Ok, I need help, im stumped. I have a 96 Cadillac Devillle 4.6L and I've been having problems with overheating. I've done alot of work within the last week and nothing seems to work, I've replaced the following:
Radiator
Water Pump
Water Pump Belt
Heater Core
Temperature Sensor
Thermostat
Radiator Cap
*Fans come on around 222 degrees. There's white smoke coming out of my expansion tank when I remove my radiator cap. Checked my oil, and there's no coolant in it. Also, my air conditioner doesn't blow through the vents, don't know if that would affect anything.
Please help, I'm going crazy.
Hi.. all I have a 96 deville that just recently been giving me problems my caddy has a light oil leak from the oil pan.beside that wen I start my car it shakes relly bad for the first couples of minutes and as I drive the car it throws white smoke out the tailpipe relly bad can any one please help me going crazy trying to figer out what can it be
OK, will do that.......what's a head gasket leak??? The same as them being blown or an easier fix?
I have a 1996 cadillac deville with the same problem it keeps overheating however my fans don't kick on at all....
96 deville sedan, the 4.7 liter. it has two fans behind the radiator and i have yet to see them turn on, the car will stall and overheat when the coolant temp reaches 200 F, but normal running temp is 197 F . so if i stop for a few minutes at a red light it overheats and stalls.
My fans are coming on. Tested off the car and on. Where is the temp sensor located?
