Question about Sharp Aqous LC-26D5U Television
SHARP AQUOS LC-52D64U TV WITH NO POWER
THE POWER LIGHT IS ON BUT FLASHING BUT CANT SEEM TO GETTHE TV TO TURN ON.
  • Anonymous Mar 27, 2009
    TV shut off and the power and opc light are flashing. Nothing else is responding. Anyone know of a remedy?
  • mnowak49 May 25, 2009
    power light and op light flashing
I had one that was doing the same.   swapped out a back light inverter board... fixed it.  this doesn't mean that my fix will be your answer. to help find which one is of the 2 sides is bad..unplug power to the board one side at a time & half the lcd will fire up.  good luck
Posted on Apr 01, 2009
I have a Sharp Aquos lc-52d64u TV that wont stay powered on.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 07, 2015 | Sharp 52"" aquos lc-52d64u 1080p...
Why won't it power on?
The power supply may have failed. There may be an open fuse internally.
May 20, 2015 | Sharp 52"" aquos lc-52d64u 1080p...
Sharp
Sorry to say, but TV is done for. I had the same exact issue with the same exact size and model. I had two different repair shops take a look at it and they both came to the conclusion that the system board went bad and was not worth replacing. I sold mine for parts
Jun 02, 2014 | Sharp 52"" aquos lc-52d64u 1080p...
What is the TV Tuner Signal Board part number for the Sharp Aquos LC-52d64U?
That the board which it have a square aluminun box at the edge of the board with a rounded bolt sticking out for inputs like ANT. input and AV inputs for like wires components inputs like multi colors like YRW,YRWGP holes for AV inputs also have HDMI hubs inputs for the high Def Pic.There are 6 HDMI inputs hubs for the tv Sharp Aquos LC-52d64U.Tvs Tuner board signal boards are also have to been known names to called as the tvs Main Logic boards and the tvs Mother boards also.U are fixing ur tv u must have to take it parts already.U can also compare the pictures between the tv Tuner signal board u are taking aparts out of the tv and the tv Tuner signal board you are buying they'll look axactly alike.The sticker of the serial numbers of the boards a few numbers in the begining on the tv Tuner signal boards should be the same also.
Dec 06, 2011 | Televison & Video
We cant turn on the Sharp Aquos TV and the power and opc buttons are flashing.
Ur power light stable green first turn on?Then awhile click,POWER and OPC flashes.Tries on/off couple time,will work.Not then ur backlight video board is dead.
Dec 25, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-52D64U Won't Turn On
I have fixed many sharp lcd tv's with a reset. If one appears to have no defects like bad capacitors, fried inverters, broken panel, ect. and the power light is flashing steady or not on at all a reset may help. There is a lot of bad information regarding the procedure though. The correct procedure is to unplug the tv, hold volume down and channel up at the same time and plug it in. Release those buttons then push the power button. Did it start? Great! I have no idea why so many seem to need this. If there truly is a problem this will only work temporarily or even momentarily but many will be fixed for good.
Apr 10, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aqous LC-26D5U Television Logo
589 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
