Question about Microsoft Windows XP Professional
Hi, i need a java source program on "Application Processing"in java only
  • 20 Answers
Just download java then
Posted on Feb 28, 2009
Java is not working
Hello there :
first you are going to want to ensure that your your current version of java is installed correctly and is not corrupted and if it needs to be reinstalled
download the latest java version and reinstall this . www.java.com
this should be able to take care of the problem that you are having ok?
best regards michael
Aug 23, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Websphere thread hungs frequently with Business Objects and it gets restarted automatically.
The issue usually manifests itself with a line in the SystemOut.log or equivalent reporting the following:
WSVR0605W: Thread "THREAD NAME : ID" (55c8824f) has been active for 600,112 milliseconds and may be hung. There are 1 threads in total in the server that may be hung.
If you do a thread dump in your App Server at this point, you will see something like so:
- waiting on <0x93d29020> (a java.lang.Object)
at java.lang.Object.wait(Object.java:429)
at com.crystaldecisions.thirdparty.com.ooc.OB.Downcall.waitUntilCompleted(Downcall.java:831)
- locked <0x93d29020> (a java.lang.Object)
at com.crystaldecisions.thirdparty.com.ooc.OB.GIOPClientWorkerThreaded.receive(GIOPClientWorkerThreaded.java:327)
at com.crystaldecisions.thirdparty.com.ooc.OB.GIOPClientWorkerThreaded.sendReceive(GIOPClientWorkerThreaded.java:353)
at com.crystaldecisions.thirdparty.com.ooc.OB.Downcall.request(Downcall.java:336)
at com.crystaldecisions.thirdparty.com.ooc.OB.DowncallStub.invoke(DowncallStub.java:583)
at com.crystaldecisions.thirdparty.com.ooc.CORBA.Delegate.invoke(Delegate.java:579)
at com.crystaldecisions.thirdparty.org.omg.CORBA.portable.ObjectImpl._invoke(ObjectImpl.java:125)
at com.crystaldecisions.enterprise.ocaframework.idl.OCA.OCAi._InfoStoreEx3Stub.queryEx3(_InfoStoreEx3Stub.java:62)
at com.crystaldecisions.enterprise.ocaframework.j.a(Unknown Source)
at com.crystaldecisions.enterprise.ocaframework.j.find(Unknown Source)
at com.crystaldecisions.enterprise.ocaframework.AbstractServerHandler.buildServerInfo(Unknown Source)
at com.crystaldecisions.enterprise.ocaframework.AbstractServerHandler.buildClusterInfo(Unknown Source)
at com.crystaldecisions.enterprise.ocaframework.aa.for(Unknown Source)
at com.crystaldecisions.enterprise.ocaframework.ServiceMgr.for(Unknown Source)
at com.crystaldecisions.enterprise.ocaframework.o.a(Unknown Source)
at com.crystaldecisions.enterprise.ocaframework.p.a(Unknown Source)
at com.crystaldecisions.enterprise.ocaframework.ServiceMgr.getManagedService(Unknown Source)
at com.crystaldecisions.sdk.occa.managedreports.ras.internal.CECORBACommunicationAdapter.connect(Unknown Source)
at com.crystaldecisions.sdk.occa.managedreports.ras.internal.RASReportAppFactory.a(Unknown Source)
at com.crystaldecisions.sdk.occa.managedreports.ras.internal.RASReportAppFactory.openDocument(Unknown Source)
at com.talic.pi.utils.ReportingEngine.generateReport(ReportingEngine.java:86)
at com.talic.pi.cms.dao.ReportsDAO.generateReport(ReportsDAO.java:31)
at com.talic.pi.cms.component.ReportGeneratorComponentImpl.generateReport(ReportGeneratorComponentImpl.java:41)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at com.ibm.ws.sca.internal.java.handler.JavaReflectionAdapter$2.run(JavaReflectionAdapter.java:152)
The cause:
This is mainly caused by reports that take a great deal of time to execute causing the application server to report that the processing thread is 'hung'. A worse side effect of this is when the application server runs out of threads and is unable to process any further requests due to these hung threads.
The solution:
The problem is due to the fact that the Corba Timeout has not been set. You've missed the clientSDKOptions.xml in your deployment. This causes the RAS SDK to probably never timeout its call to the RAS.
Create a file called clientSDKOptions.xml and place it in your application's WEB-INF/classes folder, or alternatively, you could place it in a server wide classpath folder like 'applib' on OC4J or $WASPROFILE/properties on WebSphere.
The contents of the file should be as follows:
<CrystalReports.ClientSDKOptions
xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance"
version="2"
xsi:type="CrystalReports.ClientSDKOptions">
<CORBARequestTimeout>120000</CORBARequestTimeout>
</CrystalReports.ClientSDKOptions>
Restart your app and your done. Your call should now timeout within 2 minutes (something with you can change) and you can say goodbye to your Hung Threads issue.
Jul 05, 2009 | Business Objects Full Version for PC
Sony ericsson Handset showing ''Operation failed error''
This error occurs when your phone is checking the signature of a digitally signed java application and there is no match or is unable to do so. The most common cause is that the signature is expired. Try setting the date backwards on your phone - let's say one or two month :-) and have a look! I bet it works now....
Mar 21, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Problem in java
This is how to create notepad application in java:
http://www.dreamincode.net/forums/showtopic66176.htm
Also, you can take a look to this one and download free source codes:
http://forums.targetlife.com/showthread.php?t=259
Enjoy it! Good luck
Mar 04, 2009 | Sun Java Programming Language (cdj-275)
I need a chat application in Advance Java
Iam ready to develop chat application in Java.
please give more details about application.
Feb 27, 2009 | Sun Java Programming Language (cdj-275)
I need java source code for chat application reply
Your answer is here:
Solution # 1
http://www.web-tech-india.com/software/jsp_chat.php
Solution # 2
http://www.topshareware.com/java-source-codes-for-chat-application/downloads/1.htm
Solution # 3
http://www.codeproject.com/KB/java/java_applet_chat_with_gui.aspx
Good luck
Feb 26, 2009 | Computers & Internet
What is servlets?
Java Servlet technology provides Web developers with a simple, consistent mechanism for extending the functionality of a Web server and for accessing existing business systems. A servlet can almost be thought of as an applet that runs on the server side--without a face. Java servlets make many Web applications possible.  » Read More The reference implementation is included in the Java EE 5 SDK and also in the open-source Java Platform, Enterprise Edition (Java EE) application server, available through the GlassFish project, which you can download from java.net. The reference implementation source code is available from the servlet-sources project on java.net.
Dec 29, 2008 | Microsoft Windows Vista Ultimate Edition
How to program into an MP4
Hi Myeco,
I have not done any development on an MP4 player but based on the little experience I have in developing applications for phones I was able to develop and successfully deploy an application into a sony ericsson phone.
I used J2ME (Java ME). This is mainly a Java Technology used for developing applications for devices with small processing power and memory.
Transfering from one device to another can be done via Infrared/ bluetooth/ Cable.
J2ME can be downloaded freely.
May 21, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
24 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
