Question about Microwave Ovens
The door latch has been pushed in so now the door can't close.
I have a Whirlpool Gold g2microwave, model # GH6178XPS 2.
Someone pushed in the latch inside the face of the microwave so now the door has nothing to hook onto and can't close. Is there any way to remove the face of the microwave to fix these latches? Any suggestions?
  • 52 Answers
Remove the outer casing so that you can gain access to the door locking mechanism, you will then have to use common sense to decide how to repair
Posted on Feb 26, 2009
I have to slam the door very hard for it to close correctly what would cause this problem?
Incorrectly adjusted door catch. They have movement on them to allow a tight seal due to the microwave capability.
I just found the specs and instructions on it.
Whirlpool Gold 2 0 cu ft Velos SpeedCook Oven
Mar 09, 2016 | Whirlpool Gold 2.0 cu. ft. Velos SpeedCook...
How can I close the oven door to my Whirlpool GMC305PRB01 Oven and Microwave combo?
We're very sorry to learn of your concerns regarding your Whirlpool® Microwave. We would like to inquire further about your review with you. Please respond back to this email address with your Reviewer ID, the name of the site you were contacted on (, name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance. Please include a brief description of your concerns in your email. Thank you.
Sep 12, 2017 | Whirlpool Microwave Ovens
Door error message on microwave whirlpool Gold rmc275pd
This indicates the door is not latching. The simplest fix is if it really isn't closed, and simply pressing on the door does the trick. Not so lucky? Latch mechanism itself may be dirty and not latching. Try cleaning it with standard spray kitchen cleaners and a good scrub, followed by a toweldry. Still no good? There's often an electronic interlock-- a place outside the latch, perhaps along the face of door, which must contact the body of the microwave oven. Again, try cleaning all possible contact areas. No? OK: microwaves are designed not to run without a tight seal to prevent emissions. perhaps the seal itself is damaged. Finally, and most unhappily, and expensively, the electronics module in the combo unit is shot. If the appliance is under warranty you're in like flynn; if it's relatively new but not under warranty, call the Whirlpool service 800 number and very politely but firmly remind them that this is really quite a new unit and certainly their products aren't meant to fail so soon... and surely they have a service bulletin because this can't have just happened to you... This will usually result in (oh happy day!) a free service call or (more common) a deal to sell the part at half price. Better than nothing!
Jul 03, 2012 | Whirlpool RMC275PD Microwave Oven
Replacing door handle of Whirlpool GH6178XP
I kept prying on the frame case until it disengaged, came loose and exposed the bottom screw.
Feb 17, 2009 | Whirlpool GH6178XPS Microwave Oven
Door catch not working on whirlpool MH1150xm
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Feb 02, 2009 | Whirlpool MH1150XM Convection/Microwave...
My Whirlpool microwave gold start button is not connecting. When I close the microwave door if I do not adjust the door, then press start, then press reheat and hold the reheat button for the duration of...
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type from us for $5 postpaid.
Nov 19, 2008 | Whirlpool Microwave Ovens
Door-activated power switch is loose and/or has a short
Fixed this problem! The door latches were greasy and sticking in the closed position (i.e., pushed down so not latching and engaging fully when the door was closed) and this created the problems described above. Solution was to squirt some Windex into the latch holes to dissolve the grease. The switches popped back into position (must be spring-loaded) and the door closed and latched properly, allowing the oven to function properly. I swabbed out the hole with a q-tip, let it dry for 20 minutes and all is well.
Nov 17, 2008 | Whirlpool MH6150XMS Microwave Oven
My door latch isn't letting me open my door, how do I open the panel to see what is broken. whirlpool model GT4175SPS
I would say you have a broken "release lever". This is the internal part which the release button pushes to open your door.
With the door not opening, you will have to remove the outer wrapper / cover, then you can see the works behind the control panel.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: but your exact model is not shown here.
But the info will be close enough to help you or someone you know check it, then you can call the supplier referenced at the link above to ask directly about your needed part(s).
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
Apr 26, 2008 | Microwave Ovens
Whirlpool mh2155xps microwave door handle
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your model number here: Your model does not show up. You can double-check it or look up model MH1150 - it should be close enough to help you see how it works. You may need to remove the choke, as shown in the attached sample drawing.
Sep 04, 2007 | Whirlpool GH6178XPS Microwave Oven
Whirlpool Microwave Door
if spring loaded push the pin in firs then hook on spring
Feb 12, 2007 | Whirlpool GH6178XPS Microwave Oven
Microwave Ovens Logo
273 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
