Question about Gateway 7330GZ Notebook
Gateway 7330GZ PC Notebook won't show the dvd-rw drive
I tried going to bios and turning it off and back on , that worked for a couple of days then quite. a coupe of weeks later it came on and stayed on for a couple of days and went off. A new replacement drive is $160 ,but can buy an external drive for about $60, what to do?
  • oldgrouch Feb 26, 2009
    No. the dvd-rw disc in the side of the laptop,if you put a disc in it lites up breifly ,but you access the drive
  • 1,800 Answers
Do u mean the hard drive??
Posted on Feb 26, 2009
  • Jalal Sordo
    Jalal Sordo Feb 27, 2009
    well u can check ur bios version and upgrade it.
    that would fix a lot of probs especial for optical drives.
    plz give a good feedback so we can help others.
My gateway laptop mt6707 does not recognize it's DVD player
try external drive.if this work,your dvd drive is bad
Dec 17, 2013 | Gateway MT6707 Notebook PC
CD/DVD-RW will not burn discs, get I/O error message. Cleaning lens and defragging HD did not solve problem. The Gateway website does not have a bios flash available.
It is sometimes difficult to burn on latop DVD drives as they don't have a lot of life-span, but, you could try a new DVD as the media itself can be the problem, you could get a couple of bad discs in a row.
If you can try a replacement drive or slowing down the burn speed.
Let me know how you get on
Mar 23, 2011 | Gateway 7330GZ Notebook
Can someone provide me online recovery disk of gateway 7330gz
You must set the boot sequence of the system to cd/dvd rom first which will enable the system to look for booting files in the disc in the first instance.
In your case your system is booting direct from hard disk. Boot sequence can be changed ib the bios setup of your system.
In some laptop models the restore files can be accessed by pressing function keys while system starting.
Mar 12, 2009 | Gateway 7330GZ Notebook
My gateway 7330GZ with windows xp doesn't se my dvd-rw drive
un-install the drivers,then re-install after first restarting the unit.
if that does not work,replace the drive with a new one.
Jan 31, 2009 | Gateway 7330GZ Notebook
Notebook Gateway 7330GZ won't boot
Hm...That sounds like either the motherboard is dying/dead or a device is (such as the hard drive). I would suggest removing one piece at a time and see if you can get past that screen. The most annoying would be if it is the DVD drive since it's probably the most difficult device to remove from the laptop. (If memory serves it involves removing a certain screw from the bottom and then getting under the keyboard so you can push it out).
Do you have a second stick of RAM installed? Mine died a while ago and caused real heck with my 7330GZ.
Nov 16, 2008 | Gateway 7330GZ Notebook
CD\DVD RW DRIVE
replace the drive, all drives go out eventually.
Jul 26, 2008 | Gateway 7330GZ Notebook
Gateway notebook
such problems normally i associate it with ram(memory) and or hard drive. so what i suggest yu do is first lose the area where the ram is, bring it out then put it back in place. then restart yr system n see if it hangs. if u have more than one ram in yr system then try testing then one after the other not just putting the 2 at ones..next try removing the hard drive then power it on n see what happens.next if u can enter into the bios setting good there yu can restore default settings fto manufacturers design.
b4 bringing out any hard ware from yr system try removing batteries first then from power as well.
good luck as u do this
n do come back to tell me the extend yuv gone
May 29, 2008 | Gateway 7330GZ Notebook
GATEWAY 7330GZ PC NOTEBOOK
This link will provide you the required information.
Specifications
Part Number: 4997Gateway 7330GZ Notebook
System Gateway® 7330GZ Notebook Processor Mobile Intel® Pentium® 4 Processor 532 with HT Technology
(1MB L2 Cache | 3.06GHz | 533MHz FSB) Determine Your Processor Speed
Chipset Intel® 852GME Screen 15.4-inch Widescreen Ultrabright TFT WXGA
  • Maximum Resolution: 1280 × 800
  • Maximum Color Depth: 32-bit (16.7 million colors)
  • LCD maximum refresh rate: 60 Hz
Memory 512 MB DDR (1 × 512 MB), 333 MHz, DDR
Expandable to 1.5 GB Video Intel® Extreme 2 Graphics
Dynamic Video Memory Technology (DVMT) supports up to 64 MB shared video memory Audio PC2001 Compliant AC '97 Audio
Built-in Stereo Speakers Hard drive 80 GB HDD (4200 RPM) Optical drive DVD +/- RW Multi-Format
  • Write maximum: 8X DVD +/-R, 4x DVD +/- RW, 24x DVD+R DL, 24X CD-R and 10X CD-RW disks
  • Reads maximum: 8X DVD-ROM Disks, 8X DL/+RW, 24X CD-ROM disks
Media reader 6-in-1 Digital Media Manager
Compact Flash, Micro Drive, MultimediaCard (MMC), Secure Digital (SD), Memory Stick, and Memory Stick Pro Modem 56K ITU V.92 ready Fax/Modem Network 802.11g integrated wireless (up to 54Mbps)
10/100Mbps integrated Ethernet LAN Pointing device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces
  • 4 - USB 2.0 Ports
  • 1 - VGA External Connector
  • 1 - IEEE 1394 port
  • 1 - RJ11
  • 1 - RJ45
  • Microphone In
  • Headphone/Audio Out
Battery 8-cell Lithium-ion Dimensions 1.6-inches H × 14.0-inches W × 10.4-inches D Weight 7.5 pounds (8.65 pounds total travel weight)
Mar 24, 2008 | Gateway 7330GZ Notebook
Disc drive will not recognize blank discs.
let's make sure that's a DVD RW disk shall we? check the front and make sure it says DVD RW..if it's DVD R, then it can't write.
Mar 17, 2008 | Gateway 7330GZ Notebook
Gateway 7330GZ Notebook Logo
159 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
