Parallel ports. I am trying to run a program which requires the use of a parallel port however my laptop doesn't have one. I was wondering whether there is a way to change it to use a keyboard instead?
    Sergeant:
  • 239 Answers
Unfortunatly the only way to get around that issue is to purchase a parallel to usb cable. you can purchase them for pretty low prices.
hope this helps
please rate good.
Posted on Mar 02, 2009
Iam using Just Basic programmes to produce controller algorithms which require 8 bit Binary parallel inputs & outputs.My computer has a parallel port but I cannot find suitable instructions.Any...
As long as it is a physical parallel port, not a USB derived one, you can access the port direct.
A starting point I this wiki page which gives the pin out and port designations, to use with BASIC.
Parallel port Wikipedia the free encyclopedia
Mar 18, 2015 | HP Compaq nc6320 Laptop Core 2 Duo...
How can i reset the bios password in my toshiba satellite 4010 CDS? i already tried removing the cymos but it didnt work! pliz help!!!
Removing the clock battery doesn't do anything to the CMOS passwords. You can go buy a parallel port password key (I've seen them sell for $20, $30 bucks on eBay), or you can get yourself an old, parallel printer cable, and make a parallel port password key yourself (I did, took me about an hour's worth of time). If you decide to DIY, you can wire a parallel cable according to this:
Connect these pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, 18-25
Sep 10, 2011 | Computers & Internet
Sorry I have toshiba portege 100 but whwn I switch on open the bios password and I dont have the password tell me what I do??
To remove the BIOS password on this model, you'll need a parallel port, which comes on a port replicator or a dock cause the laptop doesn't come with one. After that, you'll need to make a parallel port password key (buy an old, parallel port cable, cut it, locate the schematics http://www.cgsecurity.org/wiki/CmosPwd, and connect the appropriate wires), and that'll do it.
Jul 26, 2011 | Toshiba Portege M100 Notebook
Sir, i am learning embedded programming, i want to dump the program in the micro-controller through parallel port but there is no parallel port in my system. 1) if i buy usb to parallel port is it work as...
It would be better to use the USB to do this since Parallel ports are almost obsolete in today's computers. If you have an open expansion port you could put a parallel port card in the computer no problem but why would you want to? I would have to have a much better understanding of what you where trying to do to give you any other advice about Parallel vs USB vs FireWire. I have seen app's that use the serial port and parallel port as you are mentioning but these are tools for doing dead PC diagnostics and even most of those use the serial port because of the improves Bidirectional abilities for data flow.
Feb 20, 2011 | Intel DG31PR Motherboard
I have a toshiba sat 35x0360 it has usb port no parrell port. i can't print my dos program. help
Parallel ports have not been use in a very long time.
You can buy a usb to parallel adapter, just google or try amazon
Aug 21, 2010 | Toshiba Satellite A135-S2276 Notebook
Lp 2844 will not work with my new laptop
You need a piece of software to create a Virtual com port, make sure you have the comms set correctly 9600, n, 8, 1 and print to that port, you will find it clearly marked in Device Manager. You can get a parallel to USB cable then you can use your driver set to LPT1
Nov 05, 2009 | Zebra LP 2844 Thermal Printer
Trying to connect from USB laptop to parallel printer
You can't have a double hook up to it,When the parallel port is used the usb port is disabled and when you use the usb port the parallel port is disable.This is done to prevent damage to the printer.You can network the laptop with the pc and print that way though
Jun 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
HELP ME
If you're running XP, you don't need an installation CD. I have that printer/scanner/copier and XP includes the driver. As well you can use XP's All Programs, Accessories, Scanner and Camera Wizard to scan. Unless your laptop has a parallel port or you have a Docking Station or Port Replicator, you'll need a Parallel to USB Adapter (see http://www.usb-ware.com/expresscard-parallel-port-sy-expc34-1p.htm). The cable my printer came with is part number C6680-80003 (see http://www.partshere.com/online/detail.asp?partno=C6680-80003). Hope this helps.
Oct 30, 2008 | HP PSC 500 All-In-One Printer
INSTALL AN UMAX ASTRA 1220P TO AN USB PORT ON A LAPTOP USING XP
The 1220P (P = Parallel) does not have a USB port and Windows XP does not support it.
Jun 16, 2008 | Umax Astra 1220P Flatbed Scanner
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
