Question about Amana ASB 2623 Side by Side Refrigerator
Fridge not cooling
WHAT A GREAT SITE!! I left the freezer door open a crack for a couple of days by accident and now the fridge is not very cold. Freezer seems ok but there is some frost on the back wall of the freezer (bottom half only). The door to the freezer has been properly shut for 2 days now but fridge still not cooling. Can I fix this myself? How exactly?
  • 3 more comments
  • ColleenMcWag Feb 26, 2009
    Also I just noticed the ice maker is not working but I do hear the fan blowing or some kind of normal whirring sound.
    NEED A FRIDGE EXPERT! I left the freezer door open a crack for a couple of days by accident and now the fridge is not very cold. Freezer seems ok but there is some frost on the back wall of the freezer (bottom half only). The door to the freezer has been properly shut for 2 days now but fridge still not cooling. I the fan seems to be running, hear a whirring sound that sounds normal and I just noticed the Ice Maker is not working - no water in the resivoir. Can I fix this myself? How exactly?
    I have not defrosted it, does that mean I take everything out unplug it, wipe it down and then plug it back in? How long do I keep it un plugged? It is only 3 years old I did not think you would have to do this with new models?
    Thanks but what does a condenser look like and when I find it what am I looking for?
    Yes, I think I need a repair person!
  • 679 Answers
There is a condenser problem. the condenser is placed in back side of compressor.
check that first and let me know.
thanks
Posted on Feb 26, 2009
  • rockfixya
    rockfixya Feb 26, 2009
    folloe the following links for more information>>
    http://www.hometips.com/diy-how-to/refri...
    http://www.davesrepair.com/DIYhelp/DIYre...
    Thanks
  • 129 Answers
Check if there is leak on the back.. If not, Leave the fridge shut for some more time.. It shud return back to normal..
    Brigadier General:
  • 3,614 Answers
Hi there.
welcome to fixya.
initially try to defrost the ref and clean it.
  • 4 more comments
  • micromaster
    micromaster Feb 26, 2009
    just let me know if the above instruction has already done.
    tnx.
    micro
  • micromaster
    Problem on the condenser fan you can locate it under the unit. If the fan is malfunctioning,
    the refrigerator or freezer won't cool properly, or it will run
    continuously or not at all.
    also
    A malfunction on the water inlet
    valve strainer that feeds water to the ice maker becomes clogged.
    Check the ff:
    1. Unplug the appliance and disconnect the water
      supply.
    2. Remove the water line where it enters the valve--usually at the
      bottom edge of the unit.
    3. Locate the wire strainer and remove it.
    4. Clean
      the strainer with a stiff brush, using mild household detergent.
      Reassemble the component in reverse fashion.
  • micromaster
    first DO defrost the unit. unplug the unit and follow the procedure to defrost the fridge. at this stage we can identify the problem if the fridge still does not cooling.
    then DO the next steps>> i posted above this.
    update me.
  • micromaster
    The condenser fan is located under the unit.
    1. Test
      the fan with a VOM set to the RX1 scale.
    2. Disconnect the electrical
      wires to the fan motor and clip one probe of the VOM to each fan motor
      terminal.
    • If the meter reads from 50 to 200 ohms, the motor is
      functioning properly.
    • If the meter reads higher than 200 ohms, the fan
      motor is faulty and you should replace it.
    also clean the fan blades
  • micromaster
    it looks like this
  • micromaster
    better to contact a service engineer for that..
    thank you for using fixya.
    Let me know if you still need more further assitance.
    tnx.
    micro-
I have a 23' free standimg dispensing side by side ref. my ref is not cooling but the freeze part is working
when you open the freezer door do you hear the fan blowing?all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer and into the fridge side,there are ducts on the bottom left side where the air return sto the freezer,if that's blocked the fridge will get warm,also if the fan is blowing depending on your model you could have a damper,it's in the fridge section up top where the cold air blows into,all it is is a door that opens and closes to let the air in when the fridge section gets warm and then it closes when it's cold enough,if the damper is bad it won't open and let the air in,sometimes it gets stuck in the open position and things start to freeze in the fridge section.if you can't figure it out send the model number and i can see what model you have,open the fridge door,look up on the right side near the ceiling and you should see a tag with the model number.good luck and have a great weekend.also from the bottom up in the freezer,remove the second bin of food and touch the back inside wall of the freezer,if there's frost or like snow on the back inside wall of the freezer you have a defrost problem,let me know what you find.
Aug 07, 2012 | Kenmore Refrigerators
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Aug 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
LG Refrigerator has no cold air for fridge but freezer works fine
Sounds like the freezer fan(FF)is wearing out, This problem is very hard to diagnose because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. This repair costs parts and labor around $300.00
Jul 31, 2009 | LG Refrigerators
Freezer is cold cold....fridge is at approx 50 degrees
Hello lmk400,
Welcome to fixya,
Haier HRF10 Top Freezer Refrigerator
You siad, your freezer is cold cold....fridge is at approx 50 degrees What could it be ????????
1. The first thing it could be is that you have a freezer that is packet to the ceiling.
And so full that it's articles are covering the air vents found in the rear of the freezer.
They are need to be clear for the cold air to circulate form and to the fridge compartment.
Yes that is correct!
The freezer and the fridge both share the same air and to restrict the air causes the other
to get warm.
And will eventually burn out your fan motor or possibly your compressor!
OR
2. Your fan motor is already burned out.
Try checking this and clearing the vents.
It will take some hours to get cold and all night to reach peak temperature, if this is your reason!
If not you should then try turning off the fridge AND, then unplugging it for five minutes.
This should reset the system if there is an electronic glitch!
If all this fails you may be low on freon and need service to add some.
If the fridge was left open a crack all night or all day by accident it will cause this!
or if you go shopping and while unloading or loading the fridge with the door wide open running back and forth to the kitchen table for some extended time to!
Gather all the cold stuff near the fridge and put them in quickly!
I gave you a lot to work with and I hope the first two suggestions are the fix and solve your problem.
Let me know!!!!
Huuum
Please rememebr to leave me a rating at our fixya site!
Oct 21, 2008 | Haier HRF10 Top Freezer Refrigerator
Referidgerator side is not cooling?? Help?
I had this problem. Here's what I found: The cooling core on the freezer side was froze up. Covered in ice. I think the reason this happened was that the freezer door was held open by one of the slide out trays just enough to pull in outside air. Don't know how long it was like this. When I found it (and corrected it) the interior of the freezer was covered in ice crystals. From then on the refer side contents began warming up. There was no flow of cool air to the refer side from the freezer side (this cool air comes in from the freezer side fan near the top left side of the refer side). Freezer side was near zero temp and the unit ran continuously. Here's what I did: Removed everything from both sides (put it all in another fridge/freezer). Turned off (or unpluged) the fridge and left it off over night. I put towels under the fridge because there can be an over flow of water that could go to the floor. It works great again.
Nov 03, 2007 | Jenn-Air JCB2389G Stainless Steel Side by...
Amana ASB 2623 Side by Side Refrigerator Logo
176 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
