Question about ASUS R1F Tablet PC
Can't turn bluetooth device on (vista)
There doesn't appear to be any way of turning the bluetooth device on on my tablet. FN+F2 just shows me that wireless is turned on and that's it.
It came on once about a year ago when, for a brief time, I was able to use the bluetooth mouse.
Any ideas?
  • ebutzen Mar 17, 2009
    Bluetooth does'nt come on.
    switch is on
    cycling thrue with turns the bluetooth led on, but i can't connect to bluetooth devices, even to diveces I was able to connect before (PDA, mouse)
    Sergeant:
  • 386 Answers
Go into settings
device
then search for your bluetooth device
then pair it
Posted on Mar 15, 2018
SOURCE:
How to connect Bluetooth keyboard to my tablet? Do I need a password or pin?
hi Tammy.
Wireless Bluetooth
  1. Turn on the tablet. ...
  2. Make sure the wireless keyboard has new batteries.
  3. For Android tablets, go to Bluetooth settings and click "Find Nearby Devices." ...
  4. Turn on the wireless keyboard. ...
  5. If there is a "Connect" button (sometimes located on the back of the keyboard), press it.
How to Attach Keyboard to Your Tablet
Dec 08, 2017 | Tablets & eReaders
Enable bluetooth for kindle fire?
To pair your Kindle Fire with wireless devices that use bluetooth technology, like speakers or keyboards just swipe down from the top of the screen to show quick settings, and then tap wireless, tap bluetooth. Next to enable bluetooth, tap on.
Jan 15, 2017 | Amazon Kindle
I have an Apple IPad Pro. I bought a Bluetooth Keyboard Case from Amazon. I need to know how to get started. There doesn't seem to be an instruction manual. I'm in unknown territory.
It's fairly easy to set up usually. With the keyboard powered on there is usually a button that turns bluetooth on and a (usually) blue light will start flashing. At this point on the iPad you look in the bluetooth settings page and look for the keyboard to appear in the available devices. Tap the link to it and follow the instruction. The blue light should stop flashing and remain lit and the iPad BT settings will show that the keyboard is connected.
Oct 23, 2016 | Apple Tablets & eReaders
How do I turn on the bluetooth on my Z T PAD
You must turn on the tablet's Bluetooth radio before you can enjoy using any Bluetoothy peripherals. Here's how to activate Bluetooth on an Android tablet:
  1. Open the Settings app.
  2. On some Samsung tablets, touch the Connections tab.
  3. Ensure that the master control next to the Bluetooth item is set to On.
    Slide the icon to the right to activate.
    When Bluetooth is on, the Bluetooth status icon appears. It uses the Bluetooth logo.
To turn off Bluetooth, repeat these steps, but slide the master control to the left, to the Off position.
You'll also find a Bluetooth switch in the tablet's Quick Actions.
Dec 20, 2014 | Tablets & eReaders
How to pair bluetooth keyboard
On the tablet, Setting/Bluetooth, turn Bluetooth OFF.
On the Keyboard, switch on.
On the tablet turn Bluetooth ON.
You should see the tablet searching and when found click on the device and click PAIR.
Aug 14, 2014 | Dell Venue 8 Pro 64 GB 8" Wi-Fi Black...
Can't pair my Asus tablet with my wireless speakers. I get to thhe settings, bluetooth "on" then where do I go from there?
After turning Bluetooth "on", look if your device is set as "visible for other devices" into the same settings, and the press "Search devices". The speakers may appear and then tap on them to syncronize. If the tablet doesnt find the speakers it could be a problem of compatibility between both devices.
Aug 09, 2013 | Tablets & eReaders
I have windows xp,sp3 on a Siemens Fujitsu Lifebook T4010D. First of all, the tablet and the pen didn't work after installing the OS, also with all drivers installed. A few days ago, when xp was...
All of these drivers must be loaded;
LifeBook T4010D Driver Name Version Size (bytes) Audio V 6.14.1.3916 1,926,959 ACPI Device Driver V.1.21 9,437ACPI_Ext Device Driver (For model with Integrated Bluetooth) V.1.0 8,365 Bluetooth Device Driver (For model with Integrated Bluetooth) V.3.01.03F 15,615,696 Chipset V.4.30.1006 2,374,963 Fujitsu HotKey Utility V.2.30 1,119,189 Fujitsu Button Driver V.1.1.0126.2004 273,237 Fujitsu Button Utility V.1.0.0825.2004 976,478 Intellisonic V.2.0.1 4,077,455 LAN V.7.84.0.0 154,167 Modem V.2.1.41 883,675 MultiMedia Bay V.1.0.7.4 4,964,535 Radio Control (For model with Integrated Bluetooth) V.1.0 853,561 Smart Card Slot V.2.7.3.2 3,110,839 Security Panel Application V.1.2 3,653,534 TouchPad Mouse V.5.4.402.9 1,928,173 Touch Panel Driver V.1.03 22,505 TPM (For Model with Integrated Trusted Platform Module) V.1.7 17,542,125 Video V.6.14.10.3741 7,234,518 Wireless LAN Atheros (For 802.11a/b/g) V.3.1.2.21 3,980,525 Wireless LAN Atheros (For 802.11b) V.3.1.2.13
Jun 13, 2017 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Wireless LAN Adapter
Go to driveragent.com and let it scan the laptop to see what drivers are missing.
Aug 11, 2008 | IBM ThinkPad X41 Tablet PC
Problem with my tablet pc
Hi
The Satellite R10-S802TD doesn't have built in bluetooth device, however it's bluetooth compatible. any external bluetooth adapter will work. Toshiba recommends
PA3370U-1BTM Toshiba Bluetooth SD Card V1.2 or
PA3405U-1BTM Toshiba Bluetooth USB adapter as indicated you product's spec sheet.
Please post if you need further assistance.
Good Luck
Feb 06, 2008 | Toshiba Satellite R10-S802TD Tablet PC
ASUS R1F Tablet PC Logo
700 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Alun Cox
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
