Question about LG LRE30755 Electric Kitchen Range
Oven temperature low
Oven temp is about 25 degrees low. I've tried adjusting following the instructions in the owners manual but need to change it more than allowed. Is there something else that can be done? Is there a way to change the settings more? Can repairman do it?
It sounds to me like you are using the convection oven. When you are using the convection oven it will heat 25 degrees lower due to the circulation in the oven. This is normal.
Posted on Jun 03, 2009
Can't adjust oven thermostat
Has this just happened or have you suddenly just tested the oven temperature with a RELIABLE thermometer? Some cheaper thermometers can give a false reading. Check with a accurate thermometer first and place it at intervals in different parts of the oven ( it does vary) and take the average
Jan 17, 2014 | GE Profile JK915 Electric Single Oven
Amana Model ACS3350AS Oven temp is 25 degrees hoter than display. What do I need to repair it? How do I find a manual for this. This came with the house.
Oven temperature can be adjusted for a maximum of 35 degrees farenheight.
Refer to the page 11 of your owner's manual.
A PDF version of the owner's manual can easily be find at
http://shop.amana.com
Jan 11, 2011 | Amana ACS3350 Gas Kitchen Range
I think the oven is not getting hot enough,i have baked three
Buy an oven thermometer to check if the temperature you set the oven at is accurate. You may have a faulty thermostat, but if the temp is only off by a little, you can calibrate the temp setting on the oven by as much as + or - 25 degrees. If you have an LCD screen, then most likely you can adjust it right on there. If not, then the backside of the oven knob can be adjusted + or -. by moving a set screw and turning as needed. Your owner's manual will have a more detailed explanation on this procedure. Douglas
Jun 13, 2010 | KitchenAid 30 in. Architect II Series 4.3...
Need to adjust oven temperature on a Croley gas range
you shouldnt need to adjust the burners for a temp problem.
the control has a built in calibration setting and it should be described in your owners manual.
if you dont have the manual, then try to set the oven temp to max, 550, and then hold the bake button in for 10 to 30 seconds. after that it should beep and show you a 2 digit number like 00. that is the calibration mode, then you can adjust it up or down +/- 35 degrees. try to make a small adjustment first like 10 degrees and see how it bakes.
if it takes too long to bake, then use + degrees, if it is burning things then lower -10 degrees.
hope that helps you.
Jan 03, 2010 | Crosley CE35100AA Electric Kitchen Range
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Oven doesn't reach temperature
Page 6 of the owner's manual:
Adjust the temperature calibration.
Jun 26, 2008 | Whirlpool RBD305PD Electric Double Oven
American Range ar6b-24rg
If you oven temp is off by +- 50 degrees, thermostat needed to be change. to check and adjust the oven thermostat usually we place the oven thermometer in the center of the oven, run the oven at 350 degrees for minimum 30 minutes and check the oven temperature, It should be +- 25 degrees, if it needed adjusting, there is the adjusting slot screw in the center of the thermostat stem, to adjusting it ( do not turn thermostat stem during adjusting ), turn adjusting screw counter clockwise to raise the the temp, clockwise to lower the temp, turn it a little at a time and wait 15-30 minutes before do the next adjustment until the temp match with the oven knob. To adjust the oven burner air and gas mixture, first turn the air shutter close, you will see yellow flame, then open the shutter until the yellow flame disappear and them open it a little more, now you are done. For the oven uneven cooking? you may have a bad oven burner tube, during operation some of the flame may be lift off, disappear or flame being uneven, you can check it with the kick panels off to see the flame, if these are the case, you needed to change the oven burner tube,
Feb 04, 2008 | American Range AR-4B-36RG-CL Gas Kitchen...
Inacurate temp
The follow suggestions apply if you are at sea level, or a bit above. If you are in the mountains, you'll have to compensate for altitude issues. You need an accurate thermometer to be spot on. One way is to use an electronic thermometer. Another is to set the oven to 217 degrees, insert a small pan of water into the oven, with a metal tray or pie tin on a lower rack to catch spills and see if it eventually boils. If the water didn't boil, you can adjust the temperature upward in  5 degree steps (see your owner's manual for details). If you've lost your manual, you may be able to go on-line and get a pdf copy of your manual.If the water does boil, you know your oven is accurate within 5 degrees. You can then proceed to re-do the experiment at 212 degrees, if you wish. Then you may use the data to adjust the oven temperature.
Dec 03, 2007 | Maytag MGR6772 Gemini Gas Kitchen Range
Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
LG LRE30755 Electric Kitchen Range Logo
302 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
