Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Panasonic PT-51HX41E Convergence Problem
I have the ghosting effect which I believe it
is a convergence malfunction.
The green, blue and red are are not overlaying
which looks like a 3d image.
How can this be fixed on a Panasonic PT-51HX41E?
  • 1,139 Answers
Hello pzemenides,
I posted this in an eariler solution and there are numerous referencesto this type of problem on, however it fits in this case, sohere it is:
This denotes a convergence problem. Believe it ornot it would be cheaper for you to replace the two convergenceamplifiers and the biasing resistors. You would not actually bereplacing the convergence board since these devices are usually locatedon the deflection board in most cases. However in answer to yourquestion, the boards are easily removed, depending on your level ofpatience (lots of cables to move around), I would also advise you toeither mark down all of the connection you will remove, or take picturesof the board and its connectors. If you choose to just replace theAmplifiers and the biasing resistors there is a lot of information onthis site on how to do so: This will get you started:
1) Unplug the TV and then get a schematic of the TV I use or
2) On the schematic locate the STK392-xxx series IC packs (or whatever Convergence ICs your set is using) (usually attached to a large heat sink)
3) determine if the STK392s are 110, 120 or 150.
4) if the STK392-xxx's are 110s replace with 110s (forget that upgrade stuff it is a hit or miss game that I don't believe you want to get into), if they are 120s replace with 120s and so on.
5)Nowto replace the STKs: remove the module from the TV and unsolder theoldSTKs along with the bias resistors, and replace them with the newones(be sure to apply heat sink paste to the STKs when attaching them to the heatsink)
6) make sure there are no short circuits form your soldering job.
7) Reinstall the module and then turn on the TV.
8) do manual adjustment and the auto-convergence test and then things should be back to normal.
I hope this helps
Posted on Feb 26, 2009
2 Suggested Answers
  • 647 Answers
SOURCE: Panasonic pt-51hx41e
This is a convergence output IC problem. convergence board (main Board) would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Posted on Sep 27, 2009
I have this same problem with the PT51HX41E but in the convergence menu the green and red are allowed to move. but the blue on the right side of the screen is not allowed to move and it looks like its...
My first guess would be a bad convergence amplifier - this is common, although usually all three of the amplifiers in the integrated circuit die at the same time, which throws off at least two colors and creates a "bow-tie" effect. I surmise you have half of a bow-tie in blue only.
If you could look at the blue output waveforms with an oscilloscope, you would see right away if this is the problem (flat-line instead of sawtooth wave). It is possible that both of the blue convergence amplifiers are working, but one output is not getting to the blue deflection yoke.
Don't mess with the convergence anymore until you get this taken care of. Changing the convergence now will only make it harder to get it back to where it should be once the circuit is fixed.
Sep 22, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Have you checked the bias resistors for Exact Value. They normally change value when the stk's take a dive.
Dec 09, 2009 | Panasonic PT-46G40 46 in. Rear Projection...
Sep 26, 2009 | JVC AV-48WP74 48" Rear Projection...
I have a Panasonic PT-53WX54J that will not Converge
you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
Aug 23, 2009 | Panasonic Televison & Video
Ghosting in Red, Green and blue
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Sep 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic t.v projector
you need to replace both your convergence ICs they are both STK392-110 you can get replacments at the following link with free instructions with pictures.
Aug 02, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Think this is worth fixing?
trust ME when i say setting convergence after doing repair takes alot of time to do /you can damage set if you do not have service codes and values/ you also must have the hand unit that comes with set in order to even get into convergence circuit, call your repair shops ask if they have a good blue tube for set and how much would it cost to repair?ARE you sure blue tube has been removed from set.?
Jun 13, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
The convergence amps have most likely failed. That unit takes two STK392-110 (Sanyo) amps. For more reliability I'd have them changed using an STK392-150. They have a greater amperage and higher heat tolerance.
It's clearly a job that you want a qualified shop to do.. Call around and get some off-the-cuff estimates on what they charge to change out the convergence amps and tell them that you would prefer they use the 150's instead of the 110's.. They'll probably wonder how qualified you are. :)
Nov 13, 2007 | Panasonic PT-51HX41 51" Rear Projection...
PT 47 convergence IC's? box? both?
Always suspect the IC's first, digital convergence prblems are actually pretty rare IC's go everyday. I'd check partsore .com Generics usually work fine, they are probably STK392-110's but check to make sure.
Apr 16, 2007 | Panasonic PT-47WX49 47" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
647 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
