Question about Lanier Office Equipment & Supplies
I have a lanier 6713 that streaks and makes dirty copies. Ive cleaned the coronas and its not any better
  • dabarnes23 Feb 27, 2009
    I have figured out that the drum still has toner on it after making the copies...Possibly whatever cleans the drum is bad? Any ideas how to get it out?
Cleaned the optics yet?
Are the drum and blade ok?
Maybe Fuser?
Posted on Feb 27, 2009
  • Anonymous Feb 27, 2009
    I've only worked on a couple of those, and it was years ago.
    I'm not familiar enough to give you specific instructions in the removal process, and if the drum is dirty then the drum cleaning blade has failed and needs to be replaced
Black streak down paper on HL 3170 CDW printer
Check the drum cylinder for a) a clot of fiber inside the corona wire channel; b) a groove worn into the surface of the coating. If those OK then check the fuser (inside at the back). Look for either a dirty fuser sleeve or a shiney track worn through the coating on the fuser. Dirty can be cleaned - shiney cannot be fixed
May 12, 2014 | Brother International Brother HL-3170CDW
Paper not clean when printing/copying How do I
first the paper can be dirty in a lot of ways...
i.e.
If you have dark "background"or small black dots, the problem is in developer and it need's to be replaced, or cleaning blade or drum.
If you have streaks on copy, the problem can be in drum and cleaning blade or fixing roller.
If the copy is too light, the problem can be in dirty optics or bad transfer corona.
There can be a lot of things... better call service for preventive maintenace, they will change all that is needed according the number of copies that machine has.
Hope that helps!
Sep 01, 2011 | Toshiba E-Studio167 Copier
Vertical Lines through incoming faxes and copies.
Sometimes you may see vertical streaks/black lines
on the faxes you receive. Either your FAX/MFC's
primary corona wire for printing may be dirty, or
the sending party's fax scanner may be dirty. Clean
your primary corona wire (see pages 13-18), or ask
the sender to make a copy to see if the problem is
with the sending machine.
Cleaning the Drum Unit
We recommend you place the drum unit on a drop cloth or large piece of
disposable paper to avoid spilling and scattering toner.
1 Carefully turn the drum unit upside down.
2 Clean the primary corona wire inside the drum unit by gently sliding the tab
from right to left several times.
3 Return the tab to the Home
position (  ) before
reinstalling the drum unit.
Jan 31, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
The ride side of my faxes and copies are black, any ideas?
Sometimes you may see vertical streaks/black lines on the faxes you receive. Either your machine's
primary corona wire for printing may be dirty, or the sending party's fax scanner may be dirty. Clean
your primary corona wire. I recommend placing the drum unit on a drop cloth or large disposable paper
1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
2. Return the tab and snap it into the Home position, (Caution: If the tab is not at the Home position, printed pages may have vertical stripes).
3. Reinstall the drum unit into the machine.
4. Close the front cover.
5. Plug in the power cord first, and then plug in the telephone cord.
or ask the sender to make a copy to see if the problem is with the sending machine.
Try receiving from another fax machine.
If the problem continues, call Brother Customer
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Dec 31, 2010 | Brother IntelliFax-4100e Fax
Black streaks on copy
This can be anything from something on the glass to charge corona dirty, laser dirty, drum or blade or fuser rollers need to be replaced. For the average person, the best you can do yourself is to make sure glass is clean. Question..... do you get this line if you're printing also? If yes then that would eliminate the glass and has to be something inside. If no, then look very carefully at the glass and long skinny glass on top, if it has that, for white out or something on the glass. Sometimes you won't even see spot unless you look at just the right angle. Good luck. Please rate this if it helps.
Jul 03, 2009 | Sharp SF 2020 Copier
Dark copies with overprinting
Cleaned the coronas as per instruction book. Done this before but this time it made a difference.
May 07, 2009 | Lanier 1205 Copier
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
Dirty Edges
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
Streaks on faxes and copies but not on printed documents
Clean the glasses on top!!! Your CORONA lens is dirty!!! it must have some cleaning brush or bar near the side!!!
Jan 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Lanier 6735 Copier
Sounds like you need a new cleaning blade. It is located inside the process assy behind the drum.
Aug 10, 2007 | Lanier 1205 Copier
246 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Adorjani Laszlo
Anthony Karuku
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
