.com
I hope this helps.
Good Luck.
Feb 26, 2009 | Computers & Internet
MSI K9AGM2 MOBO can't get the PC to turn on? If I reverse the +/- on the power SW it turns on but won't boot.
check your power connections go over manual ya got with the board retrace reinstalling board ya missed a step srr if ya got right power supply for board
Jan 04, 2009 | MSI K9AGM2-FIH - Motherboard - micro ATX -...
J6 Jumper Settings for AMD XP 2200 CPU
Driversguide had the manual in a ZIP file - downloaded and opened - all info in manual!
Jul 04, 2008 | Jetway AMD V400DBL KT400 ATX AUDIO LAN...
MOTHERBOARD UPGRADE
1 yes,
2 buy a new board and chip, trust me spend as much as you can and as much memory as you can afford and laugh at the snails pace of your old system
Nov 05, 2007 | MSI KM4M-L Motherboard
JetwayV266b (REV: 3.00) - Max processor speed??
Design ATX form factor 4 layers PCB size: 30.5x24.4cm Chipset VIA KT266A/VT8233A Chipset CPU Socket Support AMD Athlon 700MHz∼1.4GHz processor Support AMD Athlon XP 1500+ 2600+ processor Support AMD Duron 600MHz 1.3GHz processor Support 200MHz/266MHz (Double Data Rate) Front Side Bus frequency processors Reserves support for future AMD processors 2600+ is the highest it will go. http://www.machspeed.com/manuals/VIPER/V266B.pdf page 3
Sep 17, 2007 | Jetway V266B Motherboard
Foxconn NF4UK8AA-8EKRS Motherboard Logo
2,009 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
