Question about Toshiba Satellite A105 Notebook
My Toshiba laptop starts but does not load windows xp. The computer freezes, I can not run it on any other mode..whether it be safe, normal etc. The wireless card does not turn on. How can I get it to load windows xp? How can I backup my drive if windows does not load, I would hate to do a recovery and lose everything. Thanks
Check the diver usage or change the partition
Posted on Feb 26, 2009
Toshiba satellite is stuck safe mode it's running Windows XP.I tried restart f8 start normal a black screen with bunch stuf& starts in safe mode. What's wrong how can I get it out of safe mode?
First you should really consider upgrading from Windows XP because it is no longer supported and the chances of your computer becoming infected are extremely high.
Pressing the F8 command will only access Windows RE where you can access startup repair safe mode etc.
If the computer is only allowing you to go into safe mode that is a good sign that something is severely wrong with your OS.
While in safe mode you should try and access system restore, but this will only work if 1) you have turned on system restore and 2) your system has a restore point to access.
Have you added any new hardware or programs to the computer? If yes, then the new addition may be the cause of this issue. You can use device manager to rollback any changes or access programs and features to delete any program changes.
Other then that, if none of the above suggestions work I would strongly suggest booting from the disk media to access Windows RE too recovery the computer or just to re-image the computer.
Hope that helps.
Nov 08, 2015 | Toshiba Computers & Internet
Toshiba satellite L675 freezes after startup. Windows &
Boot the computer into "Safe Mode".
To boot PC into Safe Mode follow these steps:
1. Turn the computer on or Restart the computer
2. Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
3. Ensure that the Safe mode option is selected, not Repair Your Computer
4. Press Enter. The computer then begins to start in Safe mode.
5. When you are finished with troubleshooting, close all programs and restart the computer as you normally would
If the computer boots into Safe Mode you can try disabling Startup Programs, one of these might be causing your computer to freeze. To do this follow these steps:
1 Press Start. Type msconfig into the search bar and press Enter. For XP, click on Run and type msconfig there.
Mar 30, 2011 | Toshiba Satellite L675-S7062 Notebook PC
I need to do a System Restore on a Gateway 7322 Laptop
try running this virus FREE prog No cost- removes too...: http://www.f-secure.com/en_EMEA/security/tools/online-scanner/
Jun 29, 2010 | Gateway 7322GZ Notebook
I cant get my computer to fully boot up
This might happen if you install McAfee with applications running, or not restarting Windows, etc. I am not sure why you couldn't boot in Safemode, booting in safemode is exactly what you need to do to uninstall McAfee.
Mar 13, 2010 | Acer Aspire M5641 PC Desktop
Laptop start up problem
Have you tried performaing a recovery ?
Feb 15, 2010 | Toshiba Satellite Pro M10 Notebook
The laptop is not letting me get into safe mode after pressing f8 and choosing safe mode the laptop just goes into a loop and does not load windows
seems like an update have messed your xp. if you have a windows xp cd start with that and choose repair mode. then run checkdisk "chkdsk /R" instructions http://kb.wisc.edu/helpdesk/page.php?id=5097
you can also try hirens boot cd. with that you can try start your computer with hirens boot cd(mini xp) and run system restore or run checkdisk.
Oct 12, 2009 | Toshiba Satellite 1415-S105 Notebook
Toshiba A135-S4467 runs in safe mode but not normal (Vista)
The fact it starts in safe mode (which means it loads the basics for the pc to run and thats it) would indicate to me that there is something running in the backround at normal boot and also your cpu has a panic attack. Just wondering did this pc come with this version of windows or is it one you downloaded and installed yourself?? If its one you downloaded yourself (which it sounds like) get rid of it, because it is probs corrupted. Get another copy of it or to be quite honest I would get windows 7. Its better ,faster, and a lot less **** runs on it...The fact you changed your hard drive and still have the same problem it sounds like the copy of windows you have...Hope this helps...
Oct 10, 2009 | Dell Inspiron 2200 Notebook
Blue screen on my laptop, not able to load another window
reinstall windows - run your recovery disks, or boot from the recovery partition. If it still happens, there's probably a hardware issue - could be anything. Call Toshiba if still under warranty...
May 15, 2009 | Intel Computers & Internet
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
2.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.
Do not choose the option to press R to use the Recovery Console.
4.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
Problem with Toshiba Laptop U
this is clearly a no boot issue. you can actually do a power cycle first. remove the battery and unplug the ac adapter. press and hold the power button on the computer for 10 secs to drain all power inside the computer. turn on the computer. if it still freezes, tried to boot to safe mode. as soon as you see the Toshiba logo on the screen, start tapping on the F8 button as quick as you can to access Windows Advanced Boot Options. then choose safe mode only. if it doesn't solve the problem then most likely, your Windows XP is already corrupted. try to do system recovery. please be reminded that you will lose all data if you run the recovery.
i hope this helps.
Sep 16, 2008 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
