Question about Proscan PS36109 36" TV
RCA ProScan won't turn on. No power.
This is a RCA ProScan PS35123. Will not turn on ... simular to a blown fuse or no power to an outlet. The power source is working satisfactory.
3 Suggested Answers
likha
  • 790 Answers
SOURCE: RCA TV blown fuse
Hi
you have bad Rectifier Diode or Ic regulator.. check first the unregulated power supply before you go to regulated power section! then check,.
Thanks!
Likha
Posted on Oct 23, 2008
  • 2326 Answers
SOURCE: proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Posted on Jun 20, 2009
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Rca phd 50500
If no power, check your power plugs and wall outlet if its working. If not might have to open it, and check fuse and Power Supply Unit. Revert if anything.
Dec 28, 2011 | RCA Televison & Video
Rca f36650yx01 will not turn on
I feel foolish asking this but have you plugged it in? If you have it plugged in are you trying to turn it on with the remote? Have you tried to turn it on by pressing the on switch on the tv? Does the outlet work?
There could be any number of reasons for this. If the outlet has power (you can check this with any electrical device you have, plug it in and turn it on). So if the outlet has power AND the remote has fresh batteries AND the tv is plugged in to the outlet but still will not turn on even after pressing the switch on the tv...then you may have a blown fuse on the power input line into the tv. Take the tv to your local repair shop and ask them to look, if the fuse is blown they'll replace it and voila, your tv is fixed!
Please do not try to do this yourself, there is over 10,000 volts available at the flyback transformer even with the tv not plugged in.
Sep 07, 2009 | RCA F36650 36" TV
RCA D52130 CHASSIS CTC211A PROBLEM
Do you hear a click when you try to power it up? If no you may have a blown fuse. But if the fuse is blown chances are a short has caused that condition. Check the fuse to see if its blown and let me know and I will try to help you out with it.
Mar 27, 2008 | RCA D52130 52" Rear Projection Television
Parental Lock
Without an original remote, I'm afraid my friend, not much
Feb 11, 2008 | RCA TruFlat 27F520T 27" TV
GE 21GT660 does not power on
ok you can see the fuse at the power section! near at the cord coming to outlet! or maybe you heve defective fusibul resistor!
Oct 21, 2007 | GE 31GT660 TV
Televison & Video Logo
134 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
