Question about Lexmark X73 All-In-One InkJet Printer
Can't seem to find where to hook my phone lines in and out.
  • 15,935 Answers
Lower left side of the Left side.
(may have a cover over it)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Feb 26, 2009
  • 1 more comment
  • blueextc3221
    blueextc3221 Feb 26, 2009
    pretty sure there is no phone out - you will need a jack diplexor (splitter)
  • blueextc3221
    this will split your line at the jack.
    One line to your phone, one to the all-in-one.
  • blueextc3221
    blueextc3221 Mar 01, 2009
    Im DYING to know where you found the jack.
    Because your unit was so old, it wasnt listed on lexmark's site.
    So i went with the nearest model # to yours. (x83)
    Also, are you SURE you wanted to rate my answer Inappropriate?
    This type of rating is reserved for answers about different topics than the question (ex - if I answered your All-in-one question with a radio answer), vulgar, abusive, or inappropriate language... or where the solution had nothing to do with the problem.
    Please reconsider raising the rating - as a "thanks for trying" severely lowers our percentage rating.
    Most experts do not even attempt to answer free questions because of askers giving ratings like this.
    Some is the fault of FixYa not wording the rating correctly. IMO there should be - INAPPROPRIATE, NOT HELPFUL, HELPFUL, AND FIXYA.
    While the answer may not be a "fixya" in your case, I took the time to answer your question and a "helpful" rating is not detremental and appreciated.
    Thank you.
Installed Cox Digital Telephone. They disconnected my fax line. I have a Dell 968 printer and what I read on line is that it is not compatible with Windows 7 and that I would have to update the prin
Most newer fax machine seem to short line 1 and 2 together and this will cause a VOIP modem "called an eMTA" to go off hook. Your fax machine should have come with a phone jumper that has only a single line "2 wires inside it", you should be able to use that jumper to attach your fax machine to your house phone wiring. If you use a standard phone line jumper it has both lines "4 wires" and can cause your eMTA modem to go off hook which could be why it was disconnected.
Jan 30, 2013 | Computers & Internet
Cannot receive faxes
The storm has likely damaged the phone line, or the ADSL microfilter (if you have one). Which is why it thinks a phone on the fax line is off the hook. Check your line for breaks and your ADSL filters for a blown filter.
Sep 18, 2007 | HP OfficeJet Pro L7580 Color All-in-One...
Hooking up the HP 640 Fax
there are 2 phone jacks on the back.. one is marked with an ( L ) or is spelled out (Line) ...the phone line from the wall should be plugged into that jack marked L or Line
Jun 04, 2010 | HP 640 Inkjet Fax Machine
No dial tone pressing hook, NG and Poor line condition transmission report on sending and receiving. Confirmed good dial tone on line in and on phone on ext. Copy, display, everything else fine. I hear...
Make sure that you have your telephone line from the wall jack plugged into the port on the fax that says "LINE" and that your telephone is plugged into EXT.
All your cables and jacks seem like they are working since your phone gets a dial tone, the onyl thing could be that the wires are mixed or the modem on the fax is broken.
Thanks,
Pat
Mar 27, 2010 | Brother Multi-Function Center MFC-240C...
I can't fax in our out...Don't know about set up
The fax phone line goes to LINE Port
Answering machine goes to TEL Port
Jun 19, 2009 | HP 1040 Plain Paper Inkjet Fax
Machine shows "phone off hook"
Hi there
check where your phone cale goes into the machine you will proberbly find two sockets one marked phone and one marked line the phone line needs to go into the one marked line and a phone handset in the one marked phone if this is correct try ringing yor line that the fax is plugged into see if you get a ring or engaged tone if you are getting engaged unplug the fax and try again if this now works the chance is that the modem board in your fax has failed and will require replaceing
Regards AL "alstech"
May 18, 2009 | HP Officejet 5510 All-In-One Thermal...
Having trouble faxing
make sure the phone jack is plugged in to the LINE input in the back. If this does not work try pressing the ON HOOK button and listen for dial tone.... If that does not work hook a regular phone the the phone line going to the fax machine and make a call checking that no static or pops are on the line ....Good Luck
May 03, 2009 | Office Equipment & Supplies
Problem faxing
Unplug the fax at the wall jack and hook up a regular phone. Listen to the dial tone. It should sound like a regular dial tone.
Next, plug the fax back in and call the machine from a regular phone.
You should hear fax tones.
Sep 07, 2008 | Office Equipment & Supplies
2 Telephone lines and one phone jack
Most of the Cordless 2 line phone BASE UNITS have the connections on the back for line1/line2 or seperate line 1 and line 2 connection. If you have the type of phone with the line1/line2 jack you have to be sure that both lines are on the same wall jack, otherwise make sure the phone you purchase has seperate line jacks and you will have two phone cords going to the base unit.
Jul 26, 2008 | Lands Phones
Fax function doesn't work
check your phone lines.then connect it to the machine.press on hook dial.if dial tone is not there you may need a service engineer.
Apr 05, 2007 | Ricoh Aficio 2018D All-In-One Laser...
Lexmark X73 All-In-One InkJet Printer Logo
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
