Question about Sony Televison & Video
Flash focus the green is not focusing in and it looks as if the objects are as if you are seeing in double vision. How can this be adjusted? the flash focus isn't alining.
    Scholar:
  • 41 Answers
This sounds like a convergence issue. I can tell you that the site that Jean posted will not fix this problem and could even make things worse. That sight pertains to a specific problem that is common in some Sony sets and should not be used to try to fix any other issue.
Please keep in mind many things can go wrong with TV sets and you should really do a lot of research before attempting any adjustment and or repair. There are high voltages present and they can reside even when the set is unplugged.
Posted on Mar 13, 2009
    Scholar:
  • 29 Answers
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
Ken , the poster of that Blog writes........
"The problem is with the convergence via the voltage on the
color ray gun tubes that get out of adjustment.
They are also known as retrace lines."............
This blog covers many makes and models with many
issues solved, just with that one solution
Give it a try, it's FREE and SIMPLE :D
Had very similar problem, that blog helped me save
my TV and hundred's of $$$$ in repair costs ! :D
Hope the blog helps you also :)
Jean
Posted on Mar 12, 2009
Hi I bought my canon 1000d on september 2009 and a year later the autofocus doesnt want to work. In the viewfinder on the far right a number 9 has a green dot flashing next to it. Please help!! Ruthven...
The 9 you see is the maximum "burst" which is (pictures made in rapid succession) and is not an issue with your problem at this time the flashing green dot is the in focus confirmation light and it's good that you are seeing this as we will use it to remedy the problem.
Diagram
Manual focus switch
Diagram here
What I want you to do is put the AF-MF switch in the manual mode if it's already in manual mode then that was your problem switch to AF and go take some pictures. If it's in AF mode switch to MF make sure teh camera is on and look through the viewfinder at a subject say 15 feet (4.5 meters) away something that has contrast then turn the manual focus ring on the camera slowly until it appears to your ey that it's coming into focus when it's in focus the green light will come on solid, now you know what you are looking for focus an several different objects at different distances and focus manually. Now switch the lens over to AF (auto focus) and focus on the same thing but let the camera do the focusing What auto focus will not focus on in something with little or no contrast like water clear blue sky a painted wall mirror chrome glass and a few other things.
Here is another diagram to check make sure you are in the correct mode.
Diagram
Now for the focus point in the viewfinder make sure it's in the center position.
To adjust the focus point do this
Once you have the camera set to the center focus point and the correct AF mode (one shot) auto focus should return to your camera. Have fun Robert from London Ontario Canada
Jan 10, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Picture looks concave ,mostly yellow,and double vision on words
Remove unshielded speakers or other metallic objects near the TV. It can cause picture distortion.
  1. Tune the TV to channel or cable program.
  2. Run the TV for at least 30 minutes.
  3. Press FLASH FOCUS on the front panel of the TV.
  4. A cross pattern appears and FLASH FOCUS begins to
    work. The adjustment is completed when the cross pattern becomes white and you are returned to the program you were watching.
You cannot perform any other functions until FLASH FOCUS has
completed its cycle. If you perform any other operation while FLASH FOCUS is in progress, FLASH FOCUS operation is canceled.
Oct 30, 2009 | Sony KP-57HW40 57" Rear Projection...
Double vision in minolta binoculars
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself.
Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside.
2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking.
3. Set the rotating eyepiece to the middle setting.
4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one.
5. Pick an object app 10 meters away.
6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus.
7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus.
8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
Aug 30, 2009 | Minolta Activa Standard Zoom Binocular
I bought these for my husband. In trying them
Difficult to answer specifically without knowing the model. But binoculars are designed to view objects in the distance. They all have a limit as to how close they will focus based on the magnification and design. Objective lenses that are far apart such as on a porro prism binocular will not focus very close. The nature of the design of having the objectives further apart than the eyepieces doesn't allow it. When trying to focus too close the image will appear blurred and double. That is the nature of the design. 9 feet or 3 metres is considered quite close to focus a binocular and is usually for a model designed to do this such as a roof prism where the objective lens and the eye lenses are inline. A specialty binocular such as the Pentax Papilo will close focus to 50 centimeters. It has been designed so that the objective (large lenses) lenses converge.
Take into account when focusing that binoculars are also designed to compensate for differences in each eye. One of the eyepieces either right or left will adjust seperately. For binoculars with a center focus ring. First focus using the center ring with one eye covered. The eye that should be covered is the one that doesn't have the adjusting eyepiece. When the image is clear close the eye you have just used and leave the center focus alone. Focusing on the same spot look through the eyepiece that adjusts and turn the eyepiece ring until the image is clear. Now all you have to do is focus using the center ring only as the binoculars are adjusted for each eye.
Some binoculars do not have a center focus and each eye will adjust seperately.
Jul 29, 2009 | Optics
Double image on green
Focus won't help if it is a double image. Sounds like convergence amps need to be replaced. Very typical on these.
Jul 04, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Double image
The distance between the centers of the eyepieces of your binocular must be the same as the distance between your pupils. This distance is adjusted as follows: 1. Focus on a distant object. 2. Pivot the two halves of your binocular farther or closer apart until you can see a single unobstructed, circular field of view. Make sure to focus on a distant object when you do this because when you focus on a close object you always see two slightly overlapping circular fields. Your binocular may have a scale on the top, between the eyepieces, to help you remember this setting.
Aug 03, 2007 | Bushnell 10 x 42mm Sportsman Binoculars
Double vision
Jul 03, 2007 | Bushnell Powerview - Compact 10 x 25...
Focusing Yukon NVMT 20040WP Monocular
It should focus normally from some 50ft up. Try to adjust the dioptery on the rear ocular.
Mar 19, 2007 | Yukon NVMT 20040WP Monocular
Televison & Video Logo
162 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
